They are all pretty similar
which one do you guys think is the best?
CM 590. I've had great luck with CM cases in the past.
get the M9 cuz it's already black inside.
I7 920 D0 4.2GHz 1.29v || EVGA Classified 760|| Crossfire ATI Radeon 5870 || G.Skill Ripjaws 12GB DDR3 2000 || Thermaltake 1.2KW PSU || Corsair 800D || Windows 7 Pro x64
Airflow-wise the Antec 300, CM 590, and Thermaltake M5 are all similar and superior to the M9 it seems but I think the M9 is the best looking though it lacks a top exhaust fan/vent.
i7-2600k L041C108 4.8ghz 1.32v PLL off Venomous-X Push/Pull http://www.xtremesystems.org/forums/...postcount=1063
Asus P8P67 Vanilla
Samsung 30nm MV-3V4G3D/US 2x4GB @ 9-10-10-28 1T DDR3 2133 1.6v http://www.techpowerup.com/forums/sh...d.php?t=159320
Diamond HD 7970
WD 600GB Velociraptor
Corsair TX750W
CM 690 II Advanced
Q822A549 E8500 @ 4.5ghz air TRUE @ http://www.xtremesystems.org/forums/...d.php?t=203762
G.Skill F3-12800CL6D-4GBXH @ 7-10-8-27 1T DDR3 2133 1.6v http://www.xtremesystems.org/forums/...d.php?t=266839
PC: none at the moment
Lappy: Dell Latitude D520
CPU: Core Duo T2300E 1.66GHz
RAM: 1 Gb generic
VGA: Intel 950 gma
HDD: 60 GB Hitachi 5400 rpm + 250 GB Phillips external
Mouse: Razer Lachesis
Mousepad: Razer Mantis
Headphones: AKG K701 + LittleDot MK II + Behringer U Control UCA202
OSes: Fedora 9 - work || XP-games (only DOTA)
Additional cooling: seated on cigarette packs with custom made USB powered fan
Top vent on m5, no top vent on m9:
http://www.thermaltake.com/product/C.../vI1000bws.asp
Asus P8P67 Vanilla
Diamond HD 7970
Corsair TX750W
CM 690 II Advanced
RAM: 1 Gb generic
VGA: Intel 950 gma
I have the cm590 and i must say its an amazing case. Its got TOO MANY fanslots
Double vent on top, 1 rear vent, 1 bottom vent, 2 left side vents, and 1 front vent all ready for 120mm fans, 1 right vent ready for a 80mm fan, and a rear vent next to the VGA slots for some more airflow. Couple that with the holes in the rear with grommets for watercooling tubing, and the mesh front this thing is a beast of a mid! And very cheap too!
Main Rig
~Rosewill Thor V2 Full~ASRock Z68 Extreme3 Gen3~i-5 2500k OC 3.8ghz Stock Cooler~MSI GTX 560Ti 2GB Twin Frozr II~Mushkin Radioactive 2x4GB DDR3 1600~ Mushkin Chronos 60GB SSD~3x500GB WD Blue~Antec True Power Trio 650W ATX12V~Acer 23" LED LCD~Win7 Ult~
Backup/GF Rig
~Coolermaster 590 case~E6850 3.0GHz~MSI P7N SLI Platinum 750i~CORSAIR XMS2 2x2GB DDR2 800~EVGA 8800GTS KO 512MB~Win xp~Needs HDD's, PSU, Monitor~
The TT M5 looks sick
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
Thanks for the input guys, I'm leaning towards the cm
if i plan to buy one extra fan for it should i put it on top or side?
my vote goes to cm or 300
DNA = Design Not Accident
DNA = Darwin Not Accurate
heatware / ebay
HARDWARE I only own Xeons, Extreme Editions & Lian Li's
https://prism-break.org/
