Results 1 to 23 of 23
Thread: Is 1,8 Vcore too much for å E8400 on air? Sub 10!
    Apr 2008
    Norway
    It's a thermalright ultra extreme. The roomtemperature was 20 degrees.
    Oct 2006
    Hampshire UK
    I can't see you getting away with that voltage for too long.
    Have fun while it lasts though
    Quote Originally Posted by Tharshan View Post
    Oct 2006
    Hampshire UK
    BTW nice OC there, what system R U running?
    May 2006
    UK
    good overclock on cpu but what were the temps, thats a lot of volts for air or water , have you tried lower volts to see if it will run same overclock, i'm guessing its a commando motherboard
    Apr 2008
    Norway
    System i ran:
    E8400
    Asus Commando
    Crucial PC6400 Ballistix @ 1178 5-5-5-12
    8800gt
    PC power & cooling 750 W
    The CPU like the voltage. I tried from 1,6 to 1,8. Over 1,8v it does not well anymore :p
    I don't have any temps. I didn't chech because i thought that it just will worry me
    Jan 2005
    Nice... Though your ram or something needs tightened. Ive seen sub 10 second runs with the same chip @ 4.5Ghz.
    Yeah, at that voltage, dont plan on keeping it for too long.
    Mar 2008
    Poland
    1.8V for 45nm nice one, I've seen many 45nm dieing with vcore lower than this. Respect for courage
    May 2006
    UK
    System i ran:
    E8400
    Asus Commando
    8800gt
    yes i know what you mean better not looking at temps eh! , what would the cpu do with the 9x multiplier, i have had about 4 of the new e8000 series cpus and they all run different some only need low volts but run hot and some need more volts and run cool , the e8500 i have tops out at 4750 on water with about 1.72 volts thenm it gets too hot, on single stage cooling which i hooked up just for a bench session i rammed 1.85 volts through it and it did 5140 , and running same chip now at 1.35 volts at 4038mhz 24/7
    Oct 2007
    Toronto, Canada
    Wow havent looked at temps? GG
    Nice OC though.
    Intel Q6600 (Stock for now)
    Scythe Infinity
    XFX 680i LT
    OCZ 2 x 2GB Platinum DDR2 800
    EVGA 8800GTS 640MB
    Ultra Aluminus
    Mushkin 650watt SLI
    Seagate 500gb
    Seagate 250gb
    DVD Rom/Burner
    Apr 2008
    Norway
    Quote Originally Posted by jas420221 View Post
    Thanks for the info mate! I will try to tweak my ram
    Jun 2006
    Wow 1,8 volt on air is not good
    max 1,60 - 1,65 only for bench
    My Computer: CPU Intel i7 920@4 ghz 1.35 volt. MAINBOARD Asus P6t dlx. RAM CSX 2000. VIDEOCARD EVGA GTX 295 . H.DISK 2 x WD VelociRaptor 74 GB @ Win XP SP3 . POWER Zalmann 1000 Watt. CASE LIAN-Li A70 . INTEGRATED WATERCOOLING CPU Couplex + Rad V3 + MP655 + Vaschetta dual 5,25 . SK VIDEO EK + Rad V2 + MP655 + vaschetta 5,25
    Mar 2005
    North West London
    Yes I would say that 1.8v is too much for air, but I would also like to say that 1.8v is too much for 4.7Ghz as most people only need 1.6v or less for that speed, some people with 1.8v can get to 5.4+Ghz with the E8400.
    xwards
    Guest
    xtreme
    dont kill your cpu man
    Feb 2008
    Yup...unless you're ready for an upgrade, keep that voltage a bit lower...nice result for air cooling though!
    Apr 2008
    Norway
    I will test my chip what it does with 1,65v tonight
    Jan 2008
    Sweden
    that is just stupid...
    24/7 Setup: Asus maximus x38 / E8500 E0 (500x8) Dtek Fuzion / Ballistix old rev 4-4-4-4 @ 1000MHz / 2900XT Ek fullcover cf / Silverstone TJ-07
    Bench: Commando / Tpower i45 / P5K / E8500 E0 @ http://valid.x86-secret.com/show_oc.php?id=433935 / modded mach2 r507 / Old rev ballistix /
    Jul 2006
    alpena, michigan
    Quote Originally Posted by begrip View Post
    ok you need to look around here and ask yourself. im at xtremesystems witch i would think there are plenty of xtreme benchs and test etc. most people think this is stupid unless your a xtreme overclocker and take risks. the people who are xtreme think its cool but people like you think its stupid. maybe you should goto powderpuffoverclocking.com and post there. and fix you sig cuz ive never seen a BOLT modded motherboard. would you care to show us your BOLT mod please.
    and tharshan way to be man this is xtreme systems and i congratulate you in having the balls to put that much vcore through that chip keep it up man get some cold on the thing
    cpu: 2600k@ 4.5ghz
    mobo: asus p8p67 deluxe
    ram: gskill ripjaw x F3-10666CL7D-8GBXH
    gfx: gigabyte gtx460
    psu:corsair 520hx
    case: antec 900
    cpu cooling: Prolimatech Megahalems Rev.B
    500mhz cas 3 club: http://valid.x86-secret.com/show_oc.php?id=235630
    p4 511 2.8ghz@ 5004mhz :http://valid.x86-secret.com/show_oc.php?id=124434
    p4 541 3.2ghz@ 4909mhz :http://valid.x86-secret.com/show_oc.php?id=157470
  18. #18
    Oct 2006
    Atlanta GA - USA
    wow I didnt even use that much voltage at -80c :p
    Heatware -> http://heatware.com/eval.php?id=51939
    Ebay -> http://myworld.ebay.com/onewhoisplug
    Feel Free to hop in my ventrio server and chat with us
    Vent6.gameservers.com:4498
  19. #19
    May 2005
    [EU] Latvia, Jelgava
    Most of E84 i tested reached 4.7GHz 1m stable with about 1.5-1.55core with air. My best E82 reached 4.65Ghz 1m with 1.52Vcore on air. 1.8Vcore adds more heat than stability at that frequency.
  20. #20
    Jan 2008
    Sweden
    Quote Originally Posted by natedog420 View Post
    Ok. I don't really understand you or your race, but if U wanna get dirty. Talking like you know something. Get the damn info about my motherboard before you open your mouth and release your death breath over me. IF you wanted to see my boltmodd then i will show U, im afraid I don't need beacause there is plenty of people that already done the mod, you know where the search bottom is? you were only a click from it!. http://www.xtremesystems.org/forums/...&postcount=751 was it so hard it took me about 2 min. If you don't call it a boltmodd, and you want to say "heatpipe mod" then it's fine with me, im gonna change my sign again if there is more people that wan't to call it a heatpipe mod.
    Anymore more questions?
    EDIT: I'm not going to watch in this thread anymore and im not coming back to xtremesystems.org, now when i know there is people like natedog420 on this site too, natedog420 if you wanna talk more PM me
  21. #21
    Jun 2005
    just extreme ....
    how much temp under super pi load ? 120 c???
    2600K working in 4.8 GHZ so far
    2600k @(4600 Ghz) 1.42v : (under water)
    Asus B2 mobo
    4 GiG DDR 2400 MHZ
    GTX 570 @ 1.063v ( 910/1820/2001 Mhz) .(under water).
    1020 W PSU
    Hobie's : Overclocking .... Overclocking .... Overclocking
  22. #22
    Apr 2008
    Norway
    I don't really know. But bios showed 67,5c when i booted.
  23. #23
    May 2007
    Athens - Hellas
    1.8V for 4700mhz??
    couldn`t you give less?
    [SIGPIC][/SIGPIC]
