wow sky that is like exactly what I want !! I am very interested in phase change but at the same time kinda scared about trying to make my own res insulate everything etc.
and vapo units are hella pricey
Intel D975XBX -304
Intel Core 2 Duo E6300 1.86 @ 2.350 ghz
2gb (1gb x 2) PQI Turbo
2 X BFG 3D Fuzion 7600GT SLI
Gigabyte 3D RocketPro cooler
Antec True power 550
Great guide! But I do have a few questions which maybe you should add in there
What's the difference as far as OC performance between a chiller and just straight water? You should do a comparison as far as explaining what exactly a chiller is used for and the differences between just straight water. This is coming from someone who knows nothing, which is who the guide is aimed at. All I know is that chiller is colder.
.:: S939 FX-53 (240x11 1:1) | 2x512 Ballistix DDR400 (2.5-3-2-10) | MSI K8N Neo2 Platinum (1.36b) | x800 Pro VIVO -> XT (575/590) | 21" Viewsonic G220fb | Lian Li PC75b ::.
Aquamark 3 : 84367
3DMark 2001 : 31717
3DMark 2003 : 14313
3DMark 2005 : 6580
Coming Soon : Silverprop HL Fusion (GPU), S-TDX (CPU), Weapon 2-302 Heatercore / Shroud, 50Z, Aquatube (special thanks to MaxxxRacer & Ancient_1) | UV / Case organization
Coming when I can afford it : Vapochill LS or Mach 2 GT for CPU | FX-55
this is kind of hard to figure out without pictures
new benching rig
mobo: dfi ultra-d rev. AD0
cpu: x2 3800+ @ 3.30 ghz
cooling: VapoLi SS by jinu117
stepping: LDBHE 0601 TPMW
mem: khx pc3200 1gig bh5's
psu: zippy emac 700watts
gfx: evga 7800gt @ 650/1355
hd: 36gb raptor + seagate 120gb
single 7800gt 3dmark05 WR!
3dmark05 - 10814
so basically what this is, is just adding a evaporator and radiator from an air conditioning unit to your current w/c setup am i right
im a begginer btw and am looking at OCing my intel 3.2GHZ cpu to 4.1 and keeping my EVGA 6800 Ultra nice and chilly, so i can overclock it later(i hpe to go to 475 or higher maybe im not too sure.)
here is the liquid setup i most likley will go with.
Swiftech MC650 pump
Tygon 1/2 ID tubing
Swiftech-Bay-Res
Hardware Labs Ice Extreame 2 mounted externally with swiftech radbox
Dangerden TDX cpu block (478 socket one)
Here is a thread somewhere else with some pictures showing the process. Go here
Excuse my noobiness but wouldnt the cost of running a chiller 24/7 be alot?
its equvilivent to the cost of running an air conditioning unit rite?
also, the AC unit being discussed is a standard room window ac or a special size
Ali
