wow i love what you have done to the case looks really clean bro! i envy your creativeness
Veery nice mod!
Amazing case!
Suscribed!!
just a trial run of the tubes. it may be revised when better layout arises etc...final tubes will be a black 3400 3/4od tygon
comments/suggestions are very much welcomed
CPU loop : Have you considered losing the tube from the pump outlet -> radiator? You can use the resevoir as a vertical water transport if you swap the resevoir caps.
You can have the pump feed water into the single connect point in the bottom cap, and then the top cap can be used to connect the radiator feeder line (the side connect on the top res cap) and a filler/bleeding tube connected to the top barb.
I have run this config before, and as long as there was water in the filler tube, the micro air bubbles would bleed out in the tube.
Custom black murderbox
QX6700 Quad Core
eVGA Nforce 680I SLI A1
2x eVGA e-Geforce 8800 GTX SC
2GB Corsair 9136C5DF 1142 Mhz
PP&C 750 Watt Sli PSU
2x Raptor 150GB + 75GB
Ek Waterblocks (Gfx, CPU, Chipset, Resevoir)
MCP655 Pump / Variable Speed
Thermalchill PA120.3 & PA120.2
Custom Silverstone TJ-07 case
@friedchicken
please enlighten me..i am not aware of that..can you make a illustration of what you are saying? ms paint will do. thanks!
The filler tube can be clamped to the top of the case for easy fill/drain, or it can be hardmounted.
This way works if you can mount the resevoir right above the pump inlet to give you enough room to mount the drain tube at the top of the res. You would need a 90 degree elbow to clear the radiator if you can go this route.
QX6700 Quad Core
yes you are indeed correct. definitely a better tube layout. thank you sir for the suggestion.
there are too many turns in the tube from the back res to what i think is the 2nd pump?
Bottom leftmost tube.
Thermaltake Armor Series Black
GIGABYTE GA-P35-DS3R
Q6600 3.6 GHZ Thermalright Ultra 120 eXtreme
4 GB Corsair XMS2 w/ OCZ XTX Ram Cooler 2 x 60mm
9800GT 512MB
18X Pioneer DVD-RW Burner
720 Watt Enermax Infiniti
4x640GB RAID 10
Windows 7
some minor tube layout revisions...thanks to friedchickens better idea.
That's a pretty sweet tube run, great execution, and good idea FC.
some minor revisions
kenneth, that's such a tease!
I would agree to leave the lcd screen out to preserve the sleek design.
Like the murdered out insides though, good job.
very nice case! +1
just a question? What Ram cooler is that? I found an OCZ one but i want a black one :up
They just painted the said cooler black
its just a powdercoated ocz ram cooler. ;-)
il be using now my 780 instead of the 680i. still waiting for my ek 780i nb block
Amazing job! I love the gloss contrast of the radgrill to the case. With super humid climate in the pinas, I knew there had to be quite a few mod/watercooling enthusiasts there. Very clean inside also.
I am just in ahhh. Wow I wish I could have the time and money to build a rig like that.
Desktop:
Antec 300
Foxcon A7AD-S 790GX
8GB Gskill PC-1066@5/5/5/12
PII X940 BE @3.6GHZ
Sunbeam Core Contact
2x 640GB in Raid 0+1
4870 512MB@800/1000
Vista Business 64bit W/ SP1
congratulations pre for being one of the chosen to be Bit-Tech's Mod of the Month! good luck to you!
beautiful mods and nice picture... very good tubing, looks very good!! keep this going!
Sony Vaio VPCSA35GX while 7Mm away from home... Back at home:
C2Q QX6850 3Ghz@3.4Ghz - P35C-DS3R
XFX GT220 - 2x2Gb OCZ PC9200@1004 5-5-5-15
3X500Gb + 64Gb - Case Thermaltake V-3 Black Edition
AC F7 Pro + TR HR-05
Very nice build.... I was looking at that case and was planning on doing the same thing that you did. But I decided on a non Tower case build..
CPU: Intel Core i7-4770K 4.8GHz
MOBO: GIGABYTE GA-G1.Sniper M5 MATX 1150
MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31 1T
GPU: 2 x eVGA GTX 780 SC
SOUND KRK Rokit 5 Limited Edition White Studio Monitors
SSD: 4 x Samsung 128GB Pro's Raid 0
PSU: SeaSonic Platinum 1000W
COOLING: 2 x Alphacool NexXxoS UT60 Full Copper 420mm 6 x Swiftech Helix 140mm Fans
CASE: Lian Li PC-C32B TECH STATION MOD build log coming soon
MONITOR: ASUS VG278HE Black 27" 149Hz
O.S: Windows 7 Pro x64
Ganda! Mabuhay!
Job well done!
Mobo: Foxconn MARS
Cpu: Wolfdale E8200 C0 @ 4ghz @1.38v w/ TRUE-120 Black
GFX: 8800GT G92 @stock
Memory: Team Extreem 2x1 5-5-5-15 1100ghz @2.11v
Hard Drive: SB 500GB
Optical Drive: LG 22x DVD/RW LS
Case: Lian-Li PC-G7B
Foxconn ROCKS!
looks amazing, keep up the good work
why can't all cases come with powdercoated interiors, they make the cases look 10x better
XS WCG Rules: #1: don't pull fart_plume's finger #2: Dave aka Movieman, don't give him your phone number if you like your hearing
XS WCG Note: There are 2 sets of points, WCG and Boinc. WCG = 7x Boinc
Project: Dark Matter (<- link) - Asus Maximus II Formula, Intel X3330 3.4ghz @1.32v under load, corsair ddr2 1066 8gigs, evga gtx260 core 216, pc p&c 750W, EK Supreme HF Nickel, iandh 175 res, Swiftech MCP355, Black Ice GTX G2 240, Lian Li v1200b
silverstone tj07 build log
