Results 1 to 5 of 5
Thread: Failing memtest86+ with CORSAIR 2GB DDR3 TWIN3X20481800C7DFIN @ 1800/7-7-7-20
    Dec 2004
    Long Island, NY
    Running memtest86+ using CORSAIR 2GB (2 x 1GB) DDR3 1800 TWIN3X20481800C7DFIN and I got 22 errors.
    E6750 450x7 @ 3.1Ghz/1.35V
    DDR3 @ 1800/7-7-7-20/2V
    Up the vdimm more? I'm already at 2.0V and I flunked Super Pi 32m as well.
    Edit: Also, what's with the cpu being @ 3.6? Does memtest set the multiplier @ 8?
    Sorry, it's a bit blurry:
    New rig: INWIN D-Frame, i7 4770k @ 4.7 Ghz/1.38V, Swiftech H220, MSI Z87-GD65 Gaming, Team Vulcan DDR3 1600, 9-9-9-24, Samsung 840 pro 256GB, EVGA GTX 780, Corsair 850W
    Old rig:Antec 900/GIGABYTE GA-X38T-DQ6
    E6750 @ 3.5 GHz/Thermalright 120 extreme/MX2
    CORSAIR Vengance 8GB
    PNY 8800GT/Thermalright HR-03 GT
    Old, old rig: FX-53/GIGABYTE K8NSNXP-939 nForce3 Ultra/1GB CORSAIR 3200XLPRO
    X800XTPE/WD 74GB Raptor/250GB Caviar
    Corsair Rep
    Apr 2004
    Some times test 5 errors can trace back to the CPU. Have you tried raising the Vcore any or testing the CPU OC with the memory at a slower speed? Also, what is your NB voltage? You are going to need to raise it to get 1800+ on the memory.
    Yes, Yellowbeard, a tall rough man with a big yellow beard
    Dec 2004
    Long Island, NY
    Yeah this is an old thread but I need to upgrade memory. Don't know whether it's Vista or the memory itself but since I only have 2GB and I need more. Games are starting to crash
    Replace or add memory? If I add I would have to make sure the new and old are running at the same speed correct? I've looked and all the current Corsair DDR3 no longer are at 7-7-7-20.
    Recommend 4 GB or more with Vista?
    Thanx
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    you cannot get something that will run the same speed and voltage as that kit anymore, it is time to get all new. i would go for 8GB as it is priced the best and most newer 2GB sticks are single sided so 2x4GB is the way to go. you are also going to be in uncharted territory with low voltage ram on the x38/48.
    i would post on house of help to see what ICs work well on that platform, so you know what rev you want.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Dec 2004
    Long Island, NY
    Will do. Thanx
