edges appear to be normal, and any grit is the sweet spot if you take into account the particle size of the thermal paste your using
K,but i still think the corners are NOT normal...if the surface is completely flat shouldnt the scratches all be even across the whole IHS surface?
I will try tommorow the method i used on 400 grit when i managed to get all scratches even,a bit harder pressure and lapping only in one direction without rotating.
I am now even more confused since I found 2 lapping guides,both had the scratches like mine,only one claimed that the corners are actually flat and that this is a trick of light (optical illusion? ) but the other said it ment the corners are concave.Id be very thankful to hear some more opinions on this,dont want to do an unnecessary re-lap which is possibly not needed at all and risk damaging the cpu.
Thx in advance
Spawne32,thx for your reply,I really appreciate it,Id just like to hear some more opinions if possible.
lol im telling you those corners are the result of hand lapping, it cant be stopped, and its perfectly normal
- You may not post replies
- You may not edit your posts
Forum Rules
