Hiya everyone,
has anyone used these....
Creative GigaWorks 5.1 G550W THX Wireless Speakers -
http://uk.europe.creative.com/produc...&product=14661
If so what did u think?
Thanks for your input
Kind Regards
Lloyd
Hiya everyone,
Kind Regards
Lloyd
Rig 1: Intel i7 2600K | Asus Maximus IV Extreme | 8GB Corsair Vengence 1600 C8 | Asus GTX 580 | 1x Corsair F3 240GB | 1x WD 1TB Black | Asus Xonar D2X | Silverstone TJ07 | BigNG | Corsair HX1000 | Corsair A50 |
Rig 2: Intel QX6700 | Asus Maximus II Formula | 8GB Corsair DDR2 |HIS 4870 1GB | 3x 500GB F1 RAID0 | X-FI Fatal1ty | CM-690 II |Corsair HX750 | Corsair A50 |
Rig 3: Intel E6850 @ 3.6GHz Fuzion V2| Asus Maximus Extreme | Full EK NB/SB/Fets | 4GB Corsair Dominator DDR3 1800| EVGA 8800GTX KO EKFC8800GTX |2x WD640GB RAID0 | Laing DDC3.2 w/Petra top | 120.2 BIX | 120.2 BIS | EK 150 Res | BigNG | X-Fi Fatal1ty | Akasa Eclipse |
| Windows 7 Ultimate x64 SP1 on all |
seems like good stuff, you can check out the logitech z5500D, i use them myself, they are amazing, optical and coax inputs as well, as far as the ceative speakers go, i have heard them before, not too bad, but i would pick the logitech over it.............. http://www.newegg.com/Product/Produc...82E16836121120
well i'm already using Logitech Z-5500 THX Certified 5.1 on my desk with 2x PCs and some Logitech THX 2.1's on the below sig (my gaming rig) and am looking to upgrade the 2.1's to atleast 5.1s.
I would just swap them over but i remember seeing while setting up the z-5500's that the sub needs to be 60cms from a PC, and there's no way i could do that, not that it's 60cms from a PC atm! lol
I used to have Megaworks 510 THX on my main pc for 2 years. Changed to Z5500 and didn't regret it since.
Pretty descent system but why bother when there is 5500?![]()
Note that 510's are actually better that G550's.
Project ZEUS II
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
2 x Asus HD 6870 CrossFire @ 1000/1100MHz
OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
Watercooling setup:
1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
Assembled in Mountain Mods Ascension Trinity
Powered by Corsair Professional Series Gold AX1200
I personally can't stand most wireless speakers, but maybe they've gotten better since I last game them a chance. Be sure to remember though that while you can rate a speaker as THX, to have a THX system you'll also need a THX-rated cabling solution (which I assure you, air is not).
Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
Xtreme Network:
- Cisco 3560X-24P PoE Switch
- Cisco ASA 5505 Firewall
- Cisco 4402 Wireless LAN Controller
- Cisco 3502i Access Point
