iMac 24''
BNDMOD @ Cruz Alta (Cba.) Argentina
Thermalright website says they won't fit and i'm not going to doubt them on that. For yours i think you should look at Enzotech Mosfet sinks. 10 in a box and you can fit one on each mosfet you feel needs the cooling.
Everyday is a NiceDay
iMac 24''
Use the Enzotech for it all. US$9.95 a box of 10
http://www.enzotechnology.com/mos-c1.htm
or which incidentally fits the commando as well
http://www.enzotechnology.com/mst-81.htm
personally i find them better than my thermalright hr-09, i blame the thermal pads they provide.
Thank bro again...
Nice the second link very nice solution... here in argentina it's very difficult find those things.... but i'll try or buy in usa and curry to here...
ENZOTECH MST-81 heatsink fit perfectly with commando...
ASUS
P5E3 Deluxe、P5E3、P5E3-DWiFi-AP、P5K Premium/WiFi-AP、P5K3 Premium/WiFi-AP、P5K3 Deluxe/WiFi-AP、P5K Deluxe/WiFi-AP、P5K-E/WIFI-AP、P5K WS、Commando、P5B Premium Vista Edition、P5B Deluxe、P5B Deluxe/WiFi-AP、Striker、P5N32-E SLI、Striker Extreme、M2N32-SLI Deluxe or... this say not up side, only left side.?
iMac 24''
Nice find Ar3s. I agree with you on the HR09, the thermal pads aren't that great.
Contemplating over the MOS-C1. Seems like a pretty good solution.
Apple MBP 15": Intel T9400 (2x2.53GHz) | 2x2Gb DDR3 1066 | 9400M + 9600M GT | 250Gb 7200rpm
Wish List: Return to desktop for some crunch action.
I am on... QuadCaine.
No problems. Do share how good they perform when you get the MST-81.
Thermal Adhesive : Fujipoly GR-d Thermal Tape is totally new to me.
GR-d Ash black 0.82(100G-d)(℃ /W)
I have found the problem with the HR-09 thermal pads. Seems to be an arse thick amount of wax on the thermal pad contact surface. I have removed that layer, currently using it to test it out.
Does the MST-81 fit an asus p5e?
it's not on the list but i see no reason why it wont..
