Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 100
Thread: Lian Li PC-A77 Mod: Project [Thessa]
  1. #51
    Nov 2005
    Quote Originally Posted by 64dragon View Post
    looks amazing, keep up the good work
    why can't all cases come with powdercoated interiors, they make the cases look 10x better
    I agree 100%. Especially in high end cases, it make everything look that much better no matter how wild or ordinary. Puts my pc-70 to shame.
    Core i7 930 @ 3.8 1.24v
    Asus P6X58D Premium
    6 gb G.Skill Pi 1600
    Diamond 4870
    Corsair 750HX
    Intel X25-V SSD
    2 x WD 640gb black
    Lian li PC-70
    Asus MS238H LED Monitor
    H2O: Thermochill 120.3, MCP 655 pump, EK Supreme HF (nickel/acetal), San Ace fans
  2. #52
    Mar 2007
    Killadelphia
    Mabuhay !!! Very nice looking !
    CPU: INTEL Q9550 E0 @ 3600 1.28V + CORSAIR H50
    GPU: EVGA GTX 480 @ 725/1450/3800
    PPU: EVGA 9800GTX @ 738/1836/2250
    MB: ASUS P5E X38
    RAM: MUSHKIN 2X2GB
    SOUND: X-FI TITANIUM FATAL1TY | LOGITECH Z-5500 | LOGITECH G35
    HDD: WD 76GB X 2 RAPTORS RAID 0 10KRPM | WD 1TB CAVIAR BLACK 32MB STORAGE
    PSU: CORSAIR HX1000W PSU
    OS: WINDOWS 7 PRO X64 OS
    MON: HANNSPREE 28" 1920X1200 RESOLUTION
  3. #53
    Jul 2008
    Lost
    This is very similar to the build I'm working on. I'm curious, how did you get that annoying cross-bar off the top half of the case? Near as I can tell the damn thing is riveted in place and I didn't see an easy way to get rid of it without cutting it. Something else I'm considering on my build is mounting a pair of Laing DDC on the MB tray, and putting a 120.1 radiator/fan on the bottom of the case, although that will depend on how clean I can run the wiring and such if I do that. I was origionally considering a 120.2 radiator on the top, but seeing how clean it looks when you remove the top PSU mount and cross-bar I might use a 120.3 instead.
  4. #54
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Quote Originally Posted by disruptfam View Post
    wow
    powder coating would be 4 times that over here same as laser cutting
    project is looking good...
    keep it going
    I don't think it would be. If he is only getting the interior done and most of the prep was complete. It wouldn't be more than $50-$75ish...
    Quote Originally Posted by orclev View Post
    Removing rivets is very easy, all you need is a drill. It seems everyone is afraid of rivets, but there shouldn't be a reason why, they aren't that bad.
  5. #55
    Mar 2008
    Philippines
    modded my d5 pumps to fit threaded barbs. shown with 1/2id fittings.
    http://www.tantricmodz.com/
  6. #56
    Jul 2008
    Lost
    Quote Originally Posted by lowfat View Post
    I think it's more a psychological thing. If you remove a screw and change your mind you can always put it back. Removing a rivet is a bit more permanent, although even then if you have a pop-rivet gun you can reattach them, although they won't look as nice as the factory rivets.
    I really didn't look very closely at the bar because at the time I wasn't planning on doing any heavy modification to the case (was still planning on air cooling), but after deciding to go with water cooling it became apparent I would need to modify the case if I was going to go with a internal setup and preserve the clean outside lines. I was sort of hoping there were some screws I missed or something, but if I have to I guess I'll just need to drill out those rivets. Definitely an option I'll consider.
    On the other hand, I could save that HD cage and mount some HDs there, while removing the bottom most HD cage from the front of the case and putting a radiator on the front panel, my pumps, or a radiator across the bottom of the case instead. So many options to consider, almost makes me wish I could just buy 3 or 4 systems and try them all.
    Anyway, I'll definitely be keeping an eye on this build to see how it goes and maybe snag a few ideas .
    P.S. Knet370, nice mod on the pump. I'm afraid I'd be too scared to try something like that on mine, that's a fairly hefty chunk of change should you screw it up.
  7. #57
    Feb 2007
    Turkey
    Very nice work on d5
    vuuuu
  8. #58
    Mar 2008
    Philippines
    some update. better pics will be taken once im done leak testing.
  9. #59
  10. #60
    I am Addicted!
    Feb 2006
    Very Nice Work! I was thinking of getting this case or the silverstone TJ-07; still a toss up as they are both excellent cases
  11. #61
    Mar 2008
    Philippines
  12. #62
    Mar 2008
    Philippines
  13. #63
    Jun 2008
    teh! batcave
    knet: nice job! talk about organized chaos
  14. #64
    I am Xtreme
    Sep 2006
    Great job mate I just received my case precut by Tom from Chilledpc.co.uk... will take some picices of mine when it's done still awaiting the 2nd rad from aquatuning...
    how did you mount the front rad ? any pictures of that ?
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
  15. #65
    Apr 2008
    France
    nice, very nice subscribed
    [SIGPIC][/SIGPIC]
  16. #66
    Mar 2008
    Philippines
  17. #67
    Mar 2007
    Killadelphia
    Blackened !!! Nice!
    MB: ASUS P5E X38
    RAM: MUSHKIN 2X2GB
  18. #68
    Feb 2008
    Australia, Perth
    VERY nice work!
    I love the Res's + Fan grill!
    Keep it up!
  19. #69
    Mar 2008
    Ah sweet job.Your setup looks awsome.
  20. #70
    Mar 2008
    Philippines
  21. #71
    Apr 2008
    Australia
    Well done knet370
    Awesome job mate.
    Anyone know of a good powder coating and laser cut place in Melbourne????
    I'm inspired
    [SIGPIC][/SIGPIC]
  22. #72
    Jun 2008
    Wow! simply amazing knet...
    I'm speechless!
  23. #73
    Mar 2008
    Philippines
    its now in blue uv dye. my rig is now a boy.. ;-)
  24. #74
    Feb 2005
    MANCHESTER - UK
    Have to say, that looks awesome!
  25. #75
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    looks really nice with the blue nice work!
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
