Hello,
i have a huge problem with my maximizer.
Board is a Asus Commando with two D9GMH 1024 sticks.
In cases, where the maximizer voltage is lower then the board vdimm voltage.... all is fine.... display shows the right voltage of the board.
but when i start raise the vdimm with the small switches (over the vdimm of the board) my maximizer will become very very hot.... i think the hot spot is in the left corner in the back.
I can not check, if the voltages of the maximizer are shown correct in the BIOS hardware monitor, because the maximizer will become untouchable hot in the first 20s after startup the system... so i better shut down the system again. Will not destroy the device.
So where is the mistake?
Is the device broken or are there just mistakes in handling? (Dont think so!)
I think i should not lift up one leg of the VDimm coil.
I hope you understand my problem.... and can help me....
Settings:
DDR2 Mode
VDIMM in display
VTT on
adjust via small switches...
KIND REGARDS Loopy
