the discuss, problems with aegis panel.
http://www.quantum-force.net/Tutorials/T000000001/
btw
can somebody send versions working on the destroyer ?
pleaseee
btw
pleaseee
please downlkoad at quANTUM force website
http://www.quantum-force.net/downloa...IJ7wf7cCALoBs=
For me it is very buggy on mars...with different multipliers it shows too high values and additionally it is too big considering the window size itself. I prefer something like smart guardian where you have all relevant informations in one small window - that's better to keep on top and for screen shots. maybe I can get on the wishlist with that
| '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
| '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
| '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
| '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
| '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
| '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
| '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
| '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
Originally Posted by saaya
yepp, i prefer a memset like look as well, keeping it simple and focussing on the settings and not so much on the bling bling
ill forward your feedback
i like aegis panel
and it working as well I want
but my favourite program for ocing in windows is clockgen but I think he never comeback
and memset ofc
you dont like setfsb?
i really like the cpuz look... memset, coretemp, setfsb... they all kept it simple, functional, classy and timeless
lets think about this
setfsb won't work on amd platforms so I have to use aegis panel.
i meant in general, just from the looks
oh
You're on MARS or Black Ops?
imho CPU is not ok. For me it seems that the temp reading in Aegis for CPU in fact is System temp. I verified with HWMonitor 1.08.0
edit: new aegis panel 1.0.2.32 shows temp readings correct now. tnx :-)
ok, so the latest version works for all temp readings?
At least for me it does and I compared with HWMonitor, which reads exactly the same
ok, good to see its working for everybody with the latest version
Not sure if this is relating to the Aegis Panel, but I just measured Voltages according to measure points Sham linked in another thread.
CPU Vcore set in BIOS 1.275 - Aegis Panel read 1.27/1.25 - DMM 1.260/1.244 idle/load
VTT set in BIOS 1.200 - DMM 1.117
VDIMM set in BIOS 1.916 - Aegis Panel read 1.98 - DMM 1.879 (slightly off reading in Aegis)
VNB set in BIOS 1.406 - Aegis Panel read 1.43 - DMM 1.230 !? (measured @ closest VRM (O36 on the PCB) to the NB) - either this is not the right point where to measure or something is wrong there. When increasing amount of Voltage for NB, the corresponding Voltage changes but does not reflect the amount of change.
for blackops, vtt for 45nm will be 0.1v lower, cos def 45nm vtt is 1.1 vs 1.2 for 65nm
Yes Peter I know about the VTT, thank you anyway
Can you or someone else please confirm or check Northbridge-Core-Voltage and compare reading thru Aegis-Panel/BIOS and digital multimeter?
I dont have the read points.
If yoy provide them Im sure Pederss can check for you!
[SIGPIC][/SIGPIC]
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
Also need to know where are you grounding?
