Goal is to do something like this:
The first of many mods. It's late so I'll get into detail later:
Still need to drill out the remaining mounting holes. Didn't fit as well as I anticipated, even after measuring everything three times.![]()
i7 3770k - p8z77-v pro - 4x4gb - gtx680 - vertex 4 256gb - ax750
i5 3570k - z77-pro3 - 2x4gb - arc-1231ml - 12x2tb wdgp r6 - cx400
heatware
NiceI moved my PSU into the 5.25 bays and then I cut off the face plate and ran the AC cable to the 5.25 bays.
Main - for now:
Celeron @ 2500 MHz/
1 GB DDR 400/
Intel/
40 GB, 80 GB, 120 GB
eMac - OCing soon:
PPC G4 @ 1.25 GHz/
1.5 GB DDR/
Radeon 9200/
40 GB Leopard
Win Web Server:
2x Opteron @ 2000 GHz/
512 MB ECC DDR/
3D Rage/
Needs fixin'
Linux Web Server:
Pentium III @ 1200 MHz
256 MB PC133/
Intel/
40 GB Arch Linux
Yeah I saw your post and considered it but don't want the PSU dumping heat into the case along with the PA120.3
This case is slightly "off" in pretty much every way that I need it...
PA160 won't fit in the bottom front without modding
PSU doesn't fit at the top without modding
Almost no space behind the mobo tray for wires
"Front panel" connectors on the top
Wire fan grilles on the inside of the fan, stamped metal grill for the outside
Huge open grilles stamped into the case (for front fan), restrictive intake holes next to PCI slots and on front bezel
Eventual plan is to:
Wind tunnel PA120.3 in the bottom (we'll see how feasible this is)
Soft mount HDD in 5.25" bays
Find some nice feet
Try to cram a PA160 in there too
heatware
Back to the traditional PSU at the top!
Borrowing someone else's mod, I also took out my drill to bore the holes larger.
heatware
Why did you drill the holes larger?
Why is it drug addicts and computer afficionados are both called users?
| AMD Phenom II X6 & Xigmatek Dark Knight
| ASUS M4A89GTD PRO
| Sapphire HD 5770 1GB
| Mushkin BL 2 x 2GB
| WD Caviar Black 1TB
| Corsair TX650
| Lian Li PC-K7 Black
Main - for now:
Celeron @ 2500 MHz/
1 GB DDR 400/
Intel/
eMac - OCing soon:
PPC G4 @ 1.25 GHz/
1.5 GB DDR/
Radeon 9200/
40 GB Leopard
Win Web Server:
512 MB ECC DDR/
3D Rage/
Needs fixin'
Linux Web Server:
256 MB PC133/
Intel/
40 GB Arch Linux
Oh nvm. I dunno what I was thinking, I thought you meant the 120mm fan holes.
If you don't mind me asking, how much space is behind the motherboard tray and is there enough room to modify the rear for a 140mm fan instead of a 120mm?
| ASUS M4A89GTD PRO
| Mushkin BL 2 x 2GB
| WD Caviar Black 1TB
| Corsair TX650
| Lian Li PC-K7 Black
No chance for a 140mm.
FREEDOM ISN'T FREE
Cruncher Support:
Utnorris
DarthBeavis
DEFRANCO NATION
_____________
E6750@ 3.0ghz- evga 750i FTW- 320gb- Swiftech MCR220 compact- 8800gts 512mb KO- 620hx - 4gb Crucial 1066- CM 690- 6 yate loons
E6600- Asus striker Extreme-2 x 750gb- Igloo 5710- 8800gt- antec 850w Quatro- 4gb DDR2 800- Antec 1200- 24/7 cruncher
**Wishes for a dual- quad core cruncher**
There is pretty much no room behind the motherboard tray. At most, there's 3/8" of space there.
Finally some more time to work on this case:
Drilled holes to flip the 3.5" drive cage:
Cut the fan holes for the PA120.3 rad with a jigsaw:
It was hard to drill the mounting holes due to the existing vent holes in the bottom of the caseIt's OK though. I still need to drill them larger and cut more of the holes for when I end up getting the stupid fan grille. I can't find one for a 120.3.
Also some other small things:
- Drilled out the last screw mount for the PSU
- Began cutting out the stock PSU hole to fit a 120mm fan. It came out rather horrible so I need to touch it up with some filing and drill out the holes to mount the fan.
heatware
LOL @ waterfish.
Thats like saying a Land Elephant.
Anyhow nice project keep the pictures coming!
Nadeshiko: i7 990 12GB DDR3 eVGA Classified *In Testing... Jealous?*
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
:P
Reusing part of the case on itself:
heatware
Can I ask why you didn't keep the PSU in the bottom and the rad up top exhausting hot air upwards? Fitment issues?
Custom black murderbox
QX6700 Quad Core
eVGA Nforce 680I SLI A1
2x eVGA e-Geforce 8800 GTX SC
2GB Corsair 9136C5DF 1142 Mhz
PP&C 750 Watt Sli PSU
2x Raptor 150GB + 75GB
Ek Waterblocks (Gfx, CPU, Chipset, Resevoir)
MCP655 Pump / Variable Speed
Thermalchill PA120.3 & PA120.2
Custom Silverstone TJ-07 case
e8500 8x500 1.55v
ga-p35-ds3p
crucial ballistix 2x2gb
seagate 7200.10 3x320 raid0
xfx 8800gts
st75f 750w
li-lian rocketfish
fuzion...dd d5...pa120.3
heatware
Whys is that radiator that thick?
I really liked the black fluid and the ways hoses are connected.
A also think you should put that T in other way, so that the flow goes straight to the cpu block instead of going straight to the unconnected hose
nice project man!
Sony Vaio VPCSA35GX while 7Mm away from home... Back at home:
C2Q QX6850 3Ghz@3.4Ghz - P35C-DS3R
XFX GT220 - 2x2Gb OCZ PC9200@1004 5-5-5-15
3X500Gb + 64Gb - Case Thermaltake V-3 Black Edition
AC F7 Pro + TR HR-05
Crappiest thing just happened. I hook up the PSU and it won't frigging turn on !!!!!!!!!!!!!!!!!!!!!!!!
Argh
heatware
OK there goes that. I toss in a different CPU and I see a little whiff of smoke come out from the top MOSFET area. The setup worked fine when it was sitting on my desk!
I'm pissed! 5 hours of work gone down the drain!!
heatware
Ouch! I feel your pain.
That sucks.
Dang man. All that work. Think it's just a matter of Mobo? or are you thinking PSU, Mobo, and CPU?
Thermaltake Armor Series Black
GIGABYTE GA-P35-DS3R
Q6600 3.6 GHZ Thermalright Ultra 120 eXtreme
4 GB Corsair XMS2 w/ OCZ XTX Ram Cooler 2 x 60mm
9800GT 512MB
18X Pioneer DVD-RW Burner
720 Watt Enermax Infiniti
4x640GB RAID 10
Windows 7
I'm hoping ASUS RMA is fast.
In the mean time, I've done this:
Parts:
Asus P5E-VM HDMI w/EK NB Block (from my dead Maxmius)
X3350 w/FuZion+Quad nozzle
8800GTX w/EK FC block
PA120.3+Shroud+SFlexF@5V
DDC3.2 w/Petra Top@7V
Needed to run my pump at full speed to get this sucker to bleed due to the changed loop layout -- the NB is closer to the GPU on this board
Did the pencil vdroop mod so now I get 1.344V load at 1.3875V BIOS set rather than 1.3360V load at 1.5250V BIOS set.
Just need to toss my X-Fi in there and I'm almost done...
Remaining on my priority/to do list:
- Find some case feet! I'm propping it up on two 120mm fans right now![]()
- Fan controller
- Dampen case with vinyl + foam
- Dampen HDD noise -- going to try modding my Scythe Quiet Drives
- Possibly swap back to my Enermax Modu82+ for higher efficiency -- 8800GTX sucks up a lot
- Tidy wires up -- zip ties, cable runners, whatever I can find.
- Possibly trade my 8800GTX for 8800GTS512MB + FC.. I have the card, just trying to convince myself to buy another FC block.
- Paint the interior black?
- Change out to DTEK DB-1 pump
heatware
Sorry dude, that really sucks. The M-ATX board looks hilarious in there.
