Page 1 of 4 1234 LastLast
Results 1 to 25 of 77
Thread: Mushkin 4GB XP2-8000 – Return of Redline!
    Apr 2005
    Calgary, AB
    Yes you heard it right, Redline is back with a new 4GB kit flavour!
    Mushkin 2x2GB DDR2-1000 XP2 Redline CL5-5-5-15 @ 2.1V
    For the few of you that don’t know, Redline is a product of Mushkin’s exclusive EPIC (Enhanced Performance IC) selection process and is Mushkin’s flagship mem.
    That being said, here is your Mushkin 4GB XP2-8000 Redline (part 996593) test report:
    Content:
    Specifications
    Packaging
    Test Bed
    Testing Methodology
    Test Results
    Testing Summary
    Observations and Impressions
    Availability and Pricing
    Specifications:
    Frequency: DDR1000 (500Mhz)
    Latency: CL5-5-5-12
    Voltage: 2.1v
    Pins: 240
    Parity: Unbuffered
    Chips: I can’t comment on the chips quite yet.
    Packaging:
    The XP2-8000 uses the new FrostByte™ (red) Redline heatspreader and comes with Mushkin’s new packaging.
    You will probably notice that the spreaders use the old BH-5 style clips, but the new style spreaders. I thinking that this style clip gives better chip to spreader contact than the top clip style in some older DDR2 kits.
    Test Bed
    This time for testing, I am using a Q6600 setup with ASUS P5K vanilla (P35). I am also doing all tests on Vista 64 bit this time so we can see stability for all 4GB of RAM.
    Full system specs are as follows:
    • ASUS P5K
    • Q6600
    • XFX GeForce 8600GT @ stock
    • Mushkin XP-650
    • Windows Vista, 64bit, untweaked
    • CPU Cooling - Custom H20 and stock cooler on the NB
    • RAM Cooling – 120mm Panaflo
    Testing methodology:
    For stability I will run two instances of HCI Memtest and 32M at the same time. Vista uses 1GB, Memtest 2GB and PI a little more, giving over 80% mem usage. HCI Memtest is very good for picking up mem errors and I have found that 200% (about 30 minutes) and a 32M at the same time is sufficient for this report.
    For the purposes of this review, I am going to test 4-3-3, 4-4-4, and 5-5-5 using 1.9v, 2.0v, and 2.1v for the mem.
    The kit I am testing came from Mushkin directly and was provided my Brian Flood, Head of Mushkin R&D. Brian assured me that the kit I was sent was pulled randomly from the retail kits and was not cherry picked.
    Benches used:
    Super PI v1.5 (32M)
    Tools:
    SetFSB
    Memset 3.3
    HCI Memtest
    CPU-Z
    MB Reviewer for HWC
    Team OCX Bench Team
    Apr 2005
    Calgary, AB
    Test Results:
    4-4-4 – 1.9v – 412Mhz
    4-4-4 – 2.0v – 419Mhz
    4-4-4 – 2.1v – 422Mhz
    5-5-5 – 1.9v – 550Mhz
    5-5-5 – 2.0v – 557Mhz
    5-5-5 – 2.1v – 558Mhz
    Summary:
    Well first off let me say that I am pleased with the results of this mem. Although it doesn't scale as well as some of the older 2GB microns out there, it runs at high speeds at low voltages. A reasonable cost makes this a great option for your gaming or 64 bit pcs. A few observations I made when testing are as follows:
    • When dropping trcd and trp I would lose almost 100 mhz at 5-5-5 so it was not worth the mhz loss. At 4-4-4 dropping trcd/trp to 4-3-3 put clocks down below 350Mhz thus this mem performs best at 5-5-5 and 4-4-4. You can tighten trp a bit but I didnt see a difference in performance in doing so.
    • tREF at its highest value (16383) was best for performance.
    • 2.0v seems about ideal vdimm for these sticks although they are spec at 2.1v. Some sticks will respond better to 2.1v that others.
    • trfc has a big impact on clocks. Ideal for 5-5-5 trfc was best at 52, but tighter timings allows tighter trfc, ie 4-4-4 can run 44 trfc.
    • The EPP profiles are bang on and give a good starting point for tweeking.
    Availability and Pricing:
    Newegg: $160 USD
    Mushkin.com: $156 USD
    NCIX: $170 CAD
    Direct Canada: $158 CAD
    Well that is it, post questions if you have em.
    MB Reviewer for HWC
    Team OCX Bench Team
    Champion
    Dec 2005
    Budapest, Hungary
    * ASUS P5K
    * Q6600
    * XFX GeForce 8600GT @ stock
    * Mushkin XP-650
    * Windows Vista, 64bit, untweaked
    * CPU Cooling - Custom H20 and stock cooler on the NB
    * RAM Cooling – 120mm Panaflo
    what happened with your P5KC mate? trash?
    btw, nice review, congrats to the mushkins, 550 5-5-5 1.9v sounds great
    Quote Originally Posted by AndreYang View Post
    I think mine is better.
    Apr 2005
    Calgary, AB
    P5KC is fixed and is running a folding machine, got a transistor from an old board and soldered it in. This P5K clocks a little better for FSB so I use that on my test bench.
    Yeah I was surprised how well this stuff did at low volts, quite different than the micron 4gb kit I have here, took 2.25v for ddr1100.
    MB Reviewer for HWC
    Team OCX Bench Team
    Mar 2005
    Norway
    Did you test them with more voltage?
    Edit: I guess this answers my question from here:http://www.xtremesystems.org/forums/...d.php?t=174826
    Looks like these are preforming around at par with the similar G.Skill set, then?
    - Intel Xeon W3520 #3848A352 D0 @ 4.4GHz
    - DFI LanParty UT X58-T3eH8 (bios 05/08)
    - 3x2GB Corsair Failinator GT 1866MHz 7-8-7-20 (3x2GB Patriot Viper 1600MHz C8 backup...)
    - Sapphire Radeon HD 4870 X2 2GB @ 872/1000
    - ~5TB assorted WD/Seagate
    - SB X-Fi XtremeMusic & Logitech Z-680 THX
    - Tt Toughpower 1200W Modular
    - CM Stacker T01 Black
    - Eizo FlexScan SX2761W 27" & Samsung 226CW 22"
    CPU Loop: MCP655/D5 - Swiftech Apogee GTZ - Thermochilll PA120.3 - YateLoon SL's - 1/2" MasterKleer
    GPU/Chipset Loop: MCP655/D5 - EK-FC4870 X2 Acetal CF - Swiftech MCW30 - Thermochill PA120.3 - YateLoon SL's - 1/2" MasterKleer
    Apr 2005
    Calgary, AB
    Yeah 2.15v didn't do anything over 2.1v.
    MB Reviewer for HWC
    Team OCX Bench Team
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Very nice, well laid out review.
    If I could guess, I'd say they use the same PowerChip IC's as found in the high-end OCZ and G.Skill 4GB kits. My only personal criticism with Mushkin's variation would be the price, why so much more than other comparable kits?
    Formerly XIP, now just P.
    May 2006
    Pricing
    If the MSRP really is $175 for this kit, that is amazing! I remember when the 2 gig came out around $400
    I am Xtreme
    Apr 2005
    Upstate, NY
    Man I remember the original Redlines. Ahh, the 939 era .
    Really awesome RAM though, 5-5-5 – 2.1v – 558Mhz is sick for 4GB
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Mar 2007
    This is basically the same as G.Skill but 60% more expensive, who needs it?
    May 2007
    Yea, but here in Europe they cost about the same.
    DFI Lanparty LT X48-T2R
    Intel Q6600 L737B242 ~ VID 1.2125 ~ 4000mhZ @ 1.48 vcore {lapped}
    eVGA 8800GTS (G92) 512MB {stock}
    Crucial Ballistix PC8500 Tracer ~ 1200mhZ 5-5-5-12 @ 2.05v
    Lian Li PC-V1000 {modded}
    Corsair HX 620W
    Creative X-FI ExtremeMusic
    Western Digital Raptor X 150GB
    Thermalright-Ultra120 Xtreme {lapped} ft. Scythe S-Flex SFF21F S-FDB ~ Push & Pull
    Apr 2005
    Calgary, AB
    Price could actually be cheaper when it is avail retail as well, $175 is just an est starting point. We will see soon enough.
    MB Reviewer for HWC
    Team OCX Bench Team
    Aug 2004
    Finland
    Can you test 5-5-4-x and/or 5-4-4-x settings?
    Asus P5Q Deluxe
    Q9650@4.2GHz, 1.2875V
    2x2GB Mushkin XP6400
    Club3D Radeon 4870X2
    Samsung SATA DVD-burner
    1.25TB HDD
    Chiectec full tower
    Zalman ZM850-HP
    BenQ G2400W
    Vista64 Ultimate
    Watercooled with PA120.3 & BIX3,Laing DDC,Swiftech Apogee GT & EK FC Acetal blocks
    Apr 2005
    Calgary, AB
    IIRC 5-4-4 lost me almost 100Mhz and was more like 450 so its not really worth it. 5-5-4 just dropped a few mhz but made 0 difference in PI. 4-4-3 was ok around ddr810 but again not really a perf boost. 5-5-5 and 4-4-4 are the best on this kit.
    MB Reviewer for HWC
    Team OCX Bench Team
    Mar 2007
    By the way, when testing on Intel P35/X38, the performance level is very important factor and should always be taken into account.
    With performance level 10 or more, it may be possible to tighten some timings, for example tRP may be set to 4 or even 3 for 5-5-4,3-15 et cetera.
    However, it is almost always beneficial performance-wise to have lower performance level over lower timings.
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    124€ here
    ASUS P5K-E // E8400 Q746A519
    G.Skill F2-8000CL5D-4GBPQ
    LC 550W GP// XPERTVISION 9600GT
    Oct 2007
    It seems they don't like high voltage
  18. #18
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by Cronos View Post
    exactly
    why pay more for same chips
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
  19. #19
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    They are more Expensive because #1 Mushkin hand picks and extensively tests the chips to put the Redline name on it and that takes time and is a slower Process and why you think people should work for free is beyond me just cuz you are being cheap and don't want to pay people for their time and labor
    I have owned both G-Skill and Mushkin DDR & DDR2 and Mushkin is better Ram it just does better and yields better results. Although G-Skill makes some damn good memory but if I were choose between the two I would get the Mushkin.
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
  20. #20
    Champion
    Mar 2005
    Warsaw, Poland
    In Europe the purchase of Redlines (in warehouse) is about 20 euro CHEAPER than G.skill...
    MSI MOA 2009 POLAND #3
    Gigabyte GOOC 2010 POLAND #2
    MSI MOA 2010 POLAND - NOT ORGANISED
    ASUS Polish Overclocking Championship 2010 #1
    MSI MOA 2011 POLAND - NOT INVITED
    HWBOT Country Cup 2011 - POLAND! #1
    MSI MOA 2012 EMEA - #1
    MSI MOA 2012 WW FINALS - #7
    ASUS Open Overclocking Cup AOOC 2012 - #1
    HWBOT Country Cup 2012 - POLAND! #2
    MSI MOA 2013 EMEA Qualifier - #2
    ASUS Open Overclocking Cup AOOC 2013 - #?
    MSI MOA 2013 WW FINALS - #?
  21. #21
    Oct 2007
    Quote Originally Posted by Miravo View Post
    Hmm.. The Gskills aren't availible in the Netherlands but in Germany they cost 95 euro.. Ive only seen the Mushkins once, which cost about 120 euro
  22. #22
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    yep Fenom GSKILL is cheaper appx 20-25€.
  23. #23
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by Brother Esau View Post
    I hate to say Brother, but that's complete bunk, and the results in this thread help to prove that.
  24. #24
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by EnJoY View Post
    exactly
    i got no faith in mushkins after 2 dead kits of xp2-8500 they dont justify being more expensive my kingston value ram outlived my munshkins lol
    its not the brand anymore its what they put inside that counts
    n my ballistix pawns every stick i got n i paid 65$ for em compared to 300$ for the mushkins
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  25. #25
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by zsamz_ View Post
    Quoted for truth. Which is one of the main reasons these days, manufacturers do their very best to keep secret the IC's that are used in each of their lines, because once everyone knows what's in every stick, they'll generally go with whoever sells it for less.
