Can i use these one's?
http://www.performance-pcs.com/catal...ducts_id=22627
if not which one's can i use?
I really like the look of these bitpower ones
Nope, won't work.
You'll need these
http://www.frozencpu.com/products/62...45&id=dnRfegtm
or
http://www.dangerden.com/store/produ...&cat=34&page=1
for that size tubing.
Circles SucQ!
AFAIK Yes
Circles SucQ!
Alternatively, you could use Primochill 3/8 ID 5/8 OK on 1/2" barbs and skip the special fittings. Works great!
DFI LP LT X38, Q9550 @ 400X8.5 (3.4GHZ), 8GB G.Skill PC2 8500 @2.0V, Powercolor 5870 @950/1250 GHZ with factory installed EK waterblock
Windows 7 64bit
Lian-Li 343B case
Water cooling components in one loop: Thermochill 120.3 to cool CPU and NB,Thermochill 120.2 to cool GPU, DDC3.2 + Petras top for above pumps.
Sometimes I feel like 2/3rds Rice Krispies. Past Snap and Crackle, but just shy of Pop
is bits power the only maker of a g1/4 1/2ID comp fitting? or are there other manufacturers? I have been contemplating switching my whole setup over to compression fittings but I need about 20 of them, and at $7 a pop, thats pretty pricey.
My Custom Pressure/Temperature Charts for Various Refrigerants
QX6700 @ 3900 | EVGA 680i |2 GB Corsair 8500 Dominator | 7800 GT SLi | Silverstone 1KW | Seagate 7200.9 Barracuda RAID 0 + Hitachi Deskstar 2TB RAID 0 | SS Phase w/ Cryostar Evap | MIPS Full Motherboard cooling
My Fake Quad Core is better than your real Quad Core! **cough**Barcelona**cough**
Lian Li Cube Case with Phase and Water DONE!!
I know frozencpu stocks bitspower stuff, they may have the compression fittings but I am not sure. Other than that, compression fittings are certaily not for the WCer on a budget, the damn things are expensive as hell.
edit: looks like they only have thinwalled compression fittings.
ASUS P7P55D
Intel CORE i7-860
EVGA 8800gt 512mb
Corsair 800D
I was commenting on your edit about thinwalled. Performance-PCs doesn't seem to sell 1/8" wall version of the compression fittings
Only got a couple of them, but Frozen sent me the wrong ones. 3/8 1/2 so be careful to examine what you get
