+ Reply to Thread
Results 1 to 5 of 5
Thread: Stupid idea??
    Registered User vwfix's Avatar
    Feb 2008
    east Bay, CA
    0
    Stupid idea??
    has anyone tried using a very powerful TEC and cooling it with dry ice will this produce colder temps then just dry ice on its own?
    E6600/ G.SKILL 4GB DDR2 1000/ GIGABYTE GA-EP35-DS3R/ CM Stacker STC-T01
    Cooled with EK supreme cpu block/ D-5 pump/ MCR220 Rad.
    Xtreme Mentor Nate P.'s Avatar
    Sep 2007
    Monterey Bay, Calif.
    0
    Bump, because I'm wondering too.
    Xtreme Cruncher Polizei's Avatar
    Nov 2006
    'burb of Cleveland, Ohio
    1
    You need to get a TEC that's designed to operate with its hot side at -70c, which are very large TEC in terms of area (like 80x80mm) and cost ($200). Very inefficient too.
    NoL told me a couple days ago when we talked about this, that a TEC that could move 250w @ -10c hot side would draw like 580w, meaning the dry ice or LN2 tube would have to be able to handle more than that.
    Xtreme Member Sam__'s Avatar
    Oct 2007
    0
    580W is a lot... im interested as to how much heat DI or LN2 can deal with.
    also.. powering 580W would cost a LOT! for the PSU.
    "Computers in the future may weigh no more than 1.5 tons."
    - Popular Mechanics, 1949
    "I think there is a world market for maybe five computers."
    - Thomas Watson, chairman of IBM, 1943
    Heat
    Jun 2007
    0
    I've never officially done any subzero benching, but I did make a DI/TEC container (for soda actually ) to test if it could get any colder. Unfortunately, the best physical probe I have access to ATM only goes to -50C, which DI + 99% rubbing alcohol reaches easily. However, even after the pelt ($5 eBay special) is cooled down to ~-75C (isopropanol becoming syrupy), it still pulls the same max amps my poor old PSU can give. From what I can tell, it does make the cold plate even colder, but not too noticeably uninsulated. I'll get some pics sometime.
+ Reply to Thread
