OCN2
Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 77
Thread: Mushkin 4GB XP2-8000 – Return of Redline!
  1. #26
    Jan 2007
    QLD
    Indeed, Mushkins was always one of those brands that was always a touch more expensive, but I could never figure out why going back to the sdram days. There still good, and if they were on special I would buy mushkins again, but certainly not infallible. Some of the worse crap ram I've had was Mushkins DDR400, turned out no better than a shoddy patriot kit that cost half as much at the time.
  2. #27
    Apr 2005
    Calgary, AB
    So true and unfortunate. You have to build brand loyalty from good support and quality products because exclusive chip supply is a thing of the past. Just remember it is not about who can build and sell a part the cheapest..
    MB Reviewer for HWC
    Team OCX Bench Team
  3. #28
    Jan 2008
    can anyone tell me how these compare to the geil esoteria's?
    upgrading...cooler master cm690 case, corsair hx850, samsung 1tb x 3, optiarc burners x2, gskill 4gb ripjaws, working on the rest again
  4. #29
    Sep 2004
    Quote Originally Posted by EnJoY View Post
    I hate to say Brother, but that's complete bunk, and the results in this thread help to prove that.
    Since I have had my 3 sets of Mushkin ram I have had 2 sets of OCZ, 2 sets of Bufffalo and 1 set of Corsair just up and die on me. The Mushkins have been punished and still they live on.
    Core i7 920 @
    MSI X58 Eclipse SLI
    6GB Mushkin Blackline
    GTX295
  5. #30
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by ccokeman View Post
    from all my ddr2 only my mushkin xp2-8500 have died
    i'm on my third set lol 2.26v max 24/7 lol
    and my kingston valueram 667 outperformed all 3 sets and still 100% after a year of use
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
  6. #31
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by zsamz_ View Post
    You both have proved what is essentially fact. It's all just luck of the draw. Binning certainly can play a big role. But if you look at one set of OCZ PC2-8500 with D9's and one set of Mushkin PC2-8500 D9's...you essentially looking at the same sticks.
    Formerly XIP, now just P.
  7. #32
    Dave's Mentor!
    May 2007
    montreal
    yup as i said its whats inside that counts
    mushkin binning use to be good but now
    only when you get the new micron ics that it will get better and of course depending on their stocks lol
    when you pay more you should get the best but not the case with ram lol
    the problem is ram manufacturers reading overclocking forums n passing lower grade chips @ higher rating
    my freinds mushkin xp2-6400 can do 4-4-4-12 @ 1100mhz with 2.3v
    since most d9s can do 1100mhz with cas 5 we gettin the shaft n getting low grade chips when we buy some pc8500 sticks
    but i gotta give kudos to crucial most 8500 rated sticks rock
    i paid my ballistix 8500s 1/4 of the price as my mushkins and thats 2007 prices not 2006 price and i dont need more than 2.13v to make them sing above 1200mhz
    my muskins need 2.34v
    and i just got them back from from rma a month ago
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  8. #33
    Jan 2008
    fyi these are available at newegg now...
  9. #34
    Apr 2005
    Calgary, AB
    Yah, available in Canada now too, Ill update the availability section.
    MB Reviewer for HWC
    Team OCX Bench Team
  10. #35
    Team AF
    Mar 2007
    CeBIT-City
    In Europe / Germany they are also available in one shop (T4PC)
  11. #36
    Jan 2008
    so any more results with these yet
  12. #37
    Mar 2005
    Norway
    Got mine today, and the box was a lovely surprise:
    They didn't boot up at 1GHz, stock timings/voltage straight away. I'm hoping it's just my sub-timings from the Crucials that's causing it. Haven't had the time to test them properly yet.
    - Intel Xeon W3520 #3848A352 D0 @ 4.4GHz
    - DFI LanParty UT X58-T3eH8 (bios 05/08)
    - 3x2GB Corsair Failinator GT 1866MHz 7-8-7-20 (3x2GB Patriot Viper 1600MHz C8 backup...)
    - Sapphire Radeon HD 4870 X2 2GB @ 872/1000
    - ~5TB assorted WD/Seagate
    - SB X-Fi XtremeMusic & Logitech Z-680 THX
    - Tt Toughpower 1200W Modular
    - CM Stacker T01 Black
    - Eizo FlexScan SX2761W 27" & Samsung 226CW 22"
    CPU Loop: MCP655/D5 - Swiftech Apogee GTZ - Thermochilll PA120.3 - YateLoon SL's - 1/2" MasterKleer
    GPU/Chipset Loop: MCP655/D5 - EK-FC4870 X2 Acetal CF - Swiftech MCW30 - Thermochill PA120.3 - YateLoon SL's - 1/2" MasterKleer
  13. #38
    Mar 2005
    Norway
    Hm well, seems like one of the sticks is a dud. I've tested one of them up to 1100MHz, which it does quite happily. The other one though, starts pumping out errors at 1040MHz, which quite frankly is very disappointing. I'll be doing more testing tomorrow, but if I'm not able to reach around 1080MHz, which is what I need for my current settings, the kit will go back on monday.
  14. #39
    May 2005
    Edmonton, Alberta, Canada
    OMG that is absolutely gorgeous.
    I mean frickin' beautiful!
    I've never been overly excited when i see fancy boxed or packaging, but that simply takes the cake.
    I might have to buy one of these kits if Mushkin promises me that box!
    As for how they clock, it's Powerchips, so anything over 500 MHz is somewhat luck, since vdimm won't help results really.
    Make sure your TRFC is set loose, as least 48+.
    If you want something that scales with voltage, you'd likely be better off with this kit: http://www.mushkin.com/doc/products/...ail.asp?id=634
    Will usually beat the Powerchips kits like this one or G.Skills, but will need some vdimm to do that.
    Gigabyte X58A-UD3R | i7 930 @ 4 GHz | Corsair H50
    G.Skill RipJaws 4x2 GB @ DDR3-1600 7-7-6-24-1N | HIS Radeon HD 5870
    3x Intel X25-M 80 GB RAID-0; OCZ Agility 120 GB | Samsung SH-S243D
    Corsair HX1000 | Dell 3007WFP & Samsung 204T | 7 Ultimate x64
  15. #40
    Apr 2005
    Calgary, AB
    Oooh, I like the box, but I didnt get one! Must be a Europe thing?
    MB Reviewer for HWC
    Team OCX Bench Team
  16. #41
    May 2005
    Quote Originally Posted by Eldonko View Post
    Now i'm disappointed.
    Once again, Euro awesomeness strikes again
    That box is just too awesome.
  17. #42
    Jan 2003
    Norway
    Quick test of mine
    Just got theese, seems slightly better than my gskill sticks, but not much.
    Attached Images Attached Images
  18. #43
    Mar 2005
    Norway
    What motherboard are you running them on? You bought them from Netshop.no, right?
  19. #44
    Jan 2003
    Norway
    Quote Originally Posted by jagt View Post
    Its a GB DS3P, 2.1vmem, and yes, picked them up at Netshop Oslo, 850NKr.
  20. #45
    Mar 2007
    Quote Originally Posted by Sniper View Post
    Keep in mind that DS3P overvolts by 0.05V.
  21. #46
    Jan 2003
    Norway
    Yes, will try lower vmem later. My gskill sticks likes 2.05 just as much as 2.1.
  22. #47
    Mar 2007
    There is virtually no improvement over 2.0V for this memory.
    But i fear this memory may degrade over time too quickly. So it is wise to keep the voltage as low as possible to prolong its life.
  23. #48
    Apr 2005
    Calgary, AB
    That is pretty decent, just a few mhz less than my kit. Yah give 2.0v a try, I found that to be optimal.
    MB Reviewer for HWC
    Team OCX Bench Team
  24. #49
    Jan 2003
    Norway
    Quote Originally Posted by Cronos View Post
    I'v been running my gskill sticks at 2.05 (bios) for months now, lots of priming, and no sign of degrading.
    I think I can go higher with them if I loosen performance level, but 7 seems to be the best on this mb.
  25. #50
    Mar 2007
    First, priming loads only a small part of memory and the load is rather light.
    Second, the degradation is rather subtle to be detected by most tests/benchmarks. I am not yet positively sure about this, but Linpack seems to show signs of degradation after approximately a month of heavy load.
    You are right about performance level, it is the most important timing and should be kept as low as possible. With higher performance level it may be possible to tighten some primary memory timings, but performance will be worse.
