Results 1 to 13 of 13
Thread: Ordered a Accelero S1 for my 8800GTS 512, need some advice
    Jan 2008
    Hi, I just ordered a accelero s1 and I'll be installing it in my 8800GTS 512 and I have some questions.
    I plan on putting a Scythe S-Flex 1600rpm on it. Can I connect it to the cards fan connection?
    I heard the heatsinks that come with the cooler arenīt easy to attach, what is the best way to attach them?
    Thanks... and sorry if my english sounds strange
    [edit]Update
    Just installed the accelero in my GPU and I'm am impressed, I have never been impressed so much with something I bought! and so cheap my card with stock cooling and fan speed set at 55% via riva tunner was idling at 45š and playing crysis it will hit 70š
    This Is my result with the accelero and withouth any fan! playing crysis for 30min
    edit - My system is now cooling down (I stopped playing crysis a couple of minutes ago) and now it's idling at 34š
    Feb 2006
    Best to plug into a Mobo header close to the card. Can control fan speed in the BIOS then.
    Leaping Ahead....
    CPU: Intel Core 2 Quad Q6600 @ 3.4 Ghz at 1.35 VCore set in BIOS
    HSF: LAPPED Thermalright Ultra 120 Extreme + 120mm Yate Loon D12SL
    RAM: 4 x 1GB Crucial Ballistix PC6400 963 Mhz @ 4-4-4-12 2.15V
    Mobo: Asus P5K-Deluxe P35
    HD's: 2 x 74GB Raptors in RAID 0 and 2 x 160GB WD Sata II's in RAID 1
    GPU: EVGA 8800GT 512MB Superclocked 720/1860/1980
    Sound: Sound Blaster X-Fi XtremeMusic
    PSU: Corsair HX-620
    Case: CM 690 Loaded with fans but quiet as a mouse.
    Monitor: 22" Samsung 226BW - 2ms of Gaming Joy!
    Aug 2006
    St. Louis
    Never heard that the ram sinks aren't easy to attach, and I have one. They come with fairly sticky clear applications, may not be the best sinks though.
    i5 750 @ 3.2 Ghz, stock volts on stock cooling
    4GB G.Skill DDR3-1600 7-7-7-21
    Gigabyte P55-DS2
    EVGA GTX260 192shader
    May 2006
    UK
    the ram sinks will stick fine, but you must clean the ram chips properly, use isopropyl or medical alcohol, something that is very pure. Don't use citrus based Akasa cleaner or similar.
    i5-750 w/ Thermalright Ultra120X
    Coolermaster HAF-932
    MSI GD65
    2x2GB G.skill Cas7 1600MHz
    Sapphire HD6870
    Western Digital 640GB.AAKS
    2x Samsung F1 1TB
    2x Samsung SLC 64GB SSD
    Pioneer DVR-212BK
    Corsair HX620W
    Creative X-Fi Xtreme Music (dead, using onboard -.-)
    LG W2286L
    Dec 2007
    Sweden
    Quote Originally Posted by Brick_top View Post
    Iīve Order one too, for my HD 3850. I have also read a couple of times that the heatsinks fall of all the time. If thats true you can always glue them with somthing like zalman Thermal adhersive or so. But then It will be harder to loosen them for upgrades in the future.
    Iīm gonna slap 2 x 120 mm Primecooler 2000/rpm, 67 cfm on my sink, really looking forward to that
    MotherBoard: GigaByte G33M DS2R
    Memory: 2x1 Gb HyperX DDR2-9600, 1200 Mhz
    Cpu: Intel e2160 @ 3,6 Ghz on Air
    Vga: XFX 4870 XXX
    Cooling: Ninja Mini, 2x Ximatek 120mm, 1x Zalman 80mm , Stock Gpu
    Case: Antec Fusion Remote
    Jan 2008
    Quote Originally Posted by LuckyNV View Post
    I have Articlean around, is that appropriate?
    Nov 2007
    Illinois
    Arcticlean is citrus based too - you should be able to smell it whenever you use step 1.
    E7200 @ 3.4 ; 7870 GHz 2 GB
    Intel's atom is a terrible chip.
    Jan 2008
    Quote Originally Posted by cegras View Post
    hum... that's probably bad, what If I told you I have already used it in a GPU's memory chips before I applied artic cooling mx-2? what can happen?
    Dec 2007
    Artic Clean is a 2 part cleaner. Yes, the first part is citrus based. That is used to break down the old TIM.
    The second part is the actual prep, and is not citrus based. It cleans off the 1st part.
    (Part-1 cleans old TIM. Part-2 cleans off part-1)
    I used it when I attached the ramsinks that came with my S1. Worked like a charm. highly recommended.
    May 2006
    UK
    the issue is with small ramsinks with pre-applied thermal tape, nothing else
    MSI GD65
    Sapphire HD6870
    2x Samsung F1 1TB
    Pioneer DVR-212BK
    Corsair HX620W
    LG W2286L
    Nov 2007
    Illinois
    Should be okay. The one thing I didn't like about using AC on a memory or on small chips (e.g. NF4 chipset) is that it tends to bleed off the chip quickly and make a mess. But if you found a way to do it and used the second part .. good.
    Jan 2008
    Just installed the accelero in my GPU and I'm am impressed, I have never been impressed so much with something I bought! and so cheap my card with stock cooling and fan speed set at 55% via riva tunner was idling at 45º and playing crysis it will hit 70º
    edit - My system is now cooling down (I stopped playing crysis a couple of minutes ago) and now it's idling at 34º
    Jan 2008
    Is this a good temp?
