+ Reply to Thread
Results 1 to 10 of 10
Thread: Best Power Supply 2+ 8800 GTX
    Dec 2005
    0
    I've run into a problem getting a power supply to run 2 8800 GTX with my dual water cooling loops.
    I currently have the Silencer 750W PC Power&Cooling PS but it doesn't have enough power.
    Equipment:
    Intel G0 Q6600
    evga 780i motherboard
    2 x nvidia 8800 GTX
    2 x 1GB Mushkin 8500 DDR2
    2 x Swiftech 655 pumps
    8 x 120mm fans (push pull, 2 radiators)
    2 x WD Raptors in Raid
    I prefer not to have multi-rail low current.
    So I need some expert help. I've heard that the 1200W PC Power & cooling wasn't all it was hyped to be. What power supply is best?
    Thanks,
    -Malt
    Xtreme Addict Frank M's Avatar
    Aug 2006
    eu/hungary/budapest.tmp
    0
    Seasonics have low noise and a single 12V rail.
    Don't know about their higher-power models, though, but I like my old S-12.
    Usual suspects: i5-750 & H212+ | Biostar T5XE CFX-SLI | 4GB RAndoM | 4850 + AC S1 + 120@5V + modded stock for VRAM/VRM | Seasonic S12-600 | 7200.12 | P180 | U2311H & S2253BW | MX518
    mITX media & to-be-server machine: A330ION | Seasonic SFX | WD600BEVS boot & WD15EARS data
    Laptops: Lifebook T4215 tablet, Vaio TX3XP
    Bike: ZX6R
    Dec 2007
    0
    antec truepower 850 watt or 1000 watt should work fine with dual 8800 gtx's and all those requirements you listed. Has 4 12v rails and they all work GREAT for what you need (personal expirence) has some 6+2 pins aswell if you have anything that needs it or you can use for a future gpu...also its modular so you can use the cables u need and not the junk you dont
    850 watt is about 230-260 u.s. dollars depending where you shop around....i got mine on sale for 137.99 but it was a 2 hour sale...the 1000 watt one is 300+ dollars...good LUCK
    I like turtles
    Xtreme Member joecop120's Avatar
    Jun 2007
    IL-USA
    0
    You could purchase a small auxilliary power supply that could power HDD, fans, and pumps to relieve the 750 watt one. Something like the Ultra Power Partner or Thermaltake Purepower express.
    "Two pentium 4's would make a great miniature George Forman grill!"
    http://heatware.com/eval.php?id=58394
    Xtreme Mentor Nate P.'s Avatar
    Sep 2007
    Monterey Bay, Calif.
    0
    PC Power and Cooling PSU's are the best! Something like their 750 or 1000W models would be ideal.
    c[_] STEvil's Avatar
    Nov 2002
    Alberta, Canada
    19
    Quote Originally Posted by pika198 View Post
    Actually if you open them up they have 2
    Based off nearly the same units as the Coolermaster Realpower Pro 850/1000/1250 series.. Antec 850's a bit weak but 1KW is nice... and decently priced, too. Paid $229 for my 1KW
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    Xtreme Cruncher Polizei's Avatar
    Nov 2006
    'burb of Cleveland, Ohio
    1
    Your PC P&C should not be having problems with that system.
    Describe the issues youre having.
    I am Xtreme
    Aug 2006
    0
    PCP&C 1200W is over-hyped ? Are you sure ? Its about the best there is. Expensive, but can you find a 1200W PSU that is cheap ?
    Oct 2007
    Toronto, Canada
    0
    the 750 should be powering ur system, something must be wrong
    Intel Q6600 (Stock for now)
    Scythe Infinity
    XFX 680i LT
    OCZ 2 x 2GB Platinum DDR2 800
    EVGA 8800GTS 640MB
    Ultra Aluminus
    Mushkin 650watt SLI
    Seagate 500gb
    Seagate 250gb
    DVD Rom/Burner
    Xtreme Member arfett's Avatar
    Jul 2006
    San Diego
    0
    I have the same power supply and I've run dual GTX cards on it when my friend was out of town for a few weeks and I borrowed his cards. We have 60 amps on our 12V rail so the problem is most definitely not your power supply.
    AMD X6 1090T @ 3.6 GHz (200x18) | ASUS M4A89TD PRO/USB3 | 2 x 2GB DDR3 1600MHz @ 6-9-6-24 1T
    Radeon HD5850 | HT Omega Claro Halo | PC P&C 750W Silencer Mk II | Lian Li PC-60FN
    EK Supreme HF CPU Block -> Swiftech MCR-220 Radiator -> Swiftech MCP-655 Laing D5 Pump
    Heat 32-1-0
+ Reply to Thread
