Results 1 to 22 of 22
Thread: Crucial Ballistix: best batch?
    Dec 2004
    Belgium
    I've bought some kits of Crucial Ballistix DIMM Kit 2x 1 GB PC2-6400U (BL2KIT12864AA804) @ different locations and received 16FD3 + 16FD5.
    The 16FD3 is second hand, has the old heatspreader with clips and is double sided. (CL1117V.87 - 72596)
    The 16FD5 is brand new, has a new heatspreader without clips and as far as I can see without opening the box also double sided. (CL1118F.3F - 97532)
    I'm still expecting 1 kit but it should also be 16FD5 as of what I've heard from other recent buyers from that shop.
    I'm planning to keep only 1 kit (the best 1 ) and sell the others.
    Is 1 batch superior to the other? Or are the results pretty equal?
    Should I test the new kit (loses value when opened) to be sure?
    Intel C2D E8400 -|- Thermalright Ultima-90 -|- Asus Maximus Formula X38 -|- Crucial Ballistix 2x1 Gb PC2-6400 (4-4-4-12) /~\ Gainward Bliss 8800 GT 512 MB -|- Samsung 930BF 19" TFT /~\ Stacker 831 Black -|- Corsair HX620 /~\ 3 TB -> WD Raptor 74 Gb -|- Samsung 3x 500 Gb + 4x 400 Gb
    Memory Addict
    Aug 2002
    Brisbane, Australia
    From my experience best kit for one motherboard might not be best for another motherboard hence I keep a few kits around and see which is best for the motherboard I'm working with
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by *Mercenary* View Post
    newer 2 sided no clips require less volts 2.1v=1200+
    some older ones have d9gkx
    i got 6 stix of d9gmh 2 stix of d9gkx i not sellin none
    they all mine all mine i'm an eva2000 wanna be
    hard to find the good stuff for a fair price now never know what you gonna get if you rma them
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    I'm doing it like eva2000 and zsamz_, I won't part with any of my kits... *evillaugh*
    Just keep all of them!
    Well, I think there are differences even in the same batch, so I would test all of them. My bet is on the newer ones though, maybe you can post some of your results, I would appreciate that very much!
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
    Nov 2007
    Canada, ON
    On my X38 motherboard, the 16FD5 batch seems to perform extremely well CAS4 and CAS5 is cake walk for DDR1200
    Feb 2008
    I had 16FD3 and they were good to 1175 5-5-5-15 2.2 and up to 970 4-4-4-8 2.35, but the voltage killed one of the sticks within a few months. I was running them 24/7 900 4-4-4-8 2.3v
    Hardware:
    DFI LT P35-T2R
    Intel Xeon 3210 G0 Quad
    Team Xtreem PC6400
    Radeon HD3870
    Corsair HX520
    2x75GB Raptors RAID-0
    Cooling:
    D-Tek Fuzion w/ quad nozzle
    Swiftech MCR320 w/3x120mm 70cfm Yates
    Swiftech MCP655
    1/2 tubing
    Noctua NC-U6 on NB
    75mm 6000RPM server fan on RAM
    Windows XP Pro SP2
    Sep 2007
    The Netherlands
    Crucial Ballistix
    OVERCLOCK TEAM HOLLAND
    http://www.overclocking-holland.nl/
    Dec 2007
    Crucial Ballistix
    Goggle "Crucial Ballistix 8FE5 trouble" or something similar. Many people (including me) are having trouble with this newer version.
    Feb 2007
    Hong Kong
    my 16FD3
    Dec 2005
    Northern Virginia
    stephen23: what voltage is that? i can't read it...
    I have some 16FD5, and it does alright. DDR2-1300 at 2.3v, 5-5-5-15.
    The Ballistix Lanfest is 16FD0? and it clocks about the same.
    Computer:
    Case: Corsair 750D Airflow Edition
    Mobo: Gigabyte Aorus X570 Ultra
    RAM: Team TForce Xtreem ARGB 3600C14 2x16gb XMP
    CPU: AMD Ryzen 5900x
    Graphics: EVGA (rip) RTX 3080 FTW3
    PSU: Seasonic Focus GX 850w
    Cooling: Arctic Liquid Freezer II 360mm
    NVMe: SKHynix P41 Platinum, Samsung 980 Pro 2tb
    SSD: Micron 1100 2TB, Samsung 860 Evo 1tb
    HDD: WD SE 2TB, WD Black 1tb 3 platter with over 10 years of power-on time
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by Foodspice View Post
    Crucial Ballistix
    if you see chips only on 1 side run lol
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    Aug 2006
    Oxford, UK
    I have a set of clipless ones, 5300 667mhz kit revision FD4....had them 1178 5,5,4,13 2.2v so far...not tried for more. Currently running 900mhz 2.16v 4,4,3,8
    || 2500K @ 5GHz 1 thread, 4.8 2 threads, 4.7 3, 4.6 4 1.284V ||
    || P8P67-M Pro || 8GB @ 2133MHz ||
    || 5850 @ 1000/1225 || XFX 650W || Silverstone FT03B ||
    || 37" LCD TV || CM Hyper 212+ || Samsung 2.1 Soundbar ||
    Feb 2007
    Hong Kong
    Quote Originally Posted by breakfromyou View Post
    DDR1200 CL5@1.95V
    DDR1200 CL4@2.55V
    Nov 2007
    I have 2 sets of Balistix DDR2-1066. 1 set is 16FD3 the second is 16FD5. They both run great 1 set at a time. When I try to run all 4 sticks seems like all hell breaks loose. They just dont play well together I guess.
    They both run fine @ 5-4-4-8 @ 2.2v.
    Has anyone else had problems running these 2 batchs/revisions together?
    Wow and this is my first post!!!
    Nov 2002
    Brazil
    Crucial Ballistix
    Wow thanks for the tip... I spent several days trying to make this sh1t to work.... No luck!!!
    Intel E8500 Q813A248; Asus Rampage X48; TRUE 120; 2x1GB Mushkin XP2-8500; EVGA 8800GTS 512MB; 2x320GB Hitachi P7K500 Raid 0; Zeus 850W; Lian Li PC-60BPlus; Samsung 226BW; Saytek Eclipse; Logitech G9
    Xtreme Mentor
    Feb 2008
    It seems that Crucial are in a spot of bother atm.
    I really hoped that they could continue their previous double sided chips and ditch the new single sided ones on their 2x1 Gb kits, and I was also expecting great results from their 2x2 Gb sets.
    Oh well, never had cruacial Ram myself anyway.
    Nov 2007
    Canada
    this is an outrage. I am an unfortunate victim of the 8FE5's and they can't clock to anything past 1100mhz.
    Every review out there claims these sticks can hit 1200mhz without a sweat, yet not ONE review stated the difference between the 8FE5's and the 16's.
    It's a good thing i got these at a retailer with good return policy, because these are going right back to the store tomorrow.
    What a total letdown. I almost feel like I have to retreat back to OCZ to get something worth out of my rampage
    q9550 e0 4.1ghz
    Corsair H100 Mx-3 + TriCool
    Asus Rampage Formula R4 BIOS
    Sapphire 7970 3gb Dual x OC 1200/1700 (reference) re-pasted MX-3
    CM Cosmos S RC-1100 w/6 TriCools
    4xOCZ2G10662G (8gb DDR2 RAM)
    Corsair AX1200 PSU
    SB X-Fi Extreme Audio PCIE w/Z-5500's +Corsair Vengeance 2000
    G15 rev2 + G13 + G9x
    GOT RAMPAGE?
    CHECK FOR MEMORY ISSUES
  18. #18
    Dave's Mentor!
    May 2007
    montreal
    my 16fd5 2.09v=1200 2.24v=1300
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  19. #19
    Nov 2007
    ohio
    i have a maximus x38. i have had nothing but trouble out of crucial ram. i originally bought the special edition lanfest when neweeg had them. on my p35 board they were good ram 1100+mhz, but on my x38 i couldnt even get them to 1066 stable. eventually the got to where they wouldnt post at anything less than 2.3 volts.
    sent the lanfest in for rma, and crucial sent back single sided tracers that are complete junk. if i try them in my maximus at default after clearing my cmos i get detdram hang. they take 2.2 volts just to run 5-5-5-15 at 800mhz.
    if i put the single sided tracers in my p35 i can get 1050mhz. i think i'm going to rma these back again.
    on a side note, i bought one of the last sets of transcend axeram 1200mhz and they freaking rule. granted they dont overclock alot, but easy 1240mhz at 2.25volts. running this ram is like a whole new rig. before the bios settings were very touchy. 1 wrong setting and it would either hang at detdram, or nuke my boot sector and require a fresh windows install. since getting these axe's i've had 0 problems with this rig.
    2600k @ 5.0, msi z68-gd65, evga gtx 470, 4x2gig Mushkin Redline 1886, 3x74gig raptors in raid0, pa120.3 push/pull, d5, swiftech apogee HD
  20. #20
    Champion
    Jan 2007
    Romania, lab501.ro
    Maximus really doesn't get along with Crucials, in fact...it doesn't get along with DDR2 generally speaking. It is not the rams fault, the chipset (X38) is more likely to run properly with DDR3 that DDR2.
    Weissbier - breakfast of champions
  21. #21
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by Monstru View Post
    sounds more like bios needs optimising for crucials more likely ?
  22. #22
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    IN one big huge way, Eva...
