Results 1 to 4 of 4
Thread: Condensation question...
    Jun 2002
    PA
    how much do you have to worry about condensation between +10C and +15C (cpu temps)? the air in the house is conditioned (central air conditioning) if that factors in. thanks
    EDIT: the water will be chilled... no pelt.
    Ritalin Junkie
    Jun 2002
    Spokane, WA
    there will be condensation at these temps, if you do nothing about it.
    but the regular silicone/neoprene/dielectric grease routine -> and you'll be fine
    Jun 2002
    PA
    thanks
    Ritalin Junkie
    Jun 2002
    Spokane, WA
    no problem.
    in case you need a detailed guide on how to do that:
    http://octools.com/index.cgi?caller=...ion/intro.html
