+ Reply to Thread
Results 1 to 15 of 15
Thread: How are the Noctua NF-P12 as radiator fans?
    Xtreme Enthusiast perfection's Avatar
    Feb 2007
    Australia
    0
    Anybody got them and willing to share their experiences??
    http://www.noctua.at/main.php?show=p...s_id=12&lng=en
    My Rig
    CPU: Intel Core 2 Duo E6600 L626A175 3GHZ 1.30V real
    RAM: Crucial Ballistix PC2-8500 stock speed and timings
    Motherboard: Asus P5E X38 333MHZ FSB x9 multi
    Video: Gigabyte 8800GTS 320mb stock speeds
    Soundcard Creative Soundblaster Audigy 2 ZS
    Hard Drives Seagate 250GB 7200.10 SATAII (boot) > Samsung HD501J 500GB SATAII (Storage)
    Case: Lian Li PC-S80
    Powersupply: Corsair HX620W 620watt
    Optical: Samsung SH-S182D DVDRW 18x
    Monitor: Asus MW221U 22" LCD
    Mouse: Logitech CF G7
    Keyboard: Logitech G15
    Speakers: Logitech Z5500
    The water cooling
    CPU waterblock: Swiftech Apogee (original with custom top and mounting plate)
    GPU waterblock: EK FC8800GTS Acrylic
    Pump: Laing D5 Vario "3" speed setting
    Radiator: Swiftech MCR220 w/ 120mm Yate Loons D12SM-12 running at 7V
    Resevoir - Swiftech MCRES Micro - Pentison G11
    Xtreme Member Kosior's Avatar
    Jan 2008
    Poland, Olsztyn
    0
    I think about using them in my setup too ! From what Noctua writes, they seem to be good even for high restrictive radiators. I wouldn't say so but if you will use them whith PA120.3 for an example they'll be ok. And you'll hear just nothing
    Pentax k10d and a backpack of lenses...
    My flickr
    -AK
    Xtreme Cruncher Origin_Unknown's Avatar
    Jan 2005
    England
    22
    they do look awesome but for the price its not worth it.
    they are like £20 here and the medium speed yates are a quarter of the price
    My Free-DC Stats
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
    Feb 2007
    Australia
    0
    price doesn't matter to me
    My Rig
    The water cooling
    Chasing After Diety NaeKuh's Avatar
    Jan 2007
    Absolutely Speachless :O
    1
    #1. San Ace aka Sanyo Denki SanAce 1011 has the greatest static pressure
    #2 Zalman F3 series. Vapor was shocked at how well these fans held up
    if you need LED's the F3's come in blue and red.
    #3 sharkoon golfballs & empapst.
    Then would come yates. At this point yates start performing on par with everything else or better, and have a much more attractive price.
    i wanna know how the 38mm ultra kaze's would pull on vapors chart. Maybe i'll buy one and throw it at him to see if he doesnt get one to test soon. :T
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Jan 2005
    England
    22
    isnt the f2 a 92mm fan?
    My Free-DC Stats
    Xtreme Mentor SKYMTL's Avatar
    Aug 2007
    9
    LINK
    Tested on WC rad.
    Jan 2005
    England
    22
    lol that was the first review i read on those fans.
    also your review on the corsair TX750 made me buy it
    My Free-DC Stats
    Aug 2007
    9
    Good to hear. But I have been using these fans on my TRUE for some time now (yeah, I know this is the WC forum) and I will be transfering them over to a WC setup I have had on the books for some time now. Needless to say, they have impressed me.
    Jan 2005
    England
    22
    they do look awesome (and vapor needs to test) but at £15 each its hard to stomach and i'd need 5
    My Free-DC Stats
    Xtreme Member neo_rtr's Avatar
    Dec 2007
    Stockholm Sweden
    0
    Hi, I have been using Noctua fans for quite some time,
    Since the NF-P12 come out got 3 for my PA120.3 and 4 for my Stacker 832 side panel.
    By neo_rtr, shot with DiMAGE X1 at 2008-01-24
    By neo_rtr, shot with DiMAGE X1 at 2008-01-17
    I dont hear them much and from what i can tell they provide a better air flow 92,3 m³/h than others i could get.
    in fact since they come out it took a while to get them locally so i had them order abroad (extra $$) in order to get them.
    For all its worth iam happy with them,
    By neo_rtr at 2008-01-21
    above is stats after cpu load aprox 30mins where i cleared the log. room temp i think was about 25c (ps: the pc was closeby to the heat radiator in the room some some warm air might have been taken into the pc)
    [Asus P8Z77 WS Z77] [i7 3770K] [Apogee HD waterblock]
    [16GB G.Skill DDR3 PC3-19200 2400MHz TridentX Series CL10 (10-12-12-31) Dual Channel kit]
    [Zotac GTX 680][Watercool Heatkiller GPU-X3 GTX680 Hole]
    [2x ThermoChill PA120.3][2x Laing DDC-1T-PLUS - XSPC Dual 5.25"Bay Reservoir ][Stacker 832][PSU:ThermalTake 1200W][2x 24" Screens BenQ G2420]
    Current Rig ASUS P8Z77 WS - ATX / Z77 Intel Core i7-3770K CM Stacker + 2nd WC Casehttp://img49.imageshack.us/my.php?image=pict0157dh0.jpg
    Project Blue Orbit - Phase 2
    http://www.xtremesystems.org/forums/...d.php?t=243865
    Build With MIPS freezers NB,SB,Mosfets
    Jan 2005
    England
    22
    neo_rtr are those fans as quiet as they say? with that CFM? (i want to order some today )
    My Free-DC Stats
    Xtreme Enthusiast AndyM's Avatar
    Jan 2007
    0
    I like the ideas behind these fans, but would really love to see a head to head test with the Petra's curved blade YL's in hard numbers. Might be easier to stomach the price considering the 10 fans I'd need to change in my machine
    C2D E8400 @ 4.4 Ghz
    Asus P5K Deluxe
    Nvidia 8800 GTS @ 648/900
    2GB Ballistix
    Dtek, Swiftech & EK blocks, 2x D5, PA120.3, 2, & 1.
    WD Raptor X 150GB & Seagate 7200.10 320GB
    X-Fi Prelude
    Corsair HX620
    Silverstone TJ07
    Dell 2407 WFP
    Dec 2007
    Stockholm Sweden
    0
    Quote Originally Posted by Origin_Unknown View Post
    93 cmh = 54.732 cfm if the web maths holds on..
    yes they are quite..(for me that is and i have total 10 of them in my case)
    Xtreme Addict MpG's Avatar
    Jul 2007
    Canada
    0
    I can vouch that the Noctua's are bloody quiet, even at full speed. A step quieter than my 1200rpm YL's, for certain. I'm undecided on open-case flow strength, as my back-of-hand-o-meter thinks the YL's are moving a little more air, even with thier slightly lower rpm. Noctua's marketing this strictly as a static-pressure fan, so perhaps they found some extra pressure at the expense of airflow? Like a water pump with extra head and less flow?
    i7 2600K | ASUS Maximus IV GENE-Z | GTX Titan | Corsair DDR3-2133
+ Reply to Thread
