Results 1 to 6 of 6
Thread: Max safe Vcore on water?
    Jul 2007
    uk
    i currently have my Vcore set to 1.58v to get 3.8ghz on my E6600, orthos with small Tft's temp hits 55c is this ok for 24/7 use?
    Thanks,
    Chris.
    X58A-UD3R
    920 @ 4.1ghz
    6gig OCZ
    1x GTX275
    1x 8800GT Pysix
    1x Samsung F3 Spin point
    L-l-look at you, hacker.
    Jun 2007
    Perth, Western Australia
    Nearly 1.6V I'd have problems with running long-term. I try to never go over 1.45V for a CPU that I'd like to be with me for a while.
    Rig specs
    CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
    Foundational Falsehoods of Creationism
    Jan 2008
    Yeah that cpu's not going to last long like that, unless you get really lucky.
    PC
    CPU: Q6600 Mobo: XFX 780i Ram: 4gb OCZ Platinum 1066mhz VGA: XFX GeForce 8800 gts 512mb HDD: Seagate Barracuda 500gb x 2 Case: Silverstone tj07
    Cooling
    CPU: D-tek Fuzion, quad nozzle + washer NB: ViperJohn 780i SPP/NF200 waterblock VGA: EK-FC88 GT/GTS (G92) Rad: PA120.2 Fans: Noctua NF-P12-1300 x 4 Reservoir: Swiftech MCRES-Micro Tubing: Tygon R-3603 1/2" ID 5/8" OD Pump: Swiftech MCP655 vario
    Jul 2007
    uk
    cheers lads think ill turn it down tonight, i might loose 300mhz on the o/c but id reather do that than loose my chip
    X58A-UD3R
    920 @ 4.1ghz
    6gig OCZ
    1x GTX275
    1x 8800GT Pysix
    Dec 2006
    Netherlands
    i had my E6600 on 1.5v on boxed cooler @ 3.5Ghz for a long time and later 1.6 @ 3.7Ghz on a gemenii the cpu is now a year old and still working
    on the boxed cooler it gets HOT but it still working
    To be a professional noob/idiot
    * Default factory speed is for noobs.
    * Everything must go above the speed that the factory consider safe.
    * Everything for more performance
    * Everything fits, and everything can be broken.
    * Most problems can be fixed by adding a volt or two.
    * Post things in your signature that makes no sense at all.
    Xtreme Cruncher
    Feb 2008
    C:\WINDOWS\system32\
    I don't recommend anything over 1.5-1.53 volts for 65mn chips, and 1.41-1.44 volts for 45nm chips. You could get away with a higher voltage, but only if you don't expect to keep the chip long.
