First, I have to thank you guys for all the helpful replies/advice to my first post. Now for the second...
I got my E2160 to 2.9GHz (325x9) stable on my P5K-VM, which seems to be lower than average compared to others here. Temps were peaking 64-66C using a Zalman 7000B-AlCu. I suspected heat was keeping me from getting stable above 2.9GHz. I had already lapped the bottom of the HS so my options were (1) lap the IHS on the E2160 or (2) remove the IHS and put the HS directly on the core. Since it had the potential for a larger temp drop, I opted for #2.
So, following the path others had blazed I removed the IHS....and managed to score the top of the PCB in 3 places with the razor blade. Believe it or not, the thing still works.
Anyhow, the IHS adds ~1.5mm in height to the CPU. This is important because when you remove the IHS the top of the core sits below the top of the load plate that holds the CPU down. The Zalman's wide base hits the load plate instead of sitting in the recess on the core. Fortunately(?) the base of the stock HS was small enough to clear the load plate and sit on the core.
Here's where things get funky. Just running at stock speed (1.8GHz) the E2160 idles ~31C. Under load it peaks ~60C. When I bump it back up to 2.9GHz it peaks ~72C! WTF?
Couple of notes:
- I used AS5.
- There is a delta between the 2 core temps of about 4-5C where it was maybe 1-2C before.
- Because the core is lower relative to the MB the stock HS does not press down as hard on the CPU.
- I disabled "CPU Q-Fan Control" in the BIOS to keep the HS fan running at full blast.
Any ideas on what I can try to get the temps down? (I can't use a large HS because I'm using a SSF case.) I thought about getting a decent copper core HS, but for the money I'd spend I could add another $20 and get another E2160 and hope for one that OCs better than the first one (without having to remove the IHS).
