Antec P182 front panel audio and asus Maximus Extreme MoBoard
Sorry if posting in wrong place ? got a question about chassis and Mobo compatibility ..
- Thought may be somebody here maybe have had already experience with this similar problem?
I am in situation – I have Antec P182 chassis(case) and just finishing installing Maximus Extreme mobo inside.
I cant find a place - where to attach front-panel Audio (mic, ear-speakers) internal connectors to the mobo?
aka there is NO such pins (male plugs) on mobo - what will match with the Antec (wire) connector plugs
That Maximus Extrme. board (by Bios options!) - and also Antec p182 chassis
(tested with earlier p5K3-dlx board setup), - both should have support for AC97 either HD Audio for front panel !
So - but there is only an ‘’uncovered’’ area ( by manual hand-book )..
(see this area attached img. - this is the 16(15) pin male plug ( 15 pins in row array) connector below the 3rd PCI-E slot
Larger pic. Link: http://img85.imageshack.us/img85/336...nnectoref2.jpg
The case wires can be attached to some of these pins - by leaving some pins un attend, -
( if looking at the combination of ((Antec factory closed )) pin-holes in plugs,
and also see the ‘’NO PIN ‘’ ((missing one pin in lower row )) on the board ..
unfortunately I didn’t find a any single word /note in manual book, saying about
that connector on maximus board ( may be I’m badly missing smth?
any way I will not go for ‘blind probe method’ - just don’t want to blow up these things for fun LOL
any ideas ? if there is any suggestions, tips or links to this topic .. please let me know
Thank You in advance !
