Back on topic, it wouldn't be a good idea spray water on it.
I would just use a compressed air or a vacuum to clean the PSU - like the
previous posters have suggested.
i agree serial, i mean how dumb can you be to clean a PSU, that is not meant to be cleaned in the first place, let alone by means of High Pressure Water, thats just plain DUMB if you ask me.
how ever, if you dont mind voiding your Warrenty on your psu, then by all means, unscrew the 4 screws and remove the cover, and used compressed can air or air compressor to blow dust and dust bunnies out of it and while doing this, hold onto the fan as any high pressure on the fan can cause it to spin and damage your bearings.
*I'm not held responsible for anyone getting hurt or killed in the process of my info im sharing on cleaning psu's, as they can still hold a charge and will kill if you touch the wrong part inside the psu.*
Little Mean Red Machine:
2008 Saturn Astra XR|Salsa Red|2dr Hatchback|1.8L 140HP 4cyl|5-Speed FWD
Main Box:
ABIT IP-35Pro XE|Intel C2Q 3.2GHz|Zalman 9900|4GB Corsair Dom. DDR21066|ATI 5770 |SB X-Fi XM|2x W.D.V.R. 300GB RAID 0|S.B. 320GB|2x TSSCORP SH-S223B|Antec P193|Antec TPQ 850W|2x Samsung SyncMaster P2350 HD 1080P|G15|MX1000&G5|Win7 RTM Pro X64
Spare Box:
ABIT IC7-G MaxII|Intel P4 3.2GHz|Zalman 7700CNPS-C|2GB OCZ HP DDR400|ATI 9800XT|W.D.C. 40GB|W.D.C. 250gb|Antec
Neo480|WinXP Pro SP3
"Foldin, Foldin, Foldin...keep those benchers foldin..." (Lyrics by Angra, Music is Rawhide)
BOYCOTT MIR's
.... this is something you'd find at other forums.
a vacuum is ideal, but a slightly damp cloth/papertowel for the outside/ bare metal is fine.
show me a pic of you washing the psu with the electric on .. lol
just tolerate with the little dust & grime ... open it and make a quick clean with some tissues .. why bother risk short circuit ur psu with rusted electronics .. not to mention burning your whole house if it give sparkies
This thread is a joke, right...?
Project ZEUS II
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
2 x Asus HD 6870 CrossFire @ 1000/1100MHz
OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
Watercooling setup:
1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
Assembled in Mountain Mods Ascension Trinity
Powered by Corsair Professional Series Gold AX1200
sorry but this is 1 of the " " threads I ever seen @ XS, u should have know that there is no way elektricity & water would work together .....except u want to ruin it. Cant believe it u actually did what u were planning to do!
• DFI Lanparty LT X48-T2R
• Intel Q6600 L737B242 ~ VID 1.2125 ~ 4000mhZ @ 1.48 vcore {lapped}
• eVGA 8800GTS (G92) 512MB {stock}
• Crucial Ballistix PC8500 Tracer ~ 1200mhZ 5-5-5-12 @ 2.05v
• Lian Li PC-V1000 {modded}
• Corsair HX 620W
• Creative X-FI ExtremeMusic
• Western Digital Raptor X 150GB
• Thermalright-Ultra120 Xtreme {lapped} ft. Scythe S-Flex SFF21F S-FDB ~ Push & Pull
Really not a clever idea really but seeing as you have done it anyway you will just have to make sure that it is completely dry before powering it up. I would put a hairdryer over it for atleast 30mins after letting it dry for a couple of days.
...and the Muppet of the week prize goes to.....
X5670 B1 @175x24=4.2GHz @1.24v LLC on
Rampage III Extreme Bios 0003
G.skill Eco @1600 (7-7-7-20 1T) @1.4v
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Intel X25-E SLC RAID 0
Samsung F3 1TB
Corsair H70 with dual 1600 rpm fan
Corsair 800D
3008WFP A00
this is an insane idea you have proposed!
Get an aerosol duster and blast the dust out.
If you do decide to wash your PS (Cough, like a toaster in a bath tub) and we don’t see you here on XS for a while I think we will all come to the conclusion that maybe this wasn’t such a good idea after all...
just Plz discharge any capacitors before dunking it in water!
Current System Build
Designaton:" Rad Hat "
__________________
Flow Order: >> Rad's 1 & 2 in parallel > Res > Pump > CPU > GPU > SB > NB > Mosfet 1 > Mosfet 2 >>
- Mother Board, RAM and CPU:
Mobo: Asus Maximus Formula (SE) BIOS 1207 | CPU: Intel q9650 @ 3.80GHz Vcore 1.272v | RAM: Crucial Ballistix Tracer PC2 8500 4x1GB- Graphics Processor:
GPU: BFG 8800GTX | BFG 8600GT (Quad Monitor Setup)- Hard Drives:
RAID: 2x 74GB Raptors on RAID 0 for OS Drives
- Case and Power Supply:
Case: Antec Case | PS: OCZ ProXstreame 1000W- Water Cooling:
Pump: Swiftech MCP655-B | Rad: Dual Swiftech MCR320's | Fans: 6x Yate Loon D12SH-12's (W/ Variable RPM Rheostat) @ 88CFM Max Each - 528CFM Total!!!- (Water Blocks and Fittings):
CPU: D-Tek Fusion Block | GPU: Danger Den Full Coverage 8800 Block | Mobo: EK's Mosfet, NorthBridge and SouthBridge Blocks
Res: Swiftech Micro | Tee's: 4x MartinM's High Flow Copper Tee's | Elbow's: None | Y's: None
Temperatures: CPU: 57°C Max, Running Prime95 | GPU: 58.3°C Max, Running 3Dmark | NorthBridge: Untested!
Last Updated 11/11/09
I might be mistaken in this but I believe you should plug the PSU into a GFCI protected outlet (with the little reset switch) when you try your "test run". Just in case. And just in case, don't wash the GFCI outlet with high pressure water if it should be dirty. Use a fine mineral water with a lemon or lime flavoring- It'll make your charred corpse smell better to your next of kin or fire/rescue workers. And just for craps and giggles- when me and my cousin were younger ( about 6-7 yrs old) and we were playing in his father's shop, he got the bright idea to bend a clothes hanger into a U shape and then proceeded to plug it into a wall outlet. All I'll say about that is thank god for breakers and an Uncle who was willing to reinforce lessons with a serious ass-beating. And before you think he's the stupidest kid in the world, I'll have to share his next adventure that only happened a couple of years later. He and a friend were playing with a lighter. "SO?" you might say, that's normal I did stuff like that- WELL, he and his friend were experimenting with the lighter by burning the plastic case on the gas meter on the outside of an elderly neighbor lady's house. WOW! You say, he really is a stupid f**K!!! IT GET'S BETTER!!!! When the paint on the plastic gas meter cover began to burn and spread to the painted gas pipe that ran 2-3 feet out of the top of the meter and into the brick on the side of the house the two geniuses decided it was time to put the fire out. "Really? How did they put the fire out?" you ask. They used the only tool they had on them, the baseball bat that they had been using at the park just up the street. My cousin banged the pipe several times with the bat until it cracked a hole in the pipe and partially dislodged it from the meter. This created a fire-hose which sprayed the side of the lady's house with a huge flame that luckily did nothing but scorch the paint and brick on the side of the house. If neighbors hadn't been watching them and calling the police those morons would've had to explain why they burned down a nice old lady's house and possibly themselves. For that lesson my Uncle had my dumbass cousin hold a piece of burning newspaper until it was getting close enough to burn his hand. My cousin started slobbering and crying asking what he should do because it was getting hot, and my wise Uncle just said , "Drop it you f**king moron!!! Never play with fire." Don't worry, my cousin finally stopped getting into trouble after he and the same friend had to have their stomachs pumped because they decided it would be a good idea to drink water out of a hose that was running from someone's backyard. Turns out that hose was someone draining their pool after the summer. And yes he is my cousin, but thankfully I was adopted and I DO NOT SHARE his DNA. THANK GOD!!! Don't be stupid.
EVGA 680i
e6600 + 2gb Dominator 6400C4d
EVGA 8800 GTS
OCZ 700w Gamestream
2 Seagate 120 gb SATA 7200 rpm RAID 0-WinXP Pro 32
Lian-Li PC-V2000
DARE TO BE STUPID!!!
If I were you I'd be doubly sure and blow dry it FIRST so that nothing inside rusts. THEN let it dry out for a few days and maybe give it another session of the blow drier.
CPU: Q6600 @ 3.6ghz G0 Week 37B
Mobo: Asus P5k Deluxe
Cooler: TRUE 120 (150cfm Delta)
2xHR-05
2xHR-09
Mem: G.Skill 4x1Gb 6400HZ
Vid: HIS 4850
HDD: 80Gb 16mb Cache Raptor
500Gb 7200.11 Seagate
PSU: Enermax Noisetaker 600w
Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
3dmark06: 16k
BOYCOTT MIR's
It's ok to clean it with soap and water. I've done it number of times with motherboards and graphics cards. Make sure it's completely dry before turning things on. Only thing that you should be worried about is the rust that in some situation might occur.
Q6600 3.6Ghz @ 1.276v | DFI LP LT P35 | Ballistix Tracer PC2-8500 600Mhz @ 2.074v | GeForce 260 GTX | Auzen X-Fi Prelude | PCP&C 750 | Arch Linux ~ WinXP
AMD Athlon 64 X2 3800 | DFI LANParty NF4 SLI-DR | 2x512MB G.SKILL PC3200 BH-5 | OCZ PowerStream 520W | Palit GeForce 9600 GT | Gentoo
Long Live DFI.
Any news on the PSu yet?
t00l of the week award, thats what we called where I used to work.
Everyone says what will happen... He does it anyway, and what do ya know? his power supply doesn't work.
I think it was a joke, or some one needs to do a few days in junior highschool physics or science classes. And possibly some common sense classes.
But this wasnt because he "had" to if i understand correctly it was just dusty.
Plus he wasn't using water at tap pressure, he was using a high pressure source, I don't know what you would call high pressure, but our pump even without a gerni on it would blow the capaciters off. No to mention the the possibility of electrolosis over time, and corrosion and rust and what ever else.
There is a difference to do something to strick rules and stardards and with some back ground knowledge than there is to picking up a hose and giving you PSU the old blast. Not to mention relying on it being dry in 5 hours after being told not to turn it on in less than 2 days.
You need to create a positive pressure situation to keep dust to a minimum. Try installing some intake fans that provide greater CFM than your exhaust CFM.
Asus P5Q Deluxe (P5QD1406) || Q9400 at 3.4GHz || 2x2GB Mushkin Redline PC2-8000 || HIS HD 4870 1GB w/ Scythe Musashi (silent) || 501GB Samsung HD || Zalman ZM850-HP || Antec P182 || Windows 7 x64 RTM
