I need to fit a 3rd loop in my Lian Li PC-7+II
CPU - Thermochill PA120.2, mounted in the roof
NB/SB/Mosfets - Thermochill PA120.1, mounted on the front intake fan
Both use fill ports mounted infront of the Thermochill PA120.2 in the top
Pumps are DDC's, 18w for CPU and a 10w for NB/SB/Mosfets. Probs use a 3rd DDC 10w for the GTX
I need to WC my 8800 GTX. Now i did think of thus
Rad on the bottom of the case (case is on V2K wheels), though of a BIX as i'd seen this one done, rad is thin which is ideal for the space there!
Other ideal was to remove the exhuast fan, fit a 120.1 there and the exhauast fan on the outside of the case. This gives me 25mm of room to play and still keep all the WC within the case like what i want!
What do you all think?
I'm really stuck for cooling this GTX. It's already under water ad i want to keep it that way as the plan is to have this rig totaly silent
Pete
