Hey guys, first post here, looking for some advice on my next build. I currently have a QX9650 running at 4.0 so its throwing off a bit of heat. I'm cooling it with a PA120.3 and have two HD3870s in crossfire being cooled by a PA120.2. The only problem with my current setup is that its LOUD. I need to leave my fans on pretty much full blast to keep load temps on my processor under 65C. My motherboard is an Asus Maximus Extreme.
I've decided to go for complete silence this time (I'll also be adding a third HD3870 to the mix). I think I went a little overboard on the amount of radiators I have, but that can never be a bad thing right?
I have a custom MM case coming that can all of my radiators and need some advice on how to set this up:
EK Supreme
Three EK FC3870
EK NB S-MAX
EK SB MAX-EX
Two EK Mosfet Asus 3a
Three Thermochill PA120.3
Thermochill PA120.2
Two EK Multioption RES250 Rev2
Two Swiftech MCP350 with Petra's Top
Swiftech MCP650
I'm running all of my fans at either 5v or 7v so I figure I can get some pretty decent temps using all of my radiators, but I'm sort of confused on how to plumb everything.
Thanks for the help!
