+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 41
Thread: HX620 is making funky noises
    Xtreme Addict silverphoenix's Avatar
    Mar 2007
    41°6′43″N 74°8′45″W
    0
    I had it sitting for about 2 weeks now and hooked it up to a few fans to test them. I 1st used a PSU tester to start it then tried a paper clip. It starts fine and powers fine but there is a clicking noise from the PSU and a slight hissing as well. It's not the fan per say as I have stopped it with my finger and the clicking persists, but when the fan is stopped the rate of the clicks slows down. I've already filed an RMA with corsair but what do you guys think?
    and the question is can I use a spare antec 480 trupower II as a backup for my rig? stock clocks no OC
    Ip35Pro
    4xhdds
    8800GT
    Q6600
    I'll oc again once I get the corsair back.
    Core
    Core i7 920
    eVGA X58 LE SLi
    2x3GB Mushkin DDR3-1600
    BFG 8800GT OC
    Seagate 7200.12 1TB + Maxtor 320GB
    LianLi A05B
    Cooling (all internal)
    2x BI GTS 360
    2x DDC3.2 + Ek top
    EK Supreme LT
    Xtreme Member AngryArtichoke's Avatar
    Jan 2008
    Oregon
    0
    RMA to be safe. I had a PSU that made a slight buzzing noise. I ignored it, and a day later, the thing went *POP*.
    Registered User Swarm dude's Avatar
    Nov 2006
    Zagreb, Croatia, Europe
    0
    I would say that the coils are producing those strange noises. That isn't really for RMA, but maybe something else is causing that sound
    Intel Pentium E2160 @ 3 GHz cooled by CM Aquagate Mini R80 (80 mm Xilence Red Wing) / Gigabyte N650SLI-DS4 / 2 X 512 MB Kingmax / Leadtek PX8500GT TDH/ WD 400BB & Hitachi T7K250 / Enermax SFMA 370W Noise Taker / Chieftec Mesh series case / 3.5" Floppy drive FTW!
    all outta gum G.Foyle's Avatar
    Dec 2006
    Poland
    20
    My HX620 is also clicking. I thought about RMAing, but clicking becomes more and more quiet the longer it's running. It only happens when the PSU is cold and fades away in <1 minute.
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
    Mar 2007
    41°6′43″N 74°8′45″W
    0
    Mine's not too loud but it's high pitch and doesn't go away. I talked to a Corsair tech engineer over the phone, he suspects it may be the coils from my description. Also he approved my RMA instantly so I could ship it out today!!
    So the other question is still can I use my antec trupower II 480?
    Core
    Core i7 920
    eVGA X58 LE SLi
    BFG 8800GT OC
    LianLi A05B
    2x BI GTS 360
    2x DDC3.2 + Ek top
    EK Supreme LT
    Nov 2006
    0
    Yes you can use that Antec. You can RMA the PSU because of the high pitch sound, coils that is?! I guess that Corsail will be having many PSU's coming in for RMA
    Jan 2008
    0
    are there so many hx620's making those sounds? I'm interested in buying this psu, since I've read it's one of the most quiet psu's out there...
    Corsair Rep Yellowbeard's Avatar
    Apr 2004
    1
    Quote Originally Posted by xoqolatl View Post
    In some cases the clicking is from the fan. Try this:
    Power off the rig and obstruct the fan blades with a non conductive object so that the fan cannot spin.
    Power the unit on and see if it clicks.
    Regardless, we'll happily replace the PSU for you if you like.
    Yes, Yellowbeard, a tall rough man with a big yellow beard
    Apr 2004
    1
    Quote Originally Posted by B@gy View Post
    No, these sounds are not typical and overall our rate of problem/defective PSUs is VERY low. You can buy with confidence and if you have an issue, we'll handle it.
    May 2006
    UK
    0
    Mine is practically inaudible, I even checked with my ear right up the back of the exhaust, just a dull hum of air coming through.
    this is 8800GT gaming and OCed quad with Folding in the background
    i5-750 w/ Thermalright Ultra120X
    Coolermaster HAF-932
    MSI GD65
    2x2GB G.skill Cas7 1600MHz
    Sapphire HD6870
    Western Digital 640GB.AAKS
    2x Samsung F1 1TB
    2x Samsung SLC 64GB SSD
    Pioneer DVR-212BK
    Corsair HX620W
    Creative X-Fi Xtreme Music (dead, using onboard -.-)
    LG W2286L
    Jan 2008
    0
    okey, then it will still be my next psu!
    tks
    Hamster Powered SiGfever's Avatar
    Apr 2006
    Virginia, USA [Krunching since 2001]
    7
    Quote Originally Posted by Yellowbeard View Post
    Now this is what you call Great Support from a company.
    XSWCG Disclaimer:
    We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
    Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
    Mar 2007
    41°6′43″N 74°8′45″W
    0
    yep great support. I called up corsair they hooked me up with an RMA technician that I explained clearly the "symptons" and he said he'd approve my RMA right there. So I had the PSU shipped within 2 hours of submitting the RMA!!
    Core
    Core i7 920
    eVGA X58 LE SLi
    BFG 8800GT OC
    LianLi A05B
    2x BI GTS 360
    2x DDC3.2 + Ek top
    EK Supreme LT
    May 2006
    UK
    0
    Quote Originally Posted by SiGfever View Post
    its almost unbeatable if you live stateside, its more troublesome if you live in say Europe/UK and need to ship the PSU back to Corsair direct
    MSI GD65
    Sapphire HD6870
    2x Samsung F1 1TB
    Pioneer DVR-212BK
    Corsair HX620W
    LG W2286L
    Xtreme Member De1337's Avatar
    Nov 2007
    Denmark
    0
    Quote Originally Posted by LuckyNV View Post
    word up
    CPU: Intel Q6600 @ 3.2 Ghz
    GFX: HIS Radeon HD4870X2
    MB: ASUS P5E (0702)
    RAM: 4x 1GB PC2-6400 Corsair DOMINATOR + Fan
    Timing: 4-4-4-12
    PSU: Corsair HX1000
    HDD: 2x WD2500YS 250GB 16MB RAID0 + Samsung 500GB HD501LJ
    Case: Antec Twelve Hundred
    Apr 2004
    1
    Xtreme Cruncher Xcel's Avatar
    Feb 2007
    0
    I have a questing regarding noise as well. This is as good a thread as any. I currently have a Nexus 4090 PSU which humms/buzzes somewhat, under load and only then at ~250-300w.
    I'm wondering how silent the Corsair PSU generally are? I'm especially interested in the VX550, does it make any sound at all except the noise from airflow?
  18. #18
    Apr 2004
    1
    Very quiet. The 550 noise level is virtually identical to the VX450. More info here at Silent PC Review:
    http://www.silentpcreview.com/article699-page1.html
  19. #19
    Feb 2007
    0
    Thanks for the quick answer I have no experience of your products but you seem to have great support! Looks like it'll be a Corsair product for me when I upgrade my PSU.
  20. #20
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    44
    I can vouch that both the HX620 and the VX450 are dead silent. Amazing PSUs. if the VX550 is about the same as the 450 then that is totally awesome.
    The Cardboard Master
    And put that GPU to work too! Fold for XS
    Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
    Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
    Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
    Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
  21. #21
    Dec 2006
    0
    so silver what was the outcome of this issue??
    I have an IP 35 Pro and HX 620W Psu and I have the buzzing noise.....OVer the weekend I will try a new psu see if it helps if it does I guess I will have to RMA the corsair....I have been doing research and looks like quiet a few people experience this buzzing sound with this combo....
    Intel I7 2600K @ 4800 MHZ | Corsair H80
    Asus Maximus IV Gene-Z
    16 GB Corsair Vengeance LP DDR3 1600
    eVga GTX 480
    Creative X-FI Titanium HD
    Crucial M4 128GB SSD | Crucial M4 64GB SSD| 1 TB Samsung F3
    Silverstone TJ08-E | Corsair AX850
    HEAT: http://heatware.com/eval.php?id=20134
  22. #22
    SR-2 up and running! jcool's Avatar
    Oct 2007
    Stuttgart, Germany
    1
    I wish Corsair Germany would be that great with RMAs. We have sent back several HX because some of them had defectice fans making very annoying clicking sounds, and guess what... the guy honestly told me he didn't hear a thing
    Now, either he was deaf, or he just didn't want to replace the fans. I don't know, but in any case sent them back to our distributor and got new ones from them
    World Community Grid - come join a great team and help us fight for a better tomorrow![size=1]
  23. #23
    Mar 2006
    Ohio, USA
    44
    Sure the buzzing comes from the PSU not the mobo? Thought mine was buzzing at first until I realized it was just coil noise from the mobo (which I've not heard for a long time now actually).
  24. #24
    Dec 2006
    0
    I guess I will find out on Saturday what is causing it
    eVga GTX 480
  25. #25
    May 2006
    UK
    0
    Quote Originally Posted by Volkswagen View Post
    I have this combo, no buzzing
    I DO get buzzing with Supreme Commander Forged Alliance but this is coming from the motherboard, and yes it definitely is the board since my PSU is bottom mounted.
    MSI GD65
    Sapphire HD6870
    2x Samsung F1 1TB
    Pioneer DVR-212BK
    Corsair HX620W
    LG W2286L
+ Reply to Thread
