Page 11 of 11 FirstFirst ... 891011
Results 251 to 272 of 272
Thread: 3DMark Vantage score thread
  1. #251
    Jun 2009
    Frenchlick you just beat my score without physx, I can only post the hwbot link: http://www.hwbot.org/result.do?resultId=896870
    can't get at the screenshot right now cause I tried overclocking the gpus just a bit more for another run & my hx1000 psu went kaboom.
    In your earlier run at 701/1168/1512 gpu clocks you still got like 700 more points than me at almost the same clocks while my cpu was at 4620, I'm curious how you managed that? Your memory timings & memory clocks were a bit better but that much diff? http://www.hwbot.org/result.do?resultId=896258
  2. #252
    Jun 2009
    Hi m8, I wouldn't say a 500 point difference is just but have had to vmod the 295s to get the extra boost in score.
    As for the other score it's probably a combination of things, I've done a couple of runs with this cpu at 4.6ghz but have scored less because the cpu just isn't as stable at those clocks yours could be a similar thing. Your also running yours in Vista I'm in windows 7, but I'd try clock ya cpu down to mid 4.5s similar volts and see what you get.
    Edit- my HX1000 is also struggling under the load grabbing an Enermax revo 1250 as soon as I can.
    Took a good look at both scores around the same gpus clocks and seems like ya cpu is getting the score it should be your uncore is running lower than mine maybe that's why I'm not that far off ya there but my gpu score is higher which has to be a vista and windows 7 thing for sure, as only diff was my mem at 1168.
    Evga Classified * Intel Xeon W3550 @ 4.4ghz - 24/7 - Kayl SS @1.34v * 6GB Corsair Doms GT 1866mhz @ 7-8-7-20 * 2 x 5970 *WD 300gb V-Raptor Windows 7 64b - WD 500gb HD Vista * 32"FULL HD LCD * Corsair HX1000 PSU *3dmark06 34005/Vantage 35556* G9 Mouse * Razor Lycosa * Cosmos S Case *
  3. #253
    Jun 2009
    Different OS changes things, I wasn't paying attention that you're using win7.
    I also did the volt mod on the 295s, I was trying 743/1602/1250 at 4.6 ghz when the psu went. I'm planning on getting the enermax galaxy 1250 this week as soon as the $ comes in, I can't stand using this laptop (seemed so fast when I got it, now with the i7 desktop I can't even handle the time it takes this thing to boot...).
    When I can get benching again I'll experiment more with cpu speeds & see what I come up with.
  4. #254
    Oct 2009
    United States
    The system I ran it on:
    i7 920 no OC
    EVGA X58
    6gigs DDR3 1333
    Corsair 1000watt
    WD Velocitor raptor 150
    GTX280
    My scores seem low:
    CPU 41284
    GPU 10688
    Its the GPU when looking at other results seems low. Is there a setting in Vantage I may need to change? I am using the stock settings at the startup of Vantage.
    Thanks,
    Butch
  5. #255
    Xtreme Mentor
    Sep 2007
    Ohio
    Look here...
    http://www.evga.com/forums/tm.asp?m=...55983;�
    A single 280 on a non-OC'ed i7 produces:
    Krackken -------------- i7 920@ 2.66GHz ----- 280 731/1517/1255 ----- P15,661
    depending on what you have your GPU's clock settings at...
    Asus Maximus SE X38 / Lapped Q6600 G0 @ 3.8GHz (L726B397 stock VID=1.224) / 7 Ultimate x64 /EVGA GTX 295 C=650 S=1512 M=1188 (Graphics)/ EVGA GTX 280 C=756 S=1512 M=1296 (PhysX)/ G.SKILL 8GB (4 x 2GB) SDRAM DDR2 1000 (PC2 8000) / Gateway FPD2485W (1920 x 1200 res) / Toughpower 1,000-Watt modular PSU / SilverStone TJ-09 BW / (2) 150 GB Raptor's RAID-0 / (1) Western Digital Caviar 750 GB / LG GGC-H20L (CD, DVD, HD-DVD, and BlueRay Drive) / WaterKegIII Xtreme / D-TEK FuZion CPU, EVGA Hydro Copper 16 GPU, and EK NB S-MAX Acetal Waterblocks / Enzotech Forged Copper CNB-S1L (South Bridge heat sink)
  6. #256
    Aug 2009
    2nd Post, ok. Heres my humble score..
    P12583 | Dani79 | Vista x64 | Q9550 @4.33GHz | Gigabyte GA-P45-UD3P | XFX Radeon HD 4890@1050/1150MHz | 4x1024MB OCZ CL5-5-5-15@1224MHz | Performance |
  7. #257
    Sep 2009
    SLI XFX GTX 260 Black Editions 730/1210/1507
  8. #258
    Jul 2008
    my first run....
    Attached Images Attached Images
  9. #259
    Mar 2009
    my humble 8400@4,5GHz + 5770 @1010/1400
    Need i7 and a second 5770 soon...:P
    8400@4,5GHz 9*500@1,506volts
    DFi X48 T2RS
    BALLISTIX 6400@1200mhz 6-5-6-15@2,1volts
    XFIRED 4850s 1GB 820/1150
    Thermaltake 600rx (aging)
  10. #260
    Xtreme Mentor
    Sep 2007
    Ohio
    A look at most all 200 Series GPU's Performance in Vantage:
    http://www.evga.com/FORUMS/tm.aspx?m=10409
  11. #261
    May 2009
    Croatia->Zagreb
  12. #262
    Aug 2009
    This is one of mine......not super but not too bad I guess
    Intel i7 920@ 4.4ghz , Asus Rampage 2 Extreme , all under sweet EK nickle pron , 6gb Corsair Dominator @ 1683mhz , EVGA gtx 560ti , all wrap up in the new and improved BLACKBOX
  13. #263
    Mar 2009
    Brazil
    Here is mine:
    i7 3930k + Koolance CPU-370 + MCP35X + Black Ice GTX360 + Hailea HC-500A + Alphacool VPP655 || Asus Rampage IV Black Edition + EK-FB Asus R4BE || 4 x4GB Corsair Dominator Platinum 2400C9 || 4x Sapphire HD 7970 OC + Koolance VID-AR797 + RP-452X2 + 2x MCP655-B + 2x Black Ice GTX360 || SSD OCZ Vertex 3 240GB + Agility 3 60GB + WD Caviar Black 2TB + WD VelociRaptor 300GB + 2x Seagate 1.5TB 32MB + Seagate 3TB || 2x Corsair AX1200W || Logitech Z-5500 + G13 + G500s + G930 || Mountain Mods Extended Ascension || Dell U2711 27"
  14. #264
    Feb 2008
    Just a quick tickle with a pair of 8800 GTS 320's http://hwbot.org/result.do?resultId=929185
    Could've done more but win7 is somehow bugged with DWM
    | A hunk of molten metal, plastic and wires |
  15. #265
    May 2009
    Indonesia
    My first post here... Thanks for advice...
    PhysX Off...
    PhysX On...
    Using the latest WHQL driver...
    Intel Core i7 860
    ASUS ROG Maximus III Formula
    Muscle Power DDR3 PC-16000 CL9 2 x 2 GB
    Inno3D iChill GTX275 896 MB GDDR3 448 Bit
    X-Fi Xtreme Gamer Fatal1ty Pro + Gigaworks S750
    WD Caviar Blue 320 GB x 2 (RAID 0)
    Thermalright TRUE Black Rev. C + Cooler Master 90 CFM X 2
    Xigmatek NRP-MC651
    Cooler Master Cosmos S
    Vista Business SP2 32 Bit
  16. #266
    Aug 2009
    Some fun with my new toy....
    [IMG][/IMG]
    EVGA P55 Classified
    i7 860 (today)
    Perfect Storm 2133
    3X 5870
    Megahalem with 1 delta 220cfms
    Navig bench station
  17. #267
    Jul 2008
    single 5850
  18. #268
    Jul 2008
    sorry double post 5850
  19. #269
    Sep 2008
    Boston Ma.
    WarPig1 / by pcnazz aka rocky9mm
    One Asus EAH5970 using 24/7 100% stable clocks .
    Room Temp H20 | sdumper 2 Stage Cascade ( 4-Sale Mint ! ) | i7 975 ES / R2E rev12 v1504 | PH II X6 1090T BE / CH4 v905 | Dominator 2000GT CL8 6gb | Asus GTX 580 X2 SLI | Corsair HX1000 1210w | WD VR Raid 3+0 ( 450gb )
  20. #270
    Aug 2007
    Toon
    Quote Originally Posted by Icebob View Post
    [IMG][/IMG]
    Smells like a Gulftown CPU score to me! I'm getting similar @ 4.5GHz Similar voltage needed to get there too.
    Intel i7 920 C0 @ 3.67GHz
    ASUS 6T Deluxe
    Powercolor 7970 @ 1050/1475
    12GB GSkill Ripjaws
    Antec 850W TruePower Quattro
    50" Full HD PDP
    Red Cosmos 1000
  21. #271
    Jan 2010
    Phoenix AZ USA
    hey guys i try running 3dmark , but it said 3dscore was 0, cpu 40K and gpu was only 7K.
    What i did wrong?
    CPU 920 Apogee XT
    MOBO asus R3E
    RAM G.Skill ripjaws X 2133 @ 1450 6-6-6-12
    GPU Evga gtx 480 850/1686/1936
    HDD 300GB WD raptor
    PSU TX750 corsair
    RAD black ice GTX Xtreme 360 and 240
    PUMP DDC
  22. #272
    Feb 2007
    Denmark
    ATI 4890 mode bios,bot org:cooling whit air.
    [IMG][/IMG]
    an here test whit 10.1 rc2
    [IMG][/IMG]
