SSD's going from strength to strength here
X5670 B1 @175x24=4.2GHz @1.24v LLC on
Rampage III Extreme Bios 0003
G.skill Eco @1600 (7-7-7-20 1T) @1.4v
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Intel X25-E SLC RAID 0
Samsung F3 1TB
Corsair H70 with dual 1600 rpm fan
Corsair 800D
3008WFP A00
All those tests are in 4-way raid0 if got that correctly. How's that relevant to any users here?
Seems we made our greatest error when we named it at the start
for though we called it "Human Nature" - it was cancer of the heart
CPU: AMD X3 720BE@ 3,4Ghz
Cooler: Xigmatek S1283(Terrible mounting system for AM2/3)
Motherboard: Gigabyte 790FXT-UD5P(F4) RAM: 2x 2GB OCZ DDR3 1600Mhz Gold 8-8-8-24
GPU:HD5850 1GB
PSU: Seasonic M12D 750W Case: Coolermaster HAF932(aka Dusty )
The article covers single drive and RAID 0 performance figures but most of the results are comparing single drives...
Also the more these drives are released to and begin to saturate the market the faster the price will drop and consequently the more relevant they will become to the average Xtreme systems user...
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Samsung F3 1TB
Corsair 800D
3008WFP A00
Now drop the price to 1/10 and I'm interested.
You were not supposed to see this.
GPU:HD5850 1GB
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Samsung F3 1TB
Corsair 800D
3008WFP A00
I'd like to know how they compare to Super Talent's new MLC SATA-II drives. Nobody has done a review on Super Talent's new drives yet but some may show up next week if we're lucky.
http://www.supertalent.com/home/press_release.php#
wow. mtron gets whipped
edit: why does the memo get raped in 'XP start-up' tho??
DNA = Design Not Accident
DNA = Darwin Not Accurate
heatware / ebay
HARDWARE I only own Xeons, Extreme Editions & Lian Li's
https://prism-break.org/
Do they say in there which MTRON they are testing ?
I read through that but all I see is the MTRON Flash SSD, is it the Pro or Mobi ?
MRTON's web page also states that the Memoright has better write speed than the Pro.
The Memoright's also cost half again as much as the Pro's do.
The bench's are also right on the benchmark page MTRON has and clearly shows the Memorights are faster than the MTRON PRO's.
http://www.dvnation.com/benchmarks.html
The only real news here is showing the Adaptic 5805 raid card performance.
I would like to see a shoot out with Areca 1231ML vs Adaptic 5805
Still way too unreliable. The fact that these things die (dropping out of RAID or flat-out die) often in heavy enterprise workloads and yet cost so much is disappointing. You pay for reliability or your pay for speed/access... and SSDs have a long way to go.
My toys:
Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
Any links for that information ?
HDD also die in heavy enterprise works loads. Thats one reason why different versions of Raid's were designed, often they are desgined in case a drive fails then another can take its place until the failed drive is replaced.
I have yet to see any graph or link that shows SSD vs HDD reliability over time in Raids, or any fact that shows a SSD worn out from over use vs a HDD.
I would also like to point out that Eve-Online has been using RamSan setups for there online game servers for some time. Is that heavy use servers ?
http://www.superssd.com/success/ccpgames.htm
Clearly these are costly and you are right in one respect, you pay for speed/access.
I will agree with you that SSD's do have a long ways to go, in price per GB. And I am willing to bet that speeds will increase also. Low power and speed for laptops is a great addition though.
So much fud is out there that relates to first gen SSD's or completly different units.
here is this
http://www.storagesearch.com/ssdmyths-endurance.html
Configuration:- a single flash SSD. (Using more disks in an array could increase the operating life.)
Write endurance rating:- 2 million cycles. (The typical range today for flash SSDs is from 1 to 5 million. The technology trend has been for this to get better.)
Sustained write speed:- 80M bytes / sec (That's the fastest for a flash SSD available today and assumes that the data is being written in big DMA blocks.)
capacity:- 64G bytes - that's about an entry level size. (The bigger the capacity - the longer the operating life - in the write endurance context.)
Today single flash SSDs are available with 160G capacity in 2.5" form factor from Adtron and 155G in a 3.5" form factor from BiTMICRO Networks.
Looking ahead to Q108 - 2.5" SSDs will be available upto 412GB from BiTMICRO. And STEC will be shipping 512GB 3.5" SSDs.
To get that very high speed the process will have to write big blocks (which also simplifies the calculation).
We assume perfect wear levelling which means we need to fill the disk 2 million times to get to the write endurance limit.
2 million (write endurance) x 64G (capacity) divided by 80M bytes / sec gives the endurance limited life in seconds.
That's a meaningless number - which needs to be divided by seconds in an hour, hours in a day etc etc to give...
The end result is 51 years!
DRAM based SSD's are not the same as NAND based SSD's. DRAM based SSD's are many times faster and have a proven reliability and track record in the enterprise environment.
The reports of questionable reliability are starting to come in. Remember NAND based SSD's have just been out for about a year. Have a look at the Dell forums, 100's of SSD users from notebooks are reporting problems.
I'll try to find the links for you, but Dave Graham (a member here and deals with a lot of server-business type clients) reported months ago problems with NAND based SSD's in the server environment, many dying after a few months of heavy usage.
In addition, the inferior random writes makes NAND SSD's suboptimal for enterprise level heavy database applications. For desktop scenarios, you should be OK...hopefully. I would definitely look for ones with the 5 year warranty (Look at OCZ's 1-year warranty...LOL)
What SSD's are the Dell's using ?
holy !
now let the prices drop!
ASUS P8P67
i7 2600K 3.4GHz @ 4.6GHz
Twintech 8800 GT 512Mo Samsung (vgpu modded)
Crucial Ballistix DDR3 C7 2 * 2Go
2 * WD VelociRaptor 150Go RAID 0
2 * Samsung Spinpoint F3 1To RAID 0
Creative Sound Blaster Audigy 2 ZS
Seasonic S12 600HT
WC :
1A-SL2 CPU // 1A-SL2 GPU (home made fix)
Eheim 1048 + magicool 25
2 * Black Ice Pro 3 serial
Tygon 3603 + glycoshell
@Buckeye-
I think most Dell SSD's are 1st Generation Samsung's. FYI the SATA2 version of the OCZ is a rebadged Samsung v2 (100/80 read/write), only about $500 for 32GB, but 1 year warranty...
Dell officially disclamimed the 20-30% return rate (most of these were customers disappointed with performance, not actual failures).... but it makes you wonder...
its pretty amazing how fast the SSD market is moving.
whats good 2 months ago, is todays antique.
its pretty cut throat from what I seen over the last few months.
prices have even begun dropping alittle a few weeks ago.
with results like these coming so fast, it will amaze me if mechanical hard drives have much of a life ahead of them.
Let me look in my crystal ball of hope
I'd say, Q1 09, SSDs will have completely displaced the Raptor as the go-to drive for high-end enthusiast builds.
The Mtron's on test are the non-Pro series. The read/write rates are 95/75 MB/s, respectively.
Kunaak, where'd you see the price drops? I don't recall any significant drops (except EUR/USD going up and up, and thus most stuff costing much less for us in Europe ^^)
PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
GTX 470 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
I'll stick with my Raptor until I can pick up a 160GB SSD for under $200.
Thermaltake Armor Series Black
GIGABYTE GA-P35-DS3R
Q6600 3.6 GHZ Thermalright Ultra 120 eXtreme
4 GB Corsair XMS2 w/ OCZ XTX Ram Cooler 2 x 60mm
9800GT 512MB
18X Pioneer DVD-RW Burner
720 Watt Enermax Infiniti
4x640GB RAID 10
Windows 7
