I want to ask you if the QX9650 ES cpus are more overclockable than the retail/oem ones,because I found someone that sells a couple of them sealed,with the original cooler.
this really sucks,considering you cannot make a good overclock even on the extreme editions,after you pay a ton of money for an unlocked multiplier
^Well it's like the lottery you got many chances out there but only a few lucky one get the very good ones! I was under the assumption that overall ES do a bit better then Retail?
ES are the same C0 revision like retail?
Also,Intel does not pre-test extreme edition versions so they overclock much further with the unlocked multi,considering they cost so much?
I really dont get what youre trying to say
I dont think it matters if its retail/oem/ES, and yes they do overclock well....
My oem... http://valid.x86-secret.com/show_oc.php?id=292456
It really is a lottery, ES/retail/whatever. My brand new QX9650 retail does 4.5GHz Pi 1M/4.4GHz Wprime at 1.392V.
QX9650 L740A 4GHz @ 1.25V aircooled
8GB Team Dark DDR2-1066 @ 5-5-4-15 @ 2.00V
Asus P5E 1.41V vNB
GTX280 1GB 600/1450/1200
WD Raptor 150GB + 2*500GB WD
Pioneer 212D
Corsair HX620
Antec P182
Dell 2407
what the general max fsb on the new 45nm quads if anyone knows?
thanks
Once intel started binning for 9770's I think then it is pretty safe to say that most 9650 ES's will be better than the retails or OEM's, or for that matter 9770 ES's. However, when the top of the line model first comes out, with no higher chip in ES sampling, then it is pretty much luck of the draw.
{2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
