Will the bitspower 1/2id 3/4od fit on the swiftech apogee gtx copper top? i want to use it but im not sure if the distance between the inlet/outlet ports are far enough for the fittings to fit without hitting each other..
tia!
tia!
Got it on mine. There is plenty of room.
