::|:: Asus P5E WS Pro ::|::
Click the thumbnail to view full-size image
System
Code:M/B:Asus P5E WS Pro rev. 1.01G, Vcore mod. CPU:Intel Core Extreme QX9650 L739A643 CPU cooling:2 Stage Cascade "Petite Bertha" (~0.6bar to 0.5bar evap pressure, i.e. -112C to -115C loaded) Memory:SuperTulip Gardena PC2-5300 512MBx2 VGA:Jaton 7600GS HDD:Western Digital 80GB Power Supply:Cooler-Master 1250W Vcore:1.832V to 1.920(CPU-Z) Vdimm: 2.60V(Bios) Vmch: 1.77V to 1.91V(Bios) Vpll: 1.64(Bios) OS:Windows 2003 Server
I've just started playing with this board and trying to find how to use it correctly.
It seems me a bit tricky actually. But, I've to say it gives the best FSB results for this QX9650. Until now, I've never had the opportunity to bench it above about 458FSB but the P5E WS Pro brings it up to 467FSB stable for Spi 32M.
I've to perform some more investigations on straps and dividers functionning. Strange things happen... It can't boot on strap 266 @420FSB but does it easily @430FSB :p Also, at those clocks while using strap 266, memory dividers won't work and it's required to let this setting to Auto. That's a bit weird because Auto setting results in 2:3 ratio and that means a very high DRAM frequency.
Vcore makes the board stopping at 1.92v...![]()
To be continued.
I've just ordered same mobo but DDR3
My Maximus Extreme died during this little oc week with kj and boby, I think this
530FSB with only 1.4V @ nb ... Wow, you must have bought several of them ...
