Well hello everyone.I have been reading this thread for quite a long time now.Have learned a couple of things from u guyz and i thank u all for this.
When i first completed the system u can see in my sig i said that aircooling is all i ll ever need.What is the meaning of running a watercooling system?None, replied to myself. Two months after reading this forum i changed my mind and decided to enter the w/c side.So as u can clearly understand u r nothing but bad influence![]()
Enough talking...the parts i think to include in my setup are the following:
D-Tek Fuzion Intel 775 Quick Mount Brack
D-Tek Waterblock Fuzion for CPU
D-Tek Fuzion Nozzie Kit
Swiftech MCP655 12V
ThermochillRadiator PA 120.3
EK WaterblocksReservoir Multioption 250
Tubing Tygon R3603 19.1/12.7 Transparent (1m)
Artic Silver 5 (3.5g)
The questions i have are the following:
1) D-Tek Fuzion Intel 775 Quick Mount Brack. Is it good or shall i choose the Thermalright one instead?
2) D-tek Fuzion. I guess that currently is the best cpu block i can buy. Do u recommend anything else? Does it work with the same efficiency on both Quads and Duals?
3) Swiftech MCP655 12V. Either this or Laing D5. Dont have any other option for the moment. As far as i know these are the same right? So i ll go for the Swiftech which is a tad cheaper.
3) About the rad. I ll run a cpu only loop for the moment and maybe the N/B. Do u think its too big? Do u think i should go for the 120.2 instead? Will there be any difference at idle/load if i run Quad @ 3.8 @ 1.55 for example?
4) Tubing Tygon R3603 19.1/12.7. Is it ok for my setup. I have NO clue about what tubing i shall use![]()
5) Artic Silver 5. I would like to go with MX-2 but i dont seem to find it anywhere. Is there any noticable diffrence? Not that it really matter if i cant get it but just to have a clue.
Thats all for the moment i guess. If u have to comment/add/change/remove anything i will be glad to hear from u.
And to be honest u putted me into trouble u have to get me out.![]()
