+ Reply to Thread
Results 1 to 2 of 2
Thread: OCing athlonX2 BE-2300
    Xtreme Cruncher WhiteFireDragon's Avatar
    Jul 2007
    @ the computer
    0
    i have an athlon X2 BE-2300 it's currently OCed to 2.02 (stock is 1.9ghz). so far i've only raised the core speed from 200mhz to 213mhz. this is as high as the core speed will go without raising the multiplier or vcore. i can't raise the multiplier in the bios, so does this mean it has a locked multiplier or is it because my mobo doesn't support it? anyone else OCed one of these before? and if so, what are its general potentials? this is basically another brisbane core that is a lower power consumption version.
    Xtreme Mentor Lightman's Avatar
    Nov 2005
    In Car (across Europe)
    140
    No higher multipliers for this CPU. Only unlocked AM2 CPU is so far B(lack)E(dition) X2 5000+.
    Only way to OC your CPU higher is to increase HTT further. Most should go up to 250-300HTT resulting in 2.4-2.9GHz depending on cooling and your BIOS settings. Make sure that you lower memory divider in BIOS before increasing HTT too high, otherwise you will be limited by max. memory clock.
    Good luck
    RiG1: i5 2500K @4.5GHz (bad clocker), MSI Z68A-GD65 G3, 2x4GB Corsair Venegence 5.11 PC14900, HD6970 2GB, Samsung SS805 100GB SLC SDD (OS Drive) + 2x1TB Samsung F1 RAID0 + 750GB Samsung F1 + 1TB Samsung F3, Hiper 4M880
    RiG2: HTPC AMD A10-5800K APU, 2x4GB Kingstone HyperX 2133C11, Gigabyte F2A85XM-D3H, 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH
    SmartPhone Samsung Galaxy Note II
    XBOX360 Elite paired with 55'' Samsung LED 3D TV
+ Reply to Thread
