+ Reply to Thread
Results 1 to 6 of 6
Thread: My A/C Water Chiller with Controller
    Registered User super dank's Avatar
    Oct 2007
    Virginia Beach
    0
    Smile My A/C Water Chiller with Controller
    I think this project might qualify as "extreme"
    I've wanted to build one of these ever since I first read about them, but I didn't want the slush that comes with a slushbox... It also just happens that I'm good with electronics
    I hope you like pictures
    Xtreme Addict msimax's Avatar
    Jun 2005
    NYC
    0
    you gonna burn out your compressor with that foam be careful with the temps
    nice setup
    Amd Nvidia/Ati -3dmark06 scorebord revisted
    asus L1N64-ws or /b depending on bios chip
    4x1gig 8500 gkill bpk
    2x opteron 8224 @ 3.8ghz
    http://www.xtremesystems.org/forums/...&postcount=236
    vga= 8800gt
    winxp pro
    custom chiller -31 water
    2x dtek fuzions
    bix3-with x3panaflo hi output
    antec 850 quattro
    heat under msimax abitmax and dfimax
    Jun 2007
    Germany
    0
    Do you have a little bit more detailed infos on the parts used?
    On first look it looks nice, but as msimax mentioned already: be careful with that foam on compressor!
    EDIT: Why don't you use a couple of 12cm fans instead of that one big fan?
    Oct 2007
    Virginia Beach
    0
    Quote Originally Posted by msimax View Post
    nice setup
    Thank you,
    The first DC fans I tried didn't keep the condenser cool enough, but I used a 120V AC fan that does the job perfectly, temps aren't a problem. Controlling both the compressor and fan via relay, via AVR
    Water temperature and duty cycle are programmed
    The compressor only stays on for about five minutes, then stays off for about 20-30 minutes no fan noise
    Assistant Administrator Buckeye's Avatar
    Nov 2007
    Stockton, CA
    127
    I am very interested in the controller board. Any chance you can post the schematic, parts list etc. ?
    Oct 2007
    Virginia Beach
    0
    Quote Originally Posted by Buckeye View Post
    With the nature of what needs to work to make a controller like this, I think the best suggestion is a good read about AVR and how they can work with your home-brew electronics. Don't forget, theres PIC and Parallax too, if you need lower level programming languages
    If you have any specific questions, you could PM me...
+ Reply to Thread
