Adding new components, 2 loops?
Hi guys.
I'm looking at adding another rad and a couple more blocks to my loop(s) and would like some advice on which blocks to have in which loops. First of all, let me tell you how I am currently set up:
Pump (DDC3.1 with PTS top) --> CPU (FuZion) --> Chipset (MCW30) --> GPU (MCW60) --> Radiator (PA120.2) --> Resevoir (MCRES)
So I have gotten my hands on an MCR320QP radiator and want to add it to my loop, and also a couple of EKMosfet ASUS1'se mosfets around the CPU socket. I think two loops would be best, and if another DDC3.1 and PTS top.
My main question is, which components should I put in which loop with which radiator?
Ok, in my opinion, you should put the CPU and northbridge on the PA120.2 and the rest on the MCR320. Maybe the other way (both radiators is good with the MCR320 a hair better with the right fans).
- You may not post replies
- You may not edit your posts
Forum Rules
