well ive been thinkin of a way to get my temps down...and saw this and was thinking about takin the coils and putting them in a reservoir...
Ac unit
Ac unit
In the works... P5wdh | E6600 | G-skill 6400 hz | Ocz Gamextreme 700w | 2x Wd 250 raid-0 | 7600gs until i get my x1950pro
Main Rig: - Ic7-g 2.4c @3.3 1.6v| 2x 256mb corsahair 3500 2-3-3-5 | 9700128mb | Antec430 truepower | mcw478uht cpu @ 10c full load
Server:- Epox 8rda+ 2100 @ 2.4 1.85v | 2x 256 corshair 3200 twinx | msi5200 | TTGI520 | slk800 40c full load soon to be watercooled.....
i wouldnt go with walmart only because i bet those ac units probably use r134a and unless you are planin on gettin it recharged........ As far as the idea goes its a excelent way to chill water as long as your ready to combat condensation which will be plentiful. LoL as far a phase change goes this is probably only area i can help you in.
well buying a window unit is the cheapest and easiest way for anyone to start a chiller.
if you take your time you can make a nice chiller without breaking any tubes and without loosing any of the charge.
Instead of practising on a new one, see if you can find an old junker that still blows cold. If you break it, you had some experience and it cost you nothing, then get a new one. I see them in the paper for free, you haul away because the dump won't take them because they won't pay to release the gases by epa guide lines.
I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me.
Hunter S. Thompson (1939 - 2005)
sweet! ill check the paper today! they always got some nice stuf in the sunday paper! thanks
good call thedude
That's what I'm doing with this one, when I get time. It still blows very cold air. Needs to be gutted and cleaned up...hopefully without leaking the charge.
LoL.. That'll keep you busy
Yeah....looks like a train wreck! lol but it works and what have I lost if I break it? I need practice straightening the lines without busting them, and other things too.
r u planning on doing the same as me? if so can u show me what i would be puttin in the water
You can't see it in my pic, but it's where the cold air comes from in front. Instead of air it cools water. Take a look around the forum, there are lots of clear pics.
aite man thanks again i should be finding one soon! i almost convinced my parents that the chest freezer was not gettin used enough and that i need it for my comp this thing is massive and i know for a fact it would do the trick but i would more then liekly have to get some copper coils and have it recharged...isnt the stuff inside it called freon?Originally posted by TheDude
yep freon
LOL....I got this visual of you chopping up the family freezer....pounds of hamburger thawing out to rot....hurry up before they get home from work! lol love it!
yep and propane would probably be the best bang for the buck as far as freon goes afaik btw thedude that thing is fuggly
I wouldn't suggest a noob work with propane.
Yeah it's fuggly, but wait til I rip it out and clean it up....total cost = elbow grease.
whered u score it ne wayz
Neighbor was throwing it out and trash guys would not take it because they aren't allowed to dump it without evac of freon first...so I volunteered to dispose of it for her.
