Well got my new waterchiller up on my ic7 - 2.4c. I fire it up, and about 30 mins into testing it i notice some condensation on the side of the block. So i rip it out, redo the insulation and no condensation now, but sence i ran out of as3 i desided to reaply using some of that radio shack compund that so many have had luck with. Its a bit diffrent than as3, so im not sure if im applying it right, really im not sure whats going on now. So i put the block back on and go into bios, starts out at 40c, then climbs up to 60c before i shut it off, this is all with -60c coolant! Can someone tell me what the prob is?
