I bought one recently and obviously it only comes with two fans (back fan which extracts and a fan cooling the GPU). Now I have two fans above the CPU socket. How should I configure it?
Furthest to back = extract
Closest to front = intake
Q6600 @ 3.2\ Corsair 2*2gb\ 8800GTX
dude, i love that case! totally will be in my next build. both exhaust, warm air rises. negative pressure inside the case is better than positive.
Case-Coolermaster Cosmos S
MoBo- ASUS Crosshair IV
Graphics Card-XFX R9 280X [out for RMA] using HD5870
Hard Drive-Kingston 240Gig V300 master Seagate 160Gb slave Seagate 250Gb slave Seagate 500Gb slave Western Digital 500Gb
CPU-AMD FX-8320 5Ghz
RAM 8Gig Corshair c8
Logitech 5.1 Z5500 BOOST22
300Gb of MUSICA!!
Steam ID: alphamonkeywoman
http://www.techpowerup.com/gpuz/933ab/
I have seen a threat with a similiar question but with a TJ09, and the guy's CPU temp dropped 5 degree by putting the top fans on intake. Nothing on GPU temp with that setting but definitly worth a try!
Will be interested to hear what you find works best, Robertus. I've got this case and some extra fans on order as well.
Experiment with different fan layouts, use whichever works best for you.
Rig // PC-A7010 :: Revo85+ 1050W :: Rampage :: Q6600 :: 8GB Redline :: GTX 260
Raptor-X RAID-0 :: 4x WD1001FALS RAID-5 ARC-1210 :: 2x WD1002FBYS RAID-1 :: 3x WD15EARS :: 7 Pro x64
2408WFP :: G15v2 :: G5v2 :: Auzen Forte :: DT770/80 :: Onkyo TX-SR605 :: Klipsch RB-61 :: SVS PB10-NSD
if you get a TRUE cpu cooler and put 2x 120 mm fans on the true and the top 120mm fans on top of your case put it as outtake fan to take the air out that would be a killer kooler
Mobo::::::::::::::::: Gigabyte X38-DS4
Cpu::::::::::::::::: q6600 2.40 ghz
hd:::::::::::::: SeaGate sata 320x2gb 7200rpm
Gpu::::::::::: GeForce 8800 GTS 512mb
Ram::::::::: A-Data 800mhz DDR2 4Gb
Psu:::::::: Thermaltake ToughtPower750 watts
Case::::: Antec 900
mice:::: LogItech G5
Cs::::: Stock
Kb:::: Logitech G15
mon: 19inch Vw192 Asus LCD
Hmmm...
I think both fans are on intake and so far:
GPU Diode 80c
CPU 50/50/45/45 (running wow in the background/60 processes/vista 64)
My case isn't far from a radiator pipe which will have an effect, but even with the rad off temps are still highish. I probably need to remount my HS but I can't be bothered :/
Also a tad disappointed about my GPU temps - fan is at 60%.
Edit: Does daisy chaining fans have an adverse effect on RPM? I have two yate loons connected to one molex via the two 4 pin M/F connectors and the other two molex cables are used (one on CDROM and another on something else).
Shazza, I was going to do the MM thing but I have decided to get the J10. Was just curious what fans did you order for yours?. I was thinking about some Silverstone High CFM fans and putting them on a fan controller. Was just curious what you ordered or have any other thoughts.
whats the difference from the TJ10 and TJ9?
Nikon User
Nikon D200 (Gone =( )/D300
Nikkor 18-105mm(Gone) // Nikkor 50mm 1.8 // Nikkor 55-200VR(Gone)
Tokina 12-24 // Tamron 90mm //
Manfrotto & Benro Legs // Benro Ballhead.
Current Lust = 80-200 Or 70-200VR1 <--Pending
No more computer parts for me... Well for now until I
really REALLY need to upgrade.
TJ-10 is simply moar sexy than TJ-09.... That's why I got it
I had only one spare 120mm around so I put it in the first top slot and made it exhaust. Ive the TRUE and it blows air out already in the direction of the open vent. The 120mm fan takes out more heat above RAM section. No idea if it actually works but I dont care.
Though I do think it's in general better to have them both exhaust. CPU temps might decrease but what about other heat building up in the case?
Synaptic Overflow
CPU:
-Intel Core i7 920 3841A522
--CPU: 4200Mhz| Vcore: +120mV| Uncore: 3200Mhz| VTT: +100mV| Turbo: On| HT: Off
---CPU block: EK Supreme Acetal| Radiator: TCF X-Changer 480mm
Motherboard:
-Foxconn Bloodrage P06
--Blck: 200Mhz| QPI: 3600Mhz
Graphics:
-Sapphire Radeon HD 4870X2
--GPU: 750Mhz| GDDR: 900Mhz
RAM:
-3x 2GB Mushkin XP3-12800
--Mhz: 800Mhz| Vdimm: 1.65V| Timings: 7-8-7-20-1T
Storage:
-3Ware 9650SE-2LP RAID controller
--2x Western Digital 74GB Raptor RAID 0
PSU:
-Enermax Revolution 85+ 1250W
OS:
-Windows Vista Business x64
ORDERED: Sapphire HD 5970 OC
LOOKING FOR: 2x G.Skill Falcon II 128GB SSD, Windows 7
I was planning to do the same ... except I picked Silverstone Med CFM fans with a controller - and I have some Yate Loons I was going to experiment with as well. But, just after taking delivery of the TJ10, the Lian-Li 343B came in stock, so I returned the TJ10. It is a very nice case, I just wanted something a bit different.
