Hi this is my first post in this excellent forum. I have not been an active overclocker for many years but have as of lately gotten interested in cooling again.
I have read a few threads here about TECs and I notice a lot of people think they they are of little use (reffering to the "Is T.E.C. Dead?" thread).
I have made a quick sketch (in paint, hehe) to show one way in which to use TECs focusing on their strong points:
No noise
Small size
While trying to minimize the weak points (compared to phase change mostly):
Low to horrible COP, Coeffecient of performance
COP= Q/Pin
Q energy in at coldside
Pin = Electrical energy draw
At the hotside of a TEC the energy dumped will be Q+Pin.
It is of some importance to maintain decent COP within you cooling solution. The final heatsink/radiator will grow larger/louder the worse our COP gets, given a wattage to cool.
The more heat you dump on your rad/sink the warmer it gets, as does you CPU as a result.
How to achieve decent COPs with TECs.
Low heatflow density, which means low amount of energy transported per TEC.
Low temperature difference between hotside and coldside.
If you translate that into application you need to use a large nr of peltiers to spread the heatload and run them at low voltages to keep temperature difference (and power consumption) down.
Now from another viewpoint, the one which I started from. How do I cool my computer passivly and effectivly. The size of a heatsink needed to passivly cool a quad to 10-20 degrees above ambient would not be practical.
To more you want to convect from a heatsink passivly the larger the heatsink or the higher the temperature of the heatsink. This is where the TEC comes in. The TEC will be able to push more heat through a smaller heatsink by raising its temperature. This will benefit a passive heatradiation and passive convection cooling solution more then a solution based on forced convection. The beauty of passive cooling is that it has a C/W that goes down as the temperature of the rad/sink goes up. It is true for forced convection cooling too, but it happens at lower temperature for passive cooling. Think of heat radiators in houses they can move 2000W through passive convection, thats what happens when size and temperature difference to ambient goes up. We need less then that, I am shooting for a COP of 0.5 or higher Which means I would dump approx 3 times the heat of the CPU into the passive rad.
The reason for me posting this i because I want someone to build it to see how well it works when implented.
I have gone on long enough now. I hope some interest has been sparked with this post. Questions and suggestions are welcome.
