+ Reply to Thread
Results 1 to 15 of 15
Thread: Extending wires on fans...?
    Xtreme Enthusiast Jsunn's Avatar
    Jul 2007
    In my home.
    1
    Hello All,
    Quick question, I want to extend the wires on my yate loon fan to better reach my fan controller. I am going to be slicing/soldering 22 gauge wire to make them longer. Is there anything that I need to be aware of before I undertake this seemingly simple task?
    Thanks for your help.
    -Jason
    Core 2 Quad Q9650 @ 4.00Ghz 1.3375(v) F9 BIOS
    2 X 2 GB DDR2 1100 @ 1000 G.Skill PC2-8800
    2 X 500gb GB SATA 2 HD RAID 0
    Gigabyte GA-EP45-UD3P
    EVGA GTX285 SSC
    EVGA 8800GTS G92 PhysX
    My 3DMark Vantage Score 16,444
    Pics of my computer
    Xtreme Member Junimrox's Avatar
    Jan 2008
    Flint, MI
    0
    no, just do it! (no nike advertising)
    Sony Vaio VPCSA35GX while 7Mm away from home... Back at home:
    C2Q QX6850 3Ghz@3.4Ghz - P35C-DS3R
    XFX GT220 - 2x2Gb OCZ PC9200@1004 5-5-5-15
    3X500Gb + 64Gb - Case Thermaltake V-3 Black Edition
    AC F7 Pro + TR HR-05
    Xtreme Addict RADCOM's Avatar
    Oct 2004
    London UK
    10
    nah straight forward job..... or you can buy a fan wire extention for a couple of pounds/dollars
    http://www.coolerguys.com/840556000013.html
    Respec'
    System:Bunch of crappy overclocked PC's that cost an arm and a leg
    "A Caesarean Milks Stops Wort"-anagram
    Wanna Pull My Finger? fart_plume's Avatar
    Sep 2007
    Oklahoma
    0
    I do it all the time, in fact I often rip fans out of dead psu's and use them and a lot of those have no plugs on them.
    Donate to Xtreme Systems!
    Now Showing:
    Gigabyte x48-DQ6, Q6600,OCZ 1066 Reapers,2 750gb seagate 7200.11 hd, BFG 8800GTS 512,PC P&C 750 Quad psu, 24" Sceptre lcd, Antec 900
    my wife's system now!
    Intel C2D 6400, Zotac Matx mobo, 1gb kingston mem, Nvidia 7050, I Feel really Good now!
    Jon C2D 6600 Zotac mobo 1gb mem............................................... ................. HTPC qx6700@3.0ghz
    Annabelle Amd 3800+@2.4ghz, Biostar mobo, 1gb ocz pc4500 beta's................. Optyx2 opty165@ 2.1 ghz
    'Want a real high?
    Come crunch WCG and you'll feel like your on QuadCaine"
    First loops are like first sex, all hands and thumbs till you figure out what goes where, then it's what ever works best for you.
    Jul 2007
    In my home.
    1
    Cool, I am going to make the fan cables the exact length that I need. I am getting a MM UFO case so I want to try and hide the fan cables as best as possible.
    -Jason
    EVGA GTX285 SSC
    Pics of my computer
    Registered User Got_Vtec?'s Avatar
    Mar 2008
    NJ
    0
    hey jsunn i was just wondering what color wire are you going to use....can any type of wire be used to extend the fan cables??.....when you say extend them you mean splice and connect or are you making a whole new wire (hence the soldering)....sorry for all the questions this stuff is rather new to me
    Jul 2007
    In my home.
    1
    I am just using 22 gauge bloack colord wire. It is stranded, not solid. I am going to be cutting them and inserting a length of 22 gauge wire to make them the length that I need.
    I will post some pics when order my case (hopefully this weekend)
    -Jason
    EVGA GTX285 SSC
    Pics of my computer
    Registered User alexey's Avatar
    Mar 2007
    Romania
    0
    Just be sure to isolate the cables with isolating band so they don't make any contact with the case or any other metal parts in the case to avoid short circuit
    Xtreme Cruncher [XC] NetburstXE's Avatar
    Feb 2008
    C:\WINDOWS\system32\
    0
    Quote Originally Posted by alexey View Post
    Electrical tape is what I use when I extend fan leads. Works fine for me every time.
    Mar 2007
    Romania
    0
    Quote Originally Posted by netburst View Post
    Yes...that's it.I didn't know exactly how it was called in english
    Jul 2007
    In my home.
    1
    I'll be using heat shrink. I will also be sleeving all of the wires also.
    EVGA GTX285 SSC
    Pics of my computer
    Registered User Dimarini's Avatar
    Mar 2008
    Pflugerville, TX USA
    0
    I use heat shrink and then sleeving over that. I agree it makes a much cleaner looking case.
    Feb 2007
    0
    If you want to match the colors, here is a place that sell all the colors in 25" rolls.
    http://www.hobbyengineering.com/Sect...html#CatSPW22M
    Frozencpu also sells it by the foot.
    http://www.frozencpu.com/cat/l3/g44/...ire-Page1.html
    Xtreme Enthusiast Lu(ky's Avatar
    Jun 2007
    Long Beach, CA
    2
    Not sure if you need a 3 pin version? You can find it here they are 3ft long for $3.99... www.mnpctech.com
    CPU: Intel Core i7-3770K 4.8GHz
    MOBO: ASUS P8Z77-I Deluxe Mini ITX 1155
    MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31
    GPU: eVGA GTX 690 Signature
    SOUND M-AUDIO Studiophile AV 40
    SSD: 2 x Samsung 128GB Pro's Raid 0
    PSU: SeaSonic Platinum 860W
    COOLING:Phobya XTREME 200 & Phobya XTREME QUAD 480 radiators
    CASE: Lian Li PC-V354B build log coming soon
    MONITOR: ASUS VG278HE Black 27" 149Hz
    O.S: Windows 7 Pro x64
    Xtreme Cruncher karl_eller's Avatar
    Nov 2007
    Newcastle, Australia
    0
    Snip, solder, heatshrink, done. It really is that simple I wired up the 3 fans for my Radiator that way, and I'm going to be re-doing all the other fans in my case using the same method.
    Quote Originally Posted by Lu(ky View Post
    No need for that. Just re-solder on one of the many spare 3-pin plugs you'll now have lying around Sure, it's a very DIY-handyman approach, but it's just a fan, so the slight extra resistance won't matter.
    Eller
    Desktop: Q6600 G0 @ 3.6 Ghz | P5E | 2x2 Gb G.Skill PC8000 | GTX 560 Ti | CM690 | TT TP 750 watt | Win 7 Pro x64 | Water Cooling
    Server: i3 530 (Stock) | CM Vortex Low-Profile | Zotac H55-ITX WIFI | 2x2Gb Corsair 1333Mhz | IGP | VX450 | Server 2008 R2 x64
+ Reply to Thread
