See edit, lol. Good night!
Here you have another simple way to install llrnet on 2, 4 and 8 cores machine.
The default server is on port 5000 but you also have work on port 400 and little work on port 7500. To change the port just edit llr-clientconfig.txt for all cores and look for the server location. Another thing you have to edit is your nickname, please look for the line username = "TeamName_nickname".
Extract the zip, for 2 and 4, versions and unrar for the 8 version. To run the client you just need to run llrnet.exe respectively for each core.llr-clientconfig.txt content:
-- LLRNet - network part of LLR
-- (C) 2004-2005 Vincent Penne
-- Released under GNU LIBRARY GENERAL PUBLIC LICENSE
-- (See file LICENSE that must be included with this software)
-- CLIENT CONFIGURATION FILE
-- WARNING: comments start with two dashes
-- server location
server = "nplb.ironbits.net"
port = 5000
-- username ## Replace this with your mersenneforum username
username = "XtremeSystems_nickname"
Links to download:
http://em99010pepe.googlepages.com/l...2_NPLB_win.zip (Core duo windows)
http://em99010pepe.googlepages.com/l...4_NPLB_win.zip (Quad-core windows)
http://em99010pepe.googlepages.com/l..._win.part1.rar (Octo part 1 windows)
http://em99010pepe.googlepages.com/l..._win.part2.rar (Octo part 2 windows)
All clients will run in the system tray. If you right click on the icon and if you choose "New GUI Window" you will get remotely control of all cores and see their progress.
Hope this helps a bit.
Carlos
Free-DC Mercenaries member
Port 7500 has 461 remaining so if you want to help a bit I suggest Port 5000.
Carlos
EDIT:
Here's an interesting map. For 300<k<1000 we are trying to find primes until n=600,000, so we still have something like 820,000 candidates to test. By looking at the following map you can see we still have a small gap to fill. HELP NEEDED.
Port 7500 is dried.
jcool,
Do you want to try to run llrnet on port 5000 for a week in a row on your octo?
Carlos
Sorry, but no. Too much hassle setting it up, and too much WCG work lost. My priorities don't lie with maths calculations either
I'll put some other machines on it if I get around to it. Really annoying that you have to change the config file all the time (my rigs run 24/7 without me being near them most of the time, so that's a rather big problem).
Ok, thank you.
You just need to setup once. On which type of machine (2, 4 or 8 cores) would you run llrnet? I can easily config the files for you, you just need to extract them to your llrnet folder. I'm also hosting a server so for example you can put your cores there, please tell me if you would like to run this for just a week in a row. This would help a lot a small project, you will make a big difference.
Carlos
New stats page in here:
http://stats.free-dc.org/stats.php?page=proj&proj=nplb
It will take a few days to put them correct.
Just to let you guys know we are trying hard to quickly finish drive 3 until the end of November.
port = 5000
Final push to complete Drive 3, at current pace 15 days left. Help needed. Thanks.
Live stats are now available from free-dc stats page.
Drive 3 was completed a few days ago and now we are concentrated on finishing Drive 1 until the end of the year.
Current servers with work:
#1
port = 400
#2:
server = "nplb.dynip.telepac.pt"
port = 443
#3
server = "nplb-gb1.no-ip.org"
port = 4000
Glenn,
When you get back to NPLB don't forget to take out the team reference from your username. This is because the new stats system works better that way, thanks.
Carlos
We won't finish Drive 1 until the end of the year, we really need some boost.
Thanks Glenn for the cores.
At the current pace Drive 1 will be finished within 16 days, final push Glenn? Just for a few days, bring everything.
Meanwhile got a new machine for my work, it's a quad-core, already running on server C443. My home quad is running IB400 and some manual ranges.
Carlos
Glenn,
I am running my own rally just until Sunday, care to join me?
Carlos
Very fast wu's in here Glenn:
port = 9000
http://nplb.ironbits.net/
Carlos
