X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 104
Thread: Tool to change CPU string
    Nov 2002
    Sweden
    Talking Tool to change CPU string
    I don't know if it's been posted before, but I downloaded a program called "Central Brain Identifyer" which works much like Wcpuid, but with a little more info. Under the tweaks tab, there's a tool to reprogram the CPU string on the CPU. Pointless but fun, a personalized CPU..
    Perhaps a useful tool for people working/benching lots of CPU's etc.
    Note the namestring in the screenshot, especially in the right one: :P
    CBI can be downloaded from it's homepage:
    Central Brain Identifier
    Since I can't see any download link on the official page, I'll share the download link:
    Central Brain Identifier 3.0b
    ps. I noticed the tool can disable L1 data cache ECC checking. Not sure I dare to disable it though.
    ASUS Sabretooth P67.B3
    Core i5 2500K 4900MHz stable/4500 Daily use
    Fractal Design R3 with Corsair TX 650W PSU
    G.Skill ARES LP 1600 @ 1866
    MSI Radeon 7950 @ 1150/1600
    OCZ Vertex 4 128GB FW 1.5
    Feb 2003
    Edmonton, Canada
    That L1 ECC thing is interesting. Wonder if it would make any diff in performance. You'd think its safe, since the author put the feature there in the first place. But not knowing how it works, or if its possible to reverse in case it totally b0rks stuff, I'm not trying it.
    Makes for truly l33t wcpuid screenies tho.
    XP2500-M IQXFA 0348 XPMW, DFI Lanparty B, 2x512 KHX3000
    1700+ 0310 WPMW @ 2700mhz (225 x 12) 2.06V Prometeia cooled
    2x512 OCZ EL-3700 DC sync 2-3-3-7 @ 2.9V
    ATI 9700 AIW
    NF7-S v2.0
    WD 36GB Raptor 10k rpm
    PC Power & Cooling Silencer 400W PSU
    NEC FP2141 22" CRT
    Klipsch 5.1 ULTRA, Klipsch DD5.1 decoder.
    Jun 2003
    Ohio
    I think the PR rating is a bit off....
    Mar 2003
    weeeeeee that was fun!
    eocf newbs own, as does linx
    Feb 2003
    humm, can't imagine how you only have 128K of L2 cache : XP-tbred have 256Ko and Barton have 512Ko , where did you get this chip that can do 3Ghz below 0°C :??:
    Nov 2002
    Sweden
    Hmm.. Actually, I think it's spot on. Since it's a Barton it's not using the same ratingsystem as the T-breds. A Barton 3200+ runs @ 2.2Ghz, I've got my 2500+ running @ 2.25Ghz. If I'd had a better motherboard I'd be pushing it a lot more, but alas, my motherboard craps out at 180Mhz FSB.
    Sep 2002
    UK
    My KX7-333 had a bios option to disable L2 Cache ECC Checking, used to give a decent performance boost and I never had any problems with it.
    The program says Cache Check is disabled anyway for me;
    Abit NF7-S v1.2
    1700+ 0310WMPW @ 12.5x211 (2645MHz)
    Maze3 CPU + GPU watercooled
    2x256MB Corsair XMS3500C2
    Connect3d 9800 Pro @ 466/371 3dMark2001 - 20719
    Leadtek GF4 Ti4600 @ 351/770 3dMark2001 - 17497
    Aug 2003
    2MrLavender:
    The program can disable or enable L1 Cache ECC only. Be attentive!
    Aug 2003
    2rabeb25:
    Your screenshot is fake! At fist, 128KB L2 cache has your Athlon XP. Secondly, my program shows XP-Rating for all Athlons XP and your CPU isn’t an exception to the rule.
    Mar 2003
    haha sorry its not fake, I don't have the time nor skills to do it. nice try though
    Sep 2002
    UK
    Originally posted by VVJ
    2MrLavender:
    Erm, I'm very attentive thank you.
    Somebody asked what would the effect of enabling/disabling L1 cache checking, I pointed out that disabling L2 checking used to give a performance boost on mobos that allowed that. The inference being that you want L1 cache checking disabled for best performance as well.
    I specifically put L2 in bold in my reply to highlight that difference.
    2rabeb25:
    You are the author of this program? Nice util, but I wouldn't suggest that accusing ppl of posting fake pics is a good way to collect bug reports...
    If you are the author, here are my suggestions;
    1. Put a close/quit button on it. Or if there is one there already that I've missed then make it more obvious!
    2. The XP rating is calculated a bit too high as somebody else pointed out. Here is my 2500+ at 3200+ speed (very slightly over).
    Oh, and to xtreme.
    Attached Images Attached Images
    Abit NF7-S v1.2
    X. I. P.
    Jul 2002
    Sioux Falls, SD U.S.A.
    Sure is an interesting program. Shows how at least portions of the CPU aren't fixed at the factory.
    And, another welcome to xtreme VVJ!
    The plural of "anecdote" is not "data."
    Nov 2002
    Sweden
    Mr Lavender: that's weird. I've got a faster chip yet you get a higher rating.. Interesting..
    Aug 2003
    Would it be posible to add a feature that automatically stores the settings and sets them after restarts?
    Also, has anyone noticed a benefit in turning off the L1 ECC?
    BTW my 2195mhz XP is showing as XP2731
    <img src=http://www.liquidninjas.net/dc/ln_dc_sig.php?xuser=Niven&xteam=3365&xskin=f_xs>
    Sep 2002
    UK
    Like I said, he needs some bug reports without abusing ppl because his program doesn't work as expected on their systems.
    Check my profile VVJ, I'm a software developer too.
    Abit NF7-S v1.2
    Aug 2003
    2rabeb25:
    Of course! XP-Rating wasn’t determined because the program showed 128K L2 cache size. XP-Rating is calculated for the known processor cores: Palomino (256K), T-Bred (256K), Barton (512K) and for Thorton (256K) in the latest version. Does WCPUID show 128K L2 cache size as well? Thanks for cooperation!
    Aug 2003
    2MrLavender:
    Frankly speaking, I don’t know how L1 Cache ECC affects to the processor performance. I found that all AMD Athlon Model 1/2 has enabled ECC, but in the Athlon XP the correction was disabled. I realized this tweak in my program. Perhaps, it will be a good thing for experiments. Also, I planed to realize the same functions for L2 Cache. I analyzed all Athlon XP MSRs, but I didn’t find how “L2 ECC Cache Checking” BIOS option affect to the set of MSRs.
    As for your suggestions about close button I do not plan to add it at all, because it looks inappropriate. You can use Escape key for closing the window. About XP Rating. It’s calculated depending on L2 Cache, standard FSB, CPU clock. For example, if your CPU has non-typical 170MHz FSB XP rating is calculated like for 166MHz, if 220MHz – like for 200MHz. So, my formula isn’t so exact as you can see.
    Hm, you are right about the XP rating! The program incorrectly calculated it for Barton with 200MHz bus. Thank you MrLavender, I have just fixed this bug!
    Thanks for screenshot! Heh, I would really like to drink a beer with you
  18. #18
    Aug 2003
    2sjohnson:
    Thanks for invitation! But my English is too bad, so that to be there frequently and answer the questions.
  19. #19
    Aug 2003
    2Niven:
    What are the settings would you like to save? Furthermore, If you lunched the program by chance with your personal settings, for example for tweaks, on the PC with another CPU that doesn’t support some MSRs CBId may call a BSOD. I think it isn’t funny.
  20. #20
    Sep 2002
    UK
    2MrLavender:
    No idea either. I just know that it was implemented in the Abit KX7-333 bios, and Disabled did make a big difference in all benchmarks. Perhaps it was just a marketing feature, I can't see why you would ever want it Enabled on a desktop system anyway (although that was in fact the default setting).
    ESC key is fine, but I told you it wasn't obvious! How about a "ESC to quit" label then?
    If you're ever in London PM me and we'll see what can be arranged.
    Abit NF7-S v1.2
  21. #21
    Aug 2003
    Slovenia
    I tried disabling L1 ECC checking and it turned out that it isn't good. F@H runs OK but in WinAMP or other MP3 player I get "corupted" sound, some cracking and poping, like on old vinyl plates. Also in DivX films processor makes artifacts in picture when ECC disabled. And performance is no better. I think it is no good.
  22. #22
    Nov 2002
    Sweden
    I agree that disabling the ECC on the cache is pointless. No performance increase whatsoever.. I didn't have any other problems though.
  23. #23
    Aug 2003
    2MrLavender:
    “L2 Cache ECC Checking” option is also present in BIOS of my old EP-8KHA+ (VIA KT266A)/ When I enable or disable this option performance of the processor is the same. My system is based on AXP 2000+ T-Bred B0.
    All right! I added the classic close button, but its visibility is optional. The visibility for the button is adjusted in the INI-file. Also, I added adjusting transparency for the window (under Windows2000/XP). The final release coming 26th.
    Thanks! But maybe in next year.
  24. #24
    Aug 2003
    TribesMan
    Hm, the disable option doesn’t reduce the quality of the MP3/Video playing whatever on my AXP2000+. Sorry, I have no any comment. All tweaks are successfully tested on my own CPU and some other AthlonXP with higher frequencies.
  25. #25
    Aug 2003
    Slovenia
    Maybe I've this problem because I'm running my 2000+ at 2600MHz? It is watercooled and temps under 45°C, but that's high overclock and the ECC correction may help eliminating erroes?
