Yeah wtf is that square I have it as well.
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
It's spying on you.
Fold for XS!
You know you want to
*I can't see the square normally but if i minimize and maximize a window quickly it can definitely see it in that corner.
*Color bug still remains for me, running Single card 3870 WinXP 32.
Gigabyte Z77X-UD5H
G-Skill Ripjaws X 16Gb - 2133Mhz
Thermalright Ultra-120 eXtreme
i7 2600k @ 4.4Ghz
Sapphire 7970 OC 1.2Ghz
Mushkin Chronos Deluxe 128Gb
i have the square also, but if i take a SS its a grey square
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
who programs these drivers...
really...
what good are 2FPS extra in games if u get what looks like a perfect gathering of 50 dead pixels on your screen and wrong color on web browsing that just wont go away.
Gigabyte Z77X-UD5H
i7 2600k @ 4.4Ghz
I have just installed the 8.1 catalyst (not the hotfix version) on XP x64 and I do not get the wrong colors in FF nor am I getting that square.
But I still would like clarification: Which drivers are newer? The official 8.1 or the 8.1 hotfix? There have been reports going either way. Please someone verify this by checking the version numbers listed in CCC, not what windows might tell you.
Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
—Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
so far what I see is peeps with P35 boards not seeing any improvement
in Crossfire with this patch. But could someone with an actual 790FX
chipset please report back as to any performance increase?
(in-game performance please, not benchmarks...)
TY
EBL
Yes Drivers Rock Crysis is now Playable!
SuperMicro X8SAX
Xeon 5620
12GB - Crucial ECC DDR3 1333
Intel 520 180GB Cherryville
Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
Here is My first Official Result......My $50.00 CRYSIS game is Now Playable
SuperMicro X8SAX
Xeon 5620
www.teampclab.pl
MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
Test bench: empty
>i5-3570K
>Asrock Z77E-ITX Wifi
>Asus GTX 670 Mini
>Cooltek Coolcube Black
>CM Silent Pro M700
>Crucial M4 128Gb Msata
>Cooler Master Seidon 120M
Hell yes its a mini-ITX gaming rig!
Link:
AMD Customer Care Site Map > Radeon Support - PC > Radeon HD 3870 > Knowledge base > Gaming > Gaming
Link #16 is: Catalyst 8.1 hotfix
And disabling tray menu helped.
www.teampclab.pl
Test bench: empty
No I actually mean its playable! After the First Alien Encounter with the Frozen ship it all started going down hill and getting laggy and unplayable which ultimately led to Hard Locking when saving game or reaching check points right before and after excavation site and then it would go no further that was the cut off with my game play with patch 1.1 & CAT 7.12 but now its all good
SuperMicro X8SAX
Xeon 5620
man this is disappointing.
looks like no go on 2900pro cf
So that is what was causing the funny colours! I actually found it a little useful, as it would highlight searched terms but prefer the default settings. I will install these drivers tonight, I wonder if they fixed the Overdrive settings, as 7.12 would take my card's core up to 945Mhz before restarting. It would then crash every time the drivers tried to load when rebooting, necessitating booting in safe mode and reinstalling the drivers.
I MSI P67A-GD65 I Intel i5 2500K I 8Gb Samsung I
I Corsair F3 60Gb I AMD 6850 I Dell SP2208WFP I Windows 7 x64 I
I Current Speed: 4.5Ghz I RAM 1866Mhz @ 9-9-9-27 1T I
I Laptop I Acer 1830T I Intel i5-470UM I Crucial M225 I 4Gb DDR3 I
Bro. Esau,
I see you are using Powercolor 3870s. I only have one but it has that core 860 limit. Do yours and if so, did you flash them? And if so, did that take care of the problem? My friends Sapphire didn't have the problem, yet the Powercolor tech tells me that all the companies get the same bios from ATI.
thanks
Gigabyte MA790FX DS5 - 5000BE AM2 (3.1)
Asus 6850 - Crucial Balistix 5-5-5-24
Corsair 550 PSU Zalman 7000Al Cu
Try the 'Sapphire' bios then, see http://www.xtremesystems.org/forums/...d.php?t=173510 for link.
System Specs: * i7 2700K @ 4.8 Ghz * Zalman CPNS9900-A LED * Asus Maximus IV Extreme -Z * 16 GB Corsair Dominator GT CMT16GX3M4X2133C9 * Sapphire HD7970 crossfire * Creative X-Fi Titanium Fatality Pro [PCI-E] * Corsair AX 1200W * WDC WD1002FAEX + WDC WD1002FAEX * Optiarc AD 5240S * Dell U3010 @ 2560 x 1600 [DVI-D] * Steelseries 7G * Logitech G9 * Steelseries SX * Coolermaster Stacker STC T01 * Logitech Z-5500 * Sennheiser HD598 * Windows 7 Ultimate x64 SP1*
So what's the final verdict on the firefox colour bug? Also WTF with that tiny square? Spyware??
Gigabyte Z77X-UD5H
i7 2600k @ 4.4Ghz
No luck with these drivers and 2900xt's for me, not sure if its cause I have overclocked or what, but 7.12 made my max oc w/o instability 850 core, now I have no idea.
I am going back to 7.11 so I can get my 950 game stable again.
These ones 3dmark06 is like half the screen is not in sync with the other half. Same with games.
Need Help With Your Mushkin Memory? Send Me a Email greg@ ...
System - Q9650@4.41Ghz 1.43v, Swiftech GTZ water block, Mushkin XP3-12800 2x2GB @ 1633 7-7-7-20 1.8v, 7200.10 6X250GB Raid 0, eSata 250GB 7200.10, Asus Rampage Extreme ,Mushkin XP-800AP , Palit 4870x2 @800/4000 (256/320 2D) ,(2)PA 120.3, 6 Ultra Kaze 2000RPM, (2)MCP 655, EK Multi-Res, Mountain Mods Duality Case, Onkyo TX-SR576 AMP, Sennheiser HD555,
SLY FOX
Just a few questions: When you go into GPU-Z, what does it say for crossfire? Does it say "enabled" using 1 GPU, "enabled" using 2 GPUs. I ask cause you and I had the EXACT SAME ISSUES Prior to my Asus Maximus X38 motherboard that im using now, I was using my trusty P5K-DLX P35 motherboard with the 16x 4x limitation. When using x-fire on the P35 chipset, GPU-z would report CROSSFIRE as "ENABLED" using "1" GPU . Which if you ask me doesnt sound right , how can x-fire be enabled, but use only 1 gpu? My 3dmark scores were only 15xxx and that also couldnt be right. Games plays laggy, and over all, my single 8800GTS 640mb card provided a better and smoother gaming experience. I got so fed up with the crap, that I took a chance and "rolled the dice" with a X38 based chipset motherboard in the hopes that this could fix my issues. I ordered my current motherboard which is a Asus Maximus Formula X38.
After doing a fresh format of XP home 32bit, installing the newest intel INF drivers, latest DX update, and (at that time) the 7.11 driver (7.12 sucked) reboot, enabled x-fire in CCC, reboot again, installed GPUz and BAM!! it now reads "CROSSFIRE ENABLED using "2" GPUs . I said to myself, now this makes sense . I overclocked all my cards to 860c/2600mem, then rebooted again.........INstalled 3dmark06 and achieved my score of 20,600k Now isnt that better? games played great (UT3, HL2 EP2) and I am really happy with the purchase of the X38. Try it if you can.
Nothing anymore
