glennpat,
If you want even fast wu's you can change your port server to 100 after clearing your cache.
More information in here.
Carlos
glennpat,
Carlos
Free-DC Mercenaries member
user=XtremeSystems_DragonOrta
[02/17/08 20:11:00]
****2^******-1 is prime! Time : 454.0 sec.
DragonOrta,
You found a prime, please check you PM box for instructions on how to submit it to top 5000 rankings. Take your time to learn how to do it, please don't publish the prime you found until it is submitted. Hope to be your first of many. Congratulations!!!
Carlos
So how many cores do you have on it? Maybe by moving more you'll find one but that it is not 100% correct.
Carlos
Whatever punk. I'm just happy with my 4ghz Q6600
A wolf in wolves clothing.
glennpat, you found a prime, please read your PM.
Carlos
Do you guys need help to submit the primes? Please reply...
glennpat, you found another one, please check you PM.
Edit: Thanks DragonOrta for submitting your prime, you can teach glennpat how to do it in case I am not around.
Thank you both, from now it is more easy to submit new primes.
Thanks Carlos ! It's nice to be on the top 5000 list. Looks like they will be on the list a fair amount of time before they fall off.
Thanks for the in-depth instructions on how to submit the Primes Carlos. I don't think I would have been able to get through the process if you hadn't sent those.
There will be a 24-hour NPLB LLRnet rally (port 100) this weekend beginning at 7 PM GMT Saturday 2/23.
In that case, I'm happy with my 4.3ghz Q6600. It gets alot of work done between random reboots.
I suggest to change port to 300. port 100 is down and I don't know why! I might cancel the rally...
Just a quick note. crus.dynip.telepac.pt server (ports 100 and 300) has been improved since last rally. The server can now handle more than 500 communications per second, compared to the previous 10. This change improved the dead times between clients/server communication.
Another server was set at:
address = llrnet.no-ip.info
port = 500
Finally, live stats will come soon..,
Thanks XS for all your CPU support.
Carlos Eduardo
There will be a 24-hour NPLB LLRnet rally (server = "llrnet.no-ip.info" port = 5000) starting today at 7 PM GMT. The server has Top 5000 candidates.
List of servers:
NPLB LLRnet server #1:
maintained by Carlos Eduardo
server = "crus.dynip.telepac.pt"
port = 100
current range: 401 <= k <= 1001, n = ~ 299.7k (upto 305k ~60,600 pairs)
NPLB LLRnet server #2:
port = 300
current range: 401 <= k <= 1001, n = ~ 373.3k (upto 392.0k)
NPLB LLRnet server #3:
maintained by IronBits
server = "llrnet.no-ip.info" NEW: llrnet.ironbits.net from 10.03.2008 6:00-7:00 GMT
port = 500
current range: 401 <= k <= 1001, n = ~ 314.1k (upto 315k ~10,000 pairs; 305k-310k ~57,000 pairs)
NPLB LLRnet server #4:
port = 5000
current range: 301 <= k <= 399, n = ~ 370.4k
NPLB LLRnet server #5:
maintained by Adam Sutton (AES)
server = "nplb.rieselprime.org"
port = 300
current range: 401 <= k <= 1001, n = ~ 395.6k
Updated list here.
Come and help us dry server = "llrnet.ironbits.net" port = 6000.
http://llrnet.ironbits.net/index.shtml
At the current pace it will dry in less than 58 hours. We need XS machines...lol. Thanks,
Carlos Eduardo
