I have recently bought a QX9650.I want some details from you guys on what to expect from it since I am buying the DFI X48 T2R mobo in May.
The FBO/Batch is : L740A489T and it a sealed Retail box,packed in March 2008.
Thanks in advance.
Thanks in advance.
If we're talking 24/7 settings, my bet would be 4.0-4.1 on high end air. 4.2-4.4 with water. Mine does 4.2 on water with 1.44v
i7 3970X @ 4500MHz 1.28v
Asus Rampage IV Extreme
4x4GB Corsair Dominator GT 2133MHz 9-11-10-27
Gigabyte Windforce 7970 OC 3-way Crossfire
Windows 7 Ultimate x64
HK 3.0-MCP655-Phobya 400mm rad
Corsair AX1200i
Sandisk Exrtreme 240GB
3x2TB WD Greens for storage
TT Armor VA8003SWA
you have a batch similar to mine?
That depends on what you mean.
If you're going for sub-zero cooling, like Dry Ice & Liquid Nitrogen, I'd say lay low... as most of those L740s max ( or should I say crap out ) at 5.3x GHz.
On air/watercooling most them ( L740s ) are decent clockers.
Let's say 4.3GHz with a ThermalRight Ultra-120 Extreme is a reachable target.
I'm going with the Thermalright Ultra 120 Extreme
What can one expect on phase?
That also depends on various things.
Your luck, your phase change's performance ( cooling capacity & temps reached ) and what do you mean... 24/7 stability ? benching ?
can the people that post here tell us please their Batch code too?Thanks in advance.
Has anyone bought their CPU from the person that sells them on ebay for 800$ buy it now ! price?
I have bought a 740B159 from Ebay but I specifically requested the batch nr and a picture of the CPU (to verify the wafer nr too) till now a good CPU3.6ghz at 1.15Volts and 4ghz at 1.26V daily... way better results then my retail one lol
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro Asus Saaya yupp, I agree
EVGA Classified (MSI XPower), 980X (i5 661, i5 680, i7 950, E8600, QX9650, E8400), Thermalright Venomous X , Kingston Hyper X 2000Mhz, MSI 480GTX (5870, 4870x2, Visiontek 3870 x2, XFX 8800GT w/HR03GT), DELL E248WFP, CM Silent Power Pro 1000W, Seagate 1TB + 1TB + 500GB+500GB, Auzentech X-Plosion, CM Bench Station, AL 641, MX 518, New G15 Keyboard
Ends with a "T"!
It seems those ones are special..
i7 3770k - p8z77-v pro - 4x4gb - gtx680 - vertex 4 256gb - ax750
i5 3570k - z77-pro3 - 2x4gb - arc-1231ml - 12x2tb wdgp r6 - cx400
heatware
mine ends with a T too,haven't tested it yet...hope it is good
I have a L740A931T, packdate in late December '07. 4GHz @ 1.25V, have not gone higher as my cooling is somewhat poor.
QX9650 L740A 4GHz @ 1.25V aircooled
8GB Team Dark DDR2-1066 @ 5-5-4-15 @ 2.00V
Asus P5E 1.41V vNB
GTX280 1GB 600/1450/1200
WD Raptor 150GB + 2*500GB WD
Pioneer 212D
Corsair HX620
Antec P182
Dell 2407
any more users that can share their batch?What does that T really mean?
I've got a L744B163 01/23/08 retail and its pretty mediocre compared to some around here. I can get 3.6GHz (9X400) @ ~1.26V (still testing for lower Vcore) but need 1.34V to reach 3.8GHz (9.5x400). Voltages are what's displayed in the BIOS/Everest, not what I actually set.
3.6GHz @ 1.26V <<<< 3.6GHz @ 1.40V which is what my x6800 needed.
QX 9650 | Maximus II Formula | G.SKILL 4GB (2 x 2GB) PC2 8500 | Sapphire 4850 X2 2GB| Auzen X-Fi Prelude 7.1 | 3x's WD 150GB Raptors & 2x's 1TB Seagate 7200.11 | Silverstone OP1200 | SilverStone TJ07 | Dell 2707WFP
EK-RES 250 --> Swiftech MCP655 --> Apogee GTZ --> Enzotech Sapphire NB --> Feser X-Changer 360
Got the chance to quickly test a QX9770 L 803B248 ( C1 stepping) yesterday... was 3.6GHz stable at 1.2volts, 4ghz needed 1.32volts ot be OCCT 2.0 stable... heat output wasn't an issue with the Wc setup though was 5-8°C more than my Qx9650... I really wonder where the extra cash goes into, are the new Qx97's beter resistant to abuse or what ? FSB was also around 470 maxed out... so no real improvement there on my board...
any speculations like at what voltage I could reach 4ghz stable?
Prolly in between 1.25-1.4 volts, if it can do eg 3.6 at 1.15volts then you are well on ya way to stay below 1.3volts for 4ghz...
Talking voltages under load here, not bios voltages, m P5K Dlx needs to be set at 1.2volts to do 1.15 under load (with laodlien calib enabled)
IT really varies. Good chips will take 1.3v or less, but I've seen 1.4-1.5v for 4ghz on a couple. MY L739"T" takes 1.272 for 4ghz.
Mine is a L739B880 I have to set it on 1.45 in the bios to get 3.9Ghz prime stable...
has anyone found out what is with these 'T' chips?Are they more special or...?
General word for T CPU's is that they seem to clock pretty good ( 4ghz around 1.25Vcore level), maybe T stands for Turbo lol
I have tested this P5K DLx for over hours now with different settings Touge, and have yet to see a spike... with the QX9770 I saw some ripples in the Vcore though nothing major... Qx9650 seems pretty flat...
Both CPU's tested at 3.6Ghz for a quick comparison (QX9770 test was interrupted after 40 mins):
At first the QX9770 was crashing with anything lower than 1.22volts at 3.6ghz, though after a night of folding I completed a few OCCT ( dunno why but it were OCCT1.0 runs so no voltage readouts) tests at only 1.2volts, do these CPU's need a burn in again ?
I know Anandtech doesn't recommend LLC but I think if you got a good mobo and good PSU then you will be fine... apparently they have found out that it seems to be CPU VTT that kills these CPU's if set too high (mine is always set at 1.3)
That's good to hear. When I was testing with LLC enabled I didn't see any ripples at all but I thought that maybe the sample rate that OCCT uses might not be fast enough to catch them. When testing w/ no LLC I did see some ripples reported by OCCT
@Coolzone
I have no idea about this mythical "T". I'm just mad that I didn't get one.
