Originally Posted by
n00b 0f l337
You never said anything about gauge being too short or anything! What's with that.
As for the original gauge not working, I tested gauge, and I tested system, gauge worked, yes the gauge for some reason did not work. Also, the system at CES did not work apparently due to a leak in the schrader, not sure how that happened especially with cap on. I recharged that and bumped to r402a for you. When you came and we replaced the gauge, I took one off my cascade project, you never mentioned it was too short and said that would be fine, would it be possible simply to mount gauge on side of case instead of front? Sorry for a small inconveinence.
When I put on the new gauge I did rush to show you the system was working, after that I did pull a proper vacuum again and recharge, showed you results again and then DROVE THE UNIT DOWN TO YOU, you lost no gas or money in this, and all of a day or two. In the meantime as for wiring, its not beautiful, however there is nothing wrong with it, and much of the wiring you YOURSELF did.
I find you unnecesarily rushing me, then never contacting me about problems before rushing me out of my control. I have tried to ammend the situation at every turn, from putting on a new gauge, recharging first and second numerous times, driving the unit to you on my own gas and time, and replacing gauge and such at no cost to you. All I see now is that your saying the capillary to the gauge is to short? And thus this is a huge problem?
If theres something else wrong, please let me know, you've never pm'd me about the gauge being too short or anything. Jake I have no idea how I've wronged you. As for camera pics, my mother is on her honeymoon after he wedding last weekend, and yes you even said congrats to her so I know you know about that, and she has the camera. In that contains a memory card, since you really seem to want pics of that gauge working, thats not a problem at all, I have them on that stick, 99.995% certain. You have asked me twice now for those pictures, but within 24 hours of each other, or immediately at the original moment, times when the camera, which I do not own is not in my hand.
Jake tell me the problem and I'll gladly fix it, seriously, never ever have said no to fixing any of the problems we've had or anything.
So let's recap that.
Finished your two stage for you, you saw it working, except gauge, however CES was around corner and you had to rush to crate and ship it that night, so said we'll fix after, gauge again worked during pressure testing at that time before charging. Get to CES seems to work fine, however you say you don't have WC components, and they arrive a day later. You have told me you tested it then, I have seen schraders start leaking if they see incredibly high pressure (350+ psi), which is possible without the WC'ing hooked up. Not a problem with me though I recharged it when it got back. Again gauge not working when you go to pick it up, odd cause I had it working, we ripped that assembly down to find some gray stuffs in the captube at the braze end of it, it's not braze, but it was something. Possibly some oxidiation, Chris thinks it might be or is braze, fine, I saw gauge working, unit was working fine at that time. I offer to put new gauge on right then, and check to make sure it works and all that. I then retuned. You asked me to deliver memorial day, I ended up walking in a parade as a Boy Scout, and delivered the next day no problems. Now gauge is too short apparently by a few inches, something you didn't mention and haven't except here, if you'd like to bring it back thats fine, if we can mount it somewhere else thats fine too. It's a minor inconveinence. Something I'm glad to fix.
Why not contact me when theres a problem?
So theres a slight gauge issue, do we have anything else that seems to require a thread here?
I'm never more then a text or PM away, and I've invited you over and benched with you, I don't see why the hostility either. I realize you've been rushing to move, however I've been trying to make your deadlines as well, and have except for 24 hours it would seem.
