You obviously havent had my wifes cooking in the gas oven then...
So the only risk is electric shock?
Never empower an idiot with a response....
http://en.wikipedia.org/wiki/Troll_%28Internet%29
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
Which is pretty null as I dont leave the electronics open. Heatshrink for all, but yes touching live capacitors is always bad. Same with working in a live PC.
If you have a cooling question or concern feel free to contact me.
Does that also go for sticking my fingers in the wall socket
EK Water Blocks R&D
ekwb.com
Hobby: Rotary SS bench unit (LPG/R-507) | -75°C Auto-cascade (R-600/R-290/R-744) | Plate HX water chiller (1kW cooling power) | My 2nd cascade MP14FB R-507/R-1150 | Mini cascade R-507/R-1150 | GPU single-stage | Mach I restoration mod -> -38°C @ 230W
Milestones: 7.12GHz P4 | 6.84GHz K10.5 | 6.45GHz Ci5 | 3.31GHz K7
3DMark2001SE -> Favourite Game!
Are Yorkfield cold bugging?
Anybody posted any Ln2 attempts? Ive seen some dryIce by SliDog but havent seen anyone go really cold yet.
Agreed valves would be nice but im deffering to NoL and his judment. I can always use shims if I need to ...
I think a hand valve can be a major pain for controlling temperatures, a bit too much and your evap temp can skyrocket. Not the best.
Sure a CPEV system could be useful instead, but I prefer shims when coldbugs are the issue. That or cranking the volts
From what I have seen some chips bug at -50 and then work great until -110C after its booted. I have also seen people being able to directly boot at -100 c or colder. It really depends on the chip itself and the board.
Originally Posted by 3oh6Originally Posted by Brian y.
Unless your bodies already at a potential of the wall voltage
Hey NOL hows the pressure testing coming along?
Pressure tests all done, vacuuming out 2nd again and then charging with r1150 tomorrow and switching gauge set to 3rd stage and vacuuming.
What happend to the second stage..... thought it was running a month and a half ago?
CPU's: E6700es, 950es (WR 6.1ghz) http://valid.x86-secret.com/show_oc?id=186415
MB's: Asus P5WD2 Premium, DFI 975 X/G
Memory: Corsair PC5400UL
Video: ATI X800pro, ATI X1800XT, ATI X1900XTX
Oh it was, and had my gauge set on there.
What I didnt know was that after screwing the schrader back in on the low side, it had not gone in all the way (this is via my valve core remover), thus poomf
I actually only noticed it when I removed the gauges and noticed pressure gauge dropping Seems also my valve core remover somehow flanged up inside and that caused it. Taking it apart to see if I can fix it. One of my most useful tools and I dont want to replace it.
Not what your thinking Teyber, this allows me to remove the valve core with refrigerant in the system, as well as lower vacuum times, and such.
