Page 1 of 4 1234 LastLast
Results 1 to 25 of 88
Thread: Hardware Labs 480GTX thermal testing results
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    First a very special thanks to Jeremy from Danger Den for providing me not only one, but two samples to use for my system upgrade. Danger Den is really committed to helping us testers out in providing you with information about performance, and that means ALOT! in my book.
    I'd also like to give special thanks to Linus from NCIX for providing me the fans to test with, they are also very interested in helping out the community.
    I've updated my previous review here:
    http://www.martinsliquidlab.com/HWla...TX-Review.html
    As you might expect, the radiator is an impressive one, for estimated water temperatures you can use this chart:
    And to compare fan effects with the Thermochill PA120.3, you can use this C/W vs RPM chart.
    I've also taken it another step and used the results to estimate the differences using different heat loads and fans on the PA120.3 vs the HWlabs480GTX.
    Bottom line..the 480GTX provided better heat dissipation from about 1120RPM on up, and at 3000RPMs it's dissipating nearly twice as much.
    Yate loon designates the D12SL12 fan as their "Slow Speed" fan which is specified to run at 1350RPM.
    The Thermochill PA120.3 is still KING of the Ultra low fan category (Less than 1100RPM), it's also extremly low in restriction comparatively, so it does very well in multiple radiator loops.
    The 480GTX is however KING of Slow, Mid, High, and Ultra High speed fans(Greater than 1100RPM). That's impressive!
    Cheers
    Martin
    XS News
    Dec 2003
    North Carolina
    Great work Martin. Thanks for this.
    RIP Dad. I will miss you always.
    Q6600,DFI X48 T2R,280 GTX,4gig ReaperX,XiFi Prelude,LL TYR PC X-2000,Westinghouse 37,Klipsch 5.1 Ultra
    Oct 2007
    US, Michigan
    That's pretty impressive. Only problem now, is how you fit that on anything?
    D-Tek Fuzion quad nozzle & MCW30
    8800GTS 512 @820/999/1998 with a MCW60
    2xMCP655b
    1xMCR320 and 1xMCR120 with 4x Yate Loon SH's
    2x Raptor X
    May 2008
    VA
    another set of comprehensive testing results! thanks martin
    Oct 2007
    socal
    yay! no more contemplating 480 it is! thanks martin
    Feb 2007
    Turkey/İzmir
    Hmmm interesting I want to buys one of these..
    Great work martin
    Intel Core i7 930@ 4.0Ghz | Gigabyte EX58-UD4P | 3x2Gb OCZ 1600mhz | Palit GTX280 | 1TB Seagate | Samsung P2350 23'' | Silverstone Decathlon DA750W | Lian-Li PC777B | Logitech Z-5500 | Creative X-Fi| Iphone 4
    Hardwarena Overclock Team
    Jul 2007
    Canada
    Excellent! This is the kind of hard data that desperately needed in larger quantities, and you do an excellent job of both gathering and presenting it. Looking at the c/w graph really highlights the fact that different radiators can be optimized for different airflow speeds, and actually be superior to the other under the right conditions.
    That said, any chance of adding in a theoretical 360GTX curve? I don't begrudge the 480GTX its victory under most of the curve (and it tells me that I made the right choice for my sub-1000rpm fans), but a comparison to the 360 might do more to directly highlight construction and design differences between the two. Doing some basic estimation, it seems that such a curve wouldn't upset the boat too much, except that the crossover point would likely slide up to about the 1500rpm mark.
    Regardless, great job! Hope to see more in the future!
    i7 2600K | ASUS Maximus IV GENE-Z | GTX Titan | Corsair DDR3-2133
    Jan 2004
    somewhere in Massachusetts
    Excellent review, I was a bit disappointed seeing as I just bought a PA 120.3 then remembered that the 480 wouldn't fit in my U2-UFO, time for 22" cubes anyone? :-P
    Feb 2006
    Vienna, Austria
    basically this confirms the testing done by "effizienzgurus" in germany, they figure out that a gtx 360 equals a pa 120.3 at 1200+ rpm and continues to increase its lead with higher speed fans
    great testing, thanks!
    Core i7 2600k|HD 6950|8GB RipJawsX|2x 128gb Samsung SSD 830 Raid0|Asus Sabertooth P67
    Seasonic X-560|Corsair 650D|2x WD Red 3TB Raid1|WD Green 3TB|Asus Xonar Essence STX
    Core i3 2100|HD 7770|8GB RipJawsX|128gb Samsung SSD 830|Asrock Z77 Pro4-M
    Bequiet! E9 400W|Fractal Design Arc Mini|3x Hitachi 7k1000.C|Asus Xonar DX
    Dell Latitude E6410|Core i7 620m|8gb DDR3|WXGA+ Screen|Nvidia Quadro NVS3100
    256gb Samsung PB22-J|Intel Wireless 6300|Sierra Aircard MC8781|WD Scorpio Blue 1TB
    Harman Kardon HK1200|Vienna Acoustics Brandnew|AKG K240 Monitor 600ohm|Sony CDP 228ESD
    Feb 2008
    Italy
    i think the interesting point should be the curve, that for 1600rpm or above is the same (obviously situated lower because of the bigger radiator)..to conclude ihmo the gtx 360 should have the same curve of the pa120.3 with 1600rpm or above, and similar performance with around 60cfm fans and not 100cfm (or more) as said from someone
    sorry for my english, I'm not an engineer but hope you see what i mean
    cheers
    thanks martin
    RzR
    15K 3d Mark06 @g80 GTS..Air
    R4z3R's Rig: Case : Armor TT | Cpu: Q6600 @3200 + ZeroTherm BTF90 | MoBo: Asus P5k Deluxe | Ram: Corsair Twinx2048 @920 4-4-4-10 | Vga: Gainward 8800gts 640mb @640/1650/2000 + Thermalright HR03 Plus | Psu: LcPower Arkangel 850w | Monitor: Samsung 226bw | S.O.: WinXp SP2 Pro | Audio: Harman|Kardon Soundsticks II
    Kh4rn3f1X's Rig: Case : AeroCool Engine 3T | Cpu: e6700 @3600 | MoBo: Asus P5k-E | Ram: Corsair Twinx2048 @900 4-4-4-10 | Vga: Gainward 8800gts 640mb @600/1600/1900 | Psu: LcPower Arkangel 850w
    Never go full retard
    Feb 2008
    I knew I should've went with higher speed fans on my PA120.3's instead of going with D12SM12's.
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Thanks guys.
    I've been thinking about doing some sort of extraction of the data to convert the c/w data per 120mm section of radiator, I just havn't tested enough radiators yet of the same exact type to know if it's a simple factor such as C/W X 120mm sections for an equivalent 120mm c/w. According to thermochill's posted data, that does appear to be roughly correct, but not exact. There is probably some losses occuring in the end caps/chambers. After I complete my XSPC RS series radiator tests, I'll be better able to see how I can piece apart and estimate smaller sizes from larger radiator tests.
    Sorry I don't have the 360GTX to test, but I am planning to continue working on rads for a bit longer before switching over to the CPU testing again. It would obviously be different comparing a PA120.3 to a 360GTX for those who are space limited. I have all my big rads external, so for me...I was mostly interested in seeing how each one does and considering they are about the same price...it was apples and apples enough for my particular needs. In my case, I like running the yate loon D12SL12 fans, although after testing, the mediums really not noticeably louder from what I could tell. For 1550 RPM slot, I'll get a little better temps with the 480 by a degree or so with the quad core overclocked when I get that all up and running.
    Apr 2008
    Ottawa, Canada
    I wonder if 2 GTX240's would be equal to one GTX480. Hope so because that's what I have.
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    very nice martin.thanks for all the effort "WE" all appreciate it.I would also like to see a test on the gtx 360
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    Martin i Hate you.
    Dont ever talk to me again.
    Cuz of this i bought 2 480GTX's today.
    Dayam YOU!
    LOL... on a real note tho, martin great work as always.
    Now to think of a way to mount them on my DD torture rack. Cuz i seriously did order 2.
    DB where are you!?!?!?
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Quote Originally Posted by NaeKuh View Post
    Martin i Hate you.
    Dayam YOU!
    I'm blaming hardware labs for making such a nice radiator and going big with quad sizing..
    I've always been more a performance IS form type, so I have no problem hanging both of mine off my aged and gatting arse old armor case...
    I think I'll be running one of the 480's dedicated to the CPU and the second for my 8800 and chipset blocks. You can never have too much radiator..lol!
    Chasing After Diety
    Jan 2007
    Quote Originally Posted by Martinm210 View Post
    ROFL..
    1 for the NICE TEC blocks you made me.
    1 for the GPU.
    Sorry martin i wanna show off your masterpiece so i hope you dont mind. :P
    But that 480GTX should have no problems keeping this monster in check @ 1500 RPMS
  18. #18
    Apr 2006
    Hong Kong
    What is that TEC block for? Does it cool the water on one side, therefore heating it on the other?
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
  19. #19
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    ROFL..
    1 for the GPU.
    Yeah, that TEC block is a perfect match for the 480. TEC's are extreme heatloads and that's where you'll really see the advantages particularly with the stronger fans.
    I'm still waiting for you to put 3 BIG TECs in there and start NEEDING antifreeze for it's lowering the freezing point abilites.
    I want to see three in there and one on the processor..
  20. #20
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Quote Originally Posted by CedricFP View Post
    It's a TEC chiller block idea, it took forever to make, but it was a fun project. It's meant for two loops, one to cool the CPU loop and a second that does nothing more than cool the hot side.
  21. #21
    Apr 2006
    Hong Kong
    Yeah, I figured. That could be a great idea. How much lower temps did you get the water on the cold side? Also, with the TEC, doesn't it follow that the hotter the hot side, the colder the cold side. So wouldn't there have to be a balance found when it came to cooling the hot side?
  22. #22
    Hamster Powered
    Apr 2006
    Virginia, USA [Krunching since 2001]
    Martin as always great testing and data presentation.
    XSWCG Disclaimer:
    We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
    Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
  23. #23
    Feb 2008
    nice review man i feel bad that i bought the thermochill rad
  24. #24
    Chasing After Diety
    Jan 2007
    LOL.. lets not steal this thread. I just wanted to show off the kind of work martin does.
    I tried to keep this a secret from the liquid cooling section. Any questions regarding Martin's Uber work should go in this thread.
    http://www.xtremesystems.org/forums/...d.php?t=172946
    Quote Originally Posted by cryptospartan View Post
    Still the largest class radiator that will fit inside a MM class case without moding. :P
    Okey martin if you watch TV and notice Los Angeles going though a blackout due to a unknown energy loss, its me.
  25. #25
    May 2006
    Excellent work and beautiful graphics Martin.
    Play-toy Rig: QX9650/Maximus Formula/Mushkin Redlines 2x1GB/3870X2 + 3870/Raptor-X/Zalman HP-1000/XP Pro-32 and Vista 64/3x12 Rad + EK-Supreme + Swiftech MCP-655 on the CPU/3x12 Rad + EK block + Koolance RP-1000 on the 3870X2/2x12 Rad + Koolance full block + Koolance RP-1000 on the 3870/1x12 rad + EK blocks + Koolance RP-1000 on the NB/SB/VRMs/Modded Lian Li Cube/SilenX fans.
    Image processing rig: Q6700/Blitz Formula SE/Mushkin DDR2-8500/HIS 3870/Raptor-X/Mushkin 800 watt PS/ Thermalright IFX-14/Armor w/ 25cm door fan.
